Sloppy Steering Column Fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by betterbuckleup, Jul 26, 2017.
  1. Dec 28, 2017 at 6:50 PM
    #41
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    You can check for play in the slip joint without taking anything apart. Just unlock the column, reach up underneath the dash and grab the column, then try to move the steering wheel. Any small amount of movement is worthy of fixing. Even though my truck only had about 110,000 on it, it had some play. It's really worth fixing, makes it drive so much better, especially on the highway, takes away the wandering.
  2. Dec 28, 2017 at 7:13 PM
    #42
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Just checked it. Yup.....slop.
    Dalandser likes this.
  3. Dec 29, 2017 at 6:35 AM
    #43
    vtframer
    vtframer Well-Known Member
    Vermont
    2001 Tacoma SR5 Extended Cab, 4x4 Manual Trans.
    i think it's crazy that the only way to fix this is to basically make the steering column unsafe by welding it. There HAS to be a better, more reliable way to address this! I would love to do this repair, but I couldn't bear the thought of my self or one of my loved ones getting into an accident and the steering column (which was supposed to be collapsible) ends up hurting or killing the driver. there is no guarantee that the tack weld will give during a collision....
    Matic likes this.
  4. Dec 29, 2017 at 6:41 AM
    #44
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    When its my time to go, its my time
    If i can do it. You can. Follow the step by step on the link posted.
    Dalandser and Matic[QUOTED] like this.
  5. Dec 29, 2017 at 6:58 AM
    #45
    Matic
    Tricky Dick
    Easley, SC
    I'm certainly going to give it a shot. Of the inch of play in the steering, 3/4 of it is in the shaft when I checked it last night.
    I thought the play was due to the steering rack which I had replaced last year. Apparently that was wasted money.
    But after owning the truck for 13 yrs, I figured it was good to replace it anyway.
  6. Dec 29, 2017 at 7:01 AM
    #46
    Matic
    Tricky Dick
    Easley, SC
    In agreement for the most part. But not the only way. You could pay big money to have both the upper shaft and lower shaft replaced.
    Whats the percentage of agreement that the welds would break or the roll pin would break first?
  7. Dec 29, 2017 at 7:02 AM
    #47
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Not a waste. Im sure it was needed.
    Also. I did not tack weld as the tack broke the first time. I gave her 2 nice welds on 2 of the 4 sides
  8. Dec 29, 2017 at 7:04 AM
    #48
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Considering that Fernando's tack weld broke just by driving it around, and I've seen someone else on her have that happen, I think it's quite likely the tack weld *will* give during a collision. I did the roll pin anyways.
    Fernando likes this.
  9. Dec 29, 2017 at 7:12 AM
    #49
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    one could argue that by doing this fix, you make your truck have better handling response, thus making it safer, decreasing your chances to get into a collision in the first place..
  10. Dec 29, 2017 at 8:34 AM
    #50
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm sure you could cut and shape some abs plastic and epoxy it to the inner or outer shaft if you're really concerned about the shaft being able to collapse.
  11. Dec 29, 2017 at 8:37 AM
    #51
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    There might be a couple of other options available. Rather than a roll pin, which would have pretty high shear strength, you might substitute a softer "shear pin". Another alternative that I thought of would be to put the shaft in a hydraulic press and dimple each of the flats of the shaft thereby getting rid of the play between the two. Mine is already welded, and likely my poor welding will fail prior to the shaft coming up though the area where it tilts.
  12. Dec 29, 2017 at 8:39 AM
    #52
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think the thin sheet metal of the column will fail before the roll pin. There's not much surface area contacting it so it should slide diagonally and deform the sheet metal in the column from the looks of what would probably happen. Plus you should have a seat belt and an airbag getting in the way of you and the wheel having a major impact, but like I said, there's ways around it, if you want to take the time to pull it apart and do some problem solving.
  13. Dec 29, 2017 at 9:58 AM
    #53
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I wish someone would just do this with JB weld already
  14. Dec 29, 2017 at 10:11 AM
    #54
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    A single slotted 1/8 roll pin takes 1875lbs for a double shear.
    SafetyDang and Dalandser like this.
  15. Dec 29, 2017 at 12:59 PM
    #55
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I could see that working. If you get a good way of injecting it into the gap and hold it in place while it cures maybe with the roll pin and then knock the roll pin back out. It may or may not have any clamping force, but it doesn't seem like that's important to stop the play between the two shafts.
  16. Dec 29, 2017 at 3:59 PM
    #56
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Oh no. Not just driving. I hammer down when im wheeling! Lol
    nw_chris likes this.
  17. Nov 26, 2018 at 8:35 PM
    #57
    Czechnology
    Czechnology Well-Known Member
    04 Xtracab TRD Offroad
    Using my new TW member necro allowance to raise this thread from the dead (we're allowed one necro a year, right? ;))
    After a modest 1.5" lift and alignment, I noticed the straighter the freeway the more I have to "micro-rock" the steering wheel back and forth tiny amounts to maintain lane. Some googling later I diagnosed the common taco intermediate steering column play problem discussed here. Guys are tack welding or shoving roll pins in to fix it, but I like the idea of mixing some JB weld or JB kwik weld and smooshing it into the tiny gaps between the two steel columns that are designed to collapse in a collision. I think if I let it set a good 24 hours it would be very solid and eliminate the slop, stand up to daily driving, and maybe even as a bonus preserve the safety of the collapsing column. Can anyone see flaws in my plan?
    OneWheelPeel likes this.
  18. Nov 26, 2018 at 8:43 PM
    #58
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    A drill press would be nice for this. I didnt drill the hole straight.
  19. Nov 26, 2018 at 10:12 PM
    #59
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Guess I know what I'm doing tomorrow morning.
  20. Nov 27, 2018 at 10:31 AM
    #60
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    If you're going through all the trouble of removing the steering column just get the damn thing welded. Muffler shop or any non chain mechanic would be happy to do it for a quick $20. My welder buddy recommended 4 tacks evenly however Im sure this is way overkill. Whichever way you go with, its well worth the time.
