Small Lift Options??
Discussion in 'Suspension' started by dza1284, Mar 16, 2011.
  1. Mar 20, 2011 at 5:47 PM
    #121
    dza1284
    dza1284 [OP] Well-Known Member
    CA
    08 OR Short Bed Dbl Cab
    Bilstein 5100, 2" AAL, Grille, BHLM, Footwell LED, Dash LED, Aero exhaust
    So not installing UCA will cause premature tire wear.. is that it? I imagine it will reduce gas mileage.
  2. Mar 20, 2011 at 6:07 PM
    #122
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    At 2.5" you are on the cusp of needing them or not needing them.
    When you lift the truck you change the geometry of the front , lift past a certain point and you can't align the truck without aftermarket UCA's .
    As I mentioned before the results of a poor alignment are premature tire wear and wandering at speed .
  3. Mar 20, 2011 at 6:20 PM
    #123
    dza1284
    CA
    I noticed my truck as blue and yellow bilstein shocks. Are these the stock shocks?
  4. Mar 20, 2011 at 8:12 PM
    #124
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    Sorry, I forget, but what year is your truck OP?
  5. Mar 20, 2011 at 8:13 PM
    #125
    OZ-T
    Peter North
    British Columbia
    Yes . why does that matter if you are replacing them ?
  6. Mar 20, 2011 at 8:38 PM
    #126
    dza1284
    CA
    08. Didn't know the stock shocks were bilstein. I have been trying to figure this out before asking this but what is the deal with the TSB and the leafs? Did certain years have a recall on the leafs?
  7. Mar 20, 2011 at 8:41 PM
    #127
    OZ-T
    Peter North
    British Columbia
    The American trucks come with 3 leafs stock .
    The Canadian trucks come with the 4 leaf , or TSB leaf pack .
  8. Mar 20, 2011 at 8:42 PM
    #128
    dza1284
    CA
    Ok but what is all the talk about Toyota replacing the leafs?
  9. Mar 20, 2011 at 8:43 PM
    #129
    dza1284
    CA
    Is one better than the other? Both provide the same lift right?
  10. Mar 20, 2011 at 8:44 PM
    #130
    OZ-T
    Peter North
    British Columbia
    You can get Toyota to replace your 3 pack with the 4 pack , this is the leaf spring TSB .
    The 4th spring will net you another 3/4" of lift over the US stock 3 leaf pack .
  11. Mar 20, 2011 at 8:46 PM
    #131
    manofsteel
    manofsteel Active Member
    Texas
    TRD Off Road
    People get the tsb leafs, for better towing/hauling capabilties, and also a little lift.
    The Tsb (four leafs) are stronger. Some say stiffer ride, others say rides like a truck.
  12. Mar 20, 2011 at 8:46 PM
    #132
    dza1284
    CA
    FYI, I know everyone one here is anxiously waiting to see what is do. Thinking about pulling the trigger on the 4 Bilsteins and the 2" AAL. Might just it to 2.5" and see how she rides.
  13. Mar 20, 2011 at 8:47 PM
    #133
    OZ-T
    Peter North
    British Columbia
    Get the LR UCA's
  14. Mar 20, 2011 at 8:47 PM
    #134
    dza1284
    CA
    So Toyota will just make this change if you ask them..
  15. Mar 20, 2011 at 8:48 PM
    #135
    dza1284
    CA
    I can't spend another 500 right now.
  16. Mar 20, 2011 at 8:48 PM
    #136
    OZ-T
    Peter North
    British Columbia
    Save your money .
  17. Mar 20, 2011 at 8:49 PM
    #137
    dza1284
    CA
    Another 3/4" on top of the rake the stock truck already has?!? Canada sells them stock like this.
  18. Mar 20, 2011 at 8:50 PM
    #138
    dza1284
    CA
    Seems people are split.. A lot say you don't need them at 2.5" and havent had any problems. Others say you deff need them
  19. Mar 20, 2011 at 8:50 PM
    #139
    OZ-T
    Peter North
    British Columbia
    Yes
  20. Mar 20, 2011 at 8:53 PM
    #140
    dza1284
    CA
    So what you think.. Just get the 2" AAL or have toyota do the TSB and add a 1.5" AAL. Is one really any better than the other?
