slow inspiron
Discussion in 'Technology' started by coffeesnob, Aug 13, 2010.
  1. Aug 13, 2010 at 5:25 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    My wifes inspiron running XP about 4 years old runs super slow..I have done all the spyware/virus scans etc..deleted unneeded programs files etc..did the msconfig start up deal when I try to defrag after it runs there are about 2 gb or files that cannot be defragged..I suspect this probably contributes to the slowness but thats as far as my skills take me. Is there a free program i can download to sort this out? Also what else can I try...thanks all....
  2. Aug 13, 2010 at 5:59 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Did you run a scandisk ? How big is hard drive & how much free space is left ? if theres an icon on your desktop that says my computer right click, go to explore left click & when that window opens up look for your C drive & click on properties you should see a pie chart with a blue area (used space) & a pink area (free space) Ideally you want 1/3 of your drive space free, regardless of size. If you have 2 gigs that won't defrag, you may have some bad clusters.. more info if you can...:cool:
  3. Aug 13, 2010 at 11:35 AM
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    There's a fair bit of startup stuff besides what shows up in Msconfig. Run Hijackthis and go through that list of startup stuff with a fine tooth comb. Iamnotageek.com has a parsing tool for the log if you don't understand it. Be brutal and shut down all the gimmicky startups you don't really need. Kill quicktime, MSoffice, Realplayer, Itunes, toolbars for IE and so on. All those programs work just fine without the preloaders and you save performance. You want to load as little as you need for your system.
    Keep hardware drivers for video and sound, software for security and so on.
    Then go into Windows Explorer. Right click the C: drive icon and click Properties. Click Disk Cleanup. Check boxes for stuff you want to clean out. Should be most of them. Click OK. That purges a bunch of crap files and should help speed as well.
  4. Aug 13, 2010 at 11:40 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    reformat and reinstall windows. Don't forget to save all the important files elsewhere before you do it.
  5. Aug 13, 2010 at 12:04 PM
    tbturner47
    tbturner47 Well-Known Member
    Hickory, NC
    '16 Barcelona Red TRD Off Road
    If you run HiJackthis you can send me a copy of the log and I will go through it for you. This could be a number things. How much memory do you have? If you open up task manager what is your CPU usage at?
  6. Aug 13, 2010 at 12:07 PM
    tbturner47
    Hickory, NC
    I would run chkdsk -f as well
  7. Aug 13, 2010 at 12:08 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    X100
    Its a 4 yr old PC, so there is only so much you can do that is going to speed it up with todays requirements. Best bet is to reinstall though. Things will be as fast as they are gonna get after that.
  8. Aug 13, 2010 at 12:12 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yup alot of resource hog bullshit programs on startup, surprisingly one of the worst is Window's own FindFast..;):D
    God forbid, but yeah sometimes thats what it comes down to, done that more than once...:eek::eek:
  9. Aug 13, 2010 at 12:20 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No shit huh, my friend's running the full Adobe suite & that fucker takes 2Gigs of Ram just to run it !!! & another guy is using MS Flight Simulator X I think it is with the expansion accelerator pack.... 4 Gigs of Ram to run it !!! It's fucking crazy !!
  10. Aug 13, 2010 at 12:30 PM
    coffeesnob
    VA
    :confused:
    56 total gig 32 used and something like 23 free
    on system information it reads:
    total physical memory 1 gig
    available memory 443 mb
    virtual memory 2 gig
    available virtual 1.96 gig
  11. Aug 13, 2010 at 12:32 PM
    coffeesnob
    VA
    now is hijack this totally free? sometimes these programs download for free and then says we found blankety blank blank and in order to fix it you need to register for $39.99 or so..
  12. Aug 13, 2010 at 12:33 PM
    coffeesnob
    VA
    in another post I stated the HD size. how do you fix bad clusters?
  13. Aug 13, 2010 at 12:41 PM
    dogbite
    Utah
    Hijackthis is totally free.
  14. Aug 13, 2010 at 12:49 PM
    tbturner47
    Hickory, NC
    Ill PM you
  15. Aug 22, 2010 at 8:04 AM
    myname150
    myname150 Well-Known Member
    x2
    i usually reinstall windows every year, succchhaa performance boost. Just keep everything on an external drive (or in the case of my dekstop i keep all my files on another hard drive) to help make backing up easier.
    Orrrrr you could go linux (Ubuntu 10.04) if all you really need is to just browse the web then Ubuntu would be perfect. You really "can't" get infected with a virus unless you give the program your root password. :p
    I love using Ubuntu, since i installed it about a month ago the only time i needed to boot into windows is to copy songs with itunes to my iphone and burn an audio CD
  16. Aug 22, 2010 at 12:56 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
  17. Aug 22, 2010 at 1:16 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    depending on your particular model, some dell laptops have a problem with getting their vents (and fans) clogged with dust, especially if left on couches and carpets all day. if the bottom of yours is too hot to the touch or you hear the fans loudly spinning all the time, it may just need a dust cleaning.
    the reason dust can affect the speed is because excessive dust = poor cooling, poor cooling = system automatically throttles the cpu speed to prevent damage and overheating.
    I used to clean out dusted laptops all the time, and the difference is huge. not saying this is your issue but it could be. removing the dust from these requires disassembling certain parts to get at the main fan, and using a compressed air can blow all the crap out. also using the air can on the vents along the bottom and sides.
  18. Aug 22, 2010 at 1:22 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    +1
  19. Aug 22, 2010 at 1:27 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
  20. Aug 22, 2010 at 4:20 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Reformat it. You will be glad you did.
