Sluggo: The 4 banger build
Discussion in '1st Gen. Builds (1995-2004)' started by IDtrucks, Dec 17, 2011.
  1. Jan 12, 2014 at 6:32 PM
    #541
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    wutwutwut!
  2. Jan 12, 2014 at 6:33 PM
    #542
    BradyT88
    BradyT88 Well-Known Member
    The winks were supposed to be hints to get down here and let's do this! Although you should ok this all through Konsta first. I can't speak for him or his shop.
    He said to just mark out what all you need to cut on the outside and then just drill through to the inside on the corners and use that to make your marks on the inside and start cutting. The drilled holes should cut down on the slag thrown when you try to make that first cut and his plasma cutter didn't throw very much slag when cutting through my 1/4" plate last night so cutting through that sheet metal should be cake for it.
  3. Jan 12, 2014 at 6:44 PM
    #543
    BradyT88
    And if Monte is right and the plasma won't work, well there are a bunch of grinders here and I think Konsta has a sawsall as well.
  4. Jan 12, 2014 at 6:47 PM
    #544
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :D:D:D it certainly would go smoothly with so many nice tools
    it will be a little while before i save up a bit more and get wheels and mount them,
    unless konsta can mount and balance them lol, if i get my fenders done ahead of time, and we get the tub job done quickly i can wheel these suckers with you
  5. Jan 12, 2014 at 6:53 PM
    #545
    BradyT88
    I know somebody who has some older tools to mount them, but it's not all that fun to do it. haha There are several places around that can balance them after that. haha Hell maybe Brant can hook you up at the dealership.
  6. Jan 12, 2014 at 6:55 PM
    #546
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    thats what im lookin for haha
  7. Jan 12, 2014 at 7:00 PM
    #547
    BradyT88
    I kind of doubt he can swing a free mount and balance on all 4 tires, but he might be able to swing a balance on the 4 if we get them mounted.
  8. Jan 12, 2014 at 8:14 PM
    #548
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ah gotcha. well it doesent have to be free lol. if anyone can cut a good deal. how much does it usually cost?
    could always mount them with the kerosene and fire trick, or whatever flammable liquid you use
  9. Jan 12, 2014 at 8:23 PM
    #549
    BradyT88
    dumbest idea ever... Would be epic in a sad way to see you burn your new 35's into molten rubber day 1...
    If we can get them on the wheels, we can seat the beads with a ratchet strap and air compressor easy enough.
  10. Jan 12, 2014 at 8:24 PM
    #550
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rofl:
    i would cry for days
  11. Jan 12, 2014 at 8:24 PM
    #551
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Seen it done with 37" military tires haha
  12. Jan 12, 2014 at 8:28 PM
    #552
    BradyT88
    No thank you... I would have to be in a really bad position before I had to do that... and I carry a few ratchet straps in my toolbox and have a compressor under the hood.
  13. Jan 12, 2014 at 8:32 PM
    #553
    PcBuilder14
    Brent
    Nor Cal
    Agreed. but it is entertaining haha
  14. Jan 12, 2014 at 8:57 PM
    #554
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea..still wont work. The door area is a tube kinda. Like 4 layers and other stupid shit. Pita. The plasma won't reach all of them.
    Sawzall was most effective in combination with cutoff wheels.
  15. Jan 12, 2014 at 9:08 PM
    #555
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    no full size spare??
  16. Jan 12, 2014 at 9:10 PM
    #556
    BradyT88
    Well on the spots the plasma can't get to use the saws all and grinder I guess.
  17. Jan 12, 2014 at 9:10 PM
    #557
    BradyT88
    Psshhh. who needs one of those ;) I'm still running the factory spare...
  18. Jan 12, 2014 at 9:11 PM
    #558
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    crazy bastard.... hahaha mind you when I break my shit its usually WELL out of the limp it home mode, and my buddy with the trailer charges too much hahaha
  19. Jan 12, 2014 at 9:12 PM
    #559
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i would love to find a matching one...but that will be a pain in the ass! ill probably just carry a 33 around with me for a spare for a little while
  20. Jan 12, 2014 at 9:14 PM
    #560
    BradyT88
    Konsta has one for sale. It just needs a wheel.
