Slight rubbing- help me with a solution
Discussion in 'Wheels & Tires' started by Col4bin, Dec 28, 2019.
  1. Dec 29, 2019 at 1:21 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Is it the plastic on the flap? If it is just get Rok Blokz or something similar.
  2. Dec 29, 2019 at 1:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Col4bin
    I don't know what alignment calls for on 2nd/3rd gens but for 1st gen, getting 3 caster helps a bit with that kind of stuff.
    That and pinch weld mod.
  3. Dec 29, 2019 at 1:25 PM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    I've tested full lock and still have no rub. His issue is the mudflaps and no lift... Sorry, I initially thought he had a PRO. My bad.
  4. Dec 29, 2019 at 6:58 PM
    Col4bin
    Col4bin [OP] Well-Known Member
    Maine
    2018 TRD OR Double Cab
    Tire shop is willing to swap these at no cost for the 265/75 ko2. Thinking I’ll have better luck with that?
  5. Dec 30, 2019 at 7:55 AM
    TuRDLYFE
    2020 AG TRD Pro 6MT
    That'll take over 2" off the overall diameter of the tire. You'll be left with a 31.6" tire as opposed to a 32.8" tire. It should definitely alleviate the issues you're having, but no mas 33's. The 265/75R16's are only about $20 cheaper a tire, so you'd end up saving on the mount and balance too.
  6. Dec 30, 2019 at 8:01 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Nahhh keep the 285s and live with the rubbing.
    Col4bin[OP] likes this.
  7. Dec 30, 2019 at 8:02 AM
    TacoRated
    TacoRated Do the chickens have large talons?
    Colorado
    2016 DCSB TRD OR
    High speed, special purpose duct-tape noise cancellation LCAs. Redline Tuning hood struts Hefty Fabworks Rock Sliders Trifold Bed Cover TRD Pro Grille
    I run 285/70/17 so the same outside dimensions. Honestly, here's what I've done. I do go off road, so take that into account. 1) Removed the factory flaps. 2) I did a CMC. Between those two things I had almost no rub on road. When I do hear rub, I go get my handy little oscillating saw and start going to town cutting away parts that have rub marks on them. It's a trial and error thing.
    tcjacado likes this.
  8. Dec 30, 2019 at 11:27 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    It will take 1.2” off overall diameter.
  9. Dec 30, 2019 at 12:13 PM
    Col4bin
    Maine
    OK an inch really isn't much to lose I guess to solve my isues IMO. Is there any other size I should consider given my sitch before I swap these out? They are being very nice and willing to work with me. Nice local shop.
  10. Dec 30, 2019 at 12:34 PM
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Disregard... 1.185" I must have been sleeping doing my math originally :) Thanks!
    If you think an extra 1/2" of clearance is all that you need at full lock and compression then go for it.
  11. Dec 30, 2019 at 3:47 PM
    gotoman1969
    What was on there originally?
  12. Dec 30, 2019 at 3:52 PM
    Col4bin
    Maine
    Just the stock tires and wheels that came on the truck
  13. Dec 30, 2019 at 3:58 PM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    It’s only rubbing on plastic. It may sound horrible but you aren’t really hurting anything.
  14. Dec 30, 2019 at 4:00 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    You’re on the right track man.
    1. Heat up plastic with a heat gun nice and hot and start pushing with something hard.
    2. If that doesn’t do it, start trimming plastic, which is super easy to do with a sharp exacto blade.
    3. If that doesn’t do it, then pinch weld and cab mount are next.
    These trucks are meant to roll on 285’s, regardless of what the “living under a rock fender engineers” produce. It’s all very doable and not difficult to solve. Start small and take care of it as you see the problem areas.
  15. Dec 30, 2019 at 4:12 PM
    #35
    Shawn_of_the_dead
    Shawn_of_the_dead Well-Known Member
    Shawn
    Miami, FL
    2020 Cement SR5 DCSB
  16. Jan 24, 2020 at 12:43 PM
    #36
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Use heat gun and push with piece of wood , pry bar or hammer and hold until it cools to keep the shape. Common trick on lowered cars. If you need you can also cut that section out only- the rest of the flap should still stay intact
