Slightly rough at idle
Discussion in '4 Cylinder' started by Mastiff37, Jan 15, 2021.
  1. Jan 15, 2021 at 10:55 AM
    Mastiff37
    Mastiff37 [OP] Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    When at a light with brake held, the engine is just a touch rough. It may be within tolerance, but it would be nice if it was glass smooth. Any suggestions what I could check into? The truck is new to me, 150K miles. Plugs were changed at the dealer by previous owner at 120K. I ran some Seafoam through it (added to gas only). Other ideas?
  2. Jan 15, 2021 at 11:00 AM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  3. Jan 15, 2021 at 11:59 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id start by cleaning the throttle body and MAF sensor. Make sure you only use MAF sensor cleaner on the MAF, they're very sensitive
    whatstcp and Mastiff37[OP] like this.
  4. Jan 15, 2021 at 12:00 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Put a scan tool on it to check for stored/pending codes as well as check the performance of intake components.
    Mastiff37[OP] likes this.
  5. Jan 15, 2021 at 12:04 PM
    BassAckwards
    Also wouldnt hurt to pull the plugs and see what they look like or if they used the Iridiums. The iridiums come standard on the 4 cyl trucks and should be good for 100k.
    Mastiff37[OP] and whatstcp like this.
  6. Jan 16, 2021 at 8:14 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Have you tried disconnecting the battery for 15-30 minutes to let the computer reset? This will also help the truck get used to your driving style.
  7. Jan 16, 2021 at 8:48 AM
    Mastiff37
    Tucson, AZ
    I'm installing a radio today, so this will happen naturally.
  8. Jan 16, 2021 at 11:23 AM
    tirediron
    It would probably be best to diagnose and repair the idle issue before making any further changes to the electrical system...
  9. Jan 16, 2021 at 1:49 PM
    Mastiff37
    Tucson, AZ
    I want to be clear that it is barely rough, as in, I can tell the engine is running. My Jeep is always like this. I doubt anything is technically wrong, but if I can dial it in I'd like to try.
  10. Jan 17, 2021 at 6:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If the throttle body gets dirty it can cause a low idle speed which especially on a 4cyl engine will make them feel kinda rough, I'd start by cleaning the throttle body and then letting it idle for awhile so it can relearn it's base idle.
  11. Jan 23, 2021 at 2:18 PM
    Mastiff37
    Tucson, AZ
    Just though I'd follow up... I cleaned the MAF and throttle body today and it seems to have improved the idle noticeably. The throttle body was visibly filthy at the plate edges and bore near the closed position, which seems like it could easily contribute to rough idle.
    Novafrk, Dm93 and BassAckwards like this.
