Slight annoying vibration finally cured!!! Hub centric vs lug centric
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sandjunkie, May 15, 2012.
  1. Jan 12, 2018 at 1:22 PM
    #81
    imageomega
    imageomega Well-Known Member
    Jarrod
    Has anyone here actually had a vibration fixed by using the ring (as opposed to having it fixed when switching to a hubcentric wheel)?
    I ask because I dont believe there's any way a plastic/rubber/paper piece of junk fixes a vibration. In sports cars, using the rings is a terrible idea as they can melt under heavy breaking heat. They're strictly for getting the wheel centered when installing, and should be removed. If you do the lugs right (star pattern, tighten later) you get the same result.
    In the OP's solution, he fixed is vibration by (in my opinion) swapping lugs which forced the wheel to be more centered. The rings were just there, not the fix.
    So.. anyone? A piece of thin paper/plastic fixed a vibration? Any first hand experience?
  2. Feb 7, 2018 at 5:44 AM
    #82
    Tacoroach
    Tacoroach Well-Known Member
    Vancouver, BC
    2017 DCLB
  3. Mar 4, 2018 at 6:11 PM
    #83
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Bump. Would love to get rid of my steering wheel vibe.
  4. Jun 4, 2018 at 8:56 PM
    #84
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Any longterm updates regarding the plastic rings? I can't find anywhere that provides a 108 to 106.1 ring besides the poorly reviewed Gorilla ones in the OP.
  5. Jun 4, 2018 at 11:05 PM
    #85
    jca
    jca Well-Known Member
    I bought CECO brand hub rings on Amazon. They are aluminum and I've had no complaints since I bought them last November.
  6. Jun 4, 2018 at 11:07 PM
    #86
    jca
    #86
    BraskaTaco likes this.
  7. Jun 4, 2018 at 11:19 PM
    #87
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Are people having to run hub centric rings with SCS wheels?
  8. Jun 4, 2018 at 11:20 PM
    #88
    jca
    SCS wheels are hub centric. No need for rings.
    4x4Taco09 likes this.
  9. Jun 4, 2018 at 11:27 PM
    #89
    4x4Taco09
    Dane
    Louisiana
    Didn’t think so. Only vibe I have is from the needle beating at 25mph. Just need to order the bearing and tool
  10. Jun 10, 2018 at 3:20 PM
    #90
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    #90
  11. Jul 24, 2018 at 5:41 AM
    #91
    Fidgit07
    Fidgit07 Well-Known Member
    David
    13 Taco TRD Off-road
    Rough country 3in suspension lift AMO Buckshot rims 285/75R16. -6 offset RC Bullbar
    I have a question...maybe it’s a stupid question but..
    My aftermarket rims are the American Outlaw Buckshot rims. The bore is 106. But I have the exact same problem that OP was having. Should I still try fix he is speaking of? Or is it something else???
  12. Jul 24, 2018 at 7:34 AM
    #92
    Fidgit07
    David
    So my rim has a 106.2mm bore. Discount tire says this wouldn’t cause a vibration, but they would be more than happy to install the rings to see if it works.
  13. Sep 11, 2018 at 6:55 PM
    #93
    Silentwolf
    Silentwolf Well-Known Member
    2017 Tacoma SR
    Cruise Control,Led Reverse lights, Weathertech mudflaps, Weathertech headlight protectors,Lund stepbar, Interior Leds, AVS Hoodflector, AVS In-Channel Ventvisor, aFe Pro DRY S airfilter, K & N cabin airfilter, A/C drain valve, Mostplus Led Headlights
    Discount Tire never mentioned rings. Bought some hoping to install tomorrow. Can someone provide a link to the lug nuts with extended thread?
  14. Sep 15, 2018 at 7:29 AM
    #94
    RevivalOL
    RevivalOL Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    These should be correct for you:
    Gorilla Automotive 21134ETBC Black 12mm x 1.50 Thread Size Chrome Finish Small Diameter 6-Lug Kit, (Pack of 24) https://www.amazon.com/dp/B00SF8FF86/ref=cm_sw_r_cp_api_tCrNBbRDSYEVE
  15. Oct 6, 2018 at 6:20 PM
    #95
    Silentwolf
    2017 Tacoma SR
  16. Nov 25, 2018 at 1:18 AM
    #96
    WVLungbuster
    WVLungbuster Active Member
    2014 Reg Cab
    So did anyone solve there vibration issues with just the extended thread lugs? I’m hesitant to buy the composite centering rings. The reviews are terrible but I also know how some people wrench on stuff lol.
