Small lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Acharenio, Mar 24, 2019.
  1. Mar 24, 2019 at 5:44 PM
    Acharenio
    Acharenio [OP] Member
    Arizona, USA
    2018 TRD Off Road
    none
    Hello,
    i'm thinking of putting a fox 2.0 on front and the dakar ome leaf pack medium duty, now my question is do i need to change the shocks in the back also, is a 2018 trd off road and that will give a couple of inches front and back, that is perfect for what i need.
    Thank you for the help.
  2. Mar 28, 2019 at 11:35 PM
    Acharenio
    Arizona, USA
    2018 TRD Off Road
    none
    any opinions?
  3. Mar 29, 2019 at 4:51 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, your factory shocks are not long enough. They will over extend, with the Dakar leaf pack.
  4. Mar 29, 2019 at 6:24 AM
    MontysTruck
    MontysTruck Well-Known Member
    2017 Tacoma TRD Pro
    Are you going to be running any extra weight? (sliders, skids, bumper, winch, stuff in the bed, etc)
  5. Mar 29, 2019 at 6:27 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Look into adding 2-3 degrees of angle to the rear axel.
    na8rboy likes this.
  6. Mar 29, 2019 at 8:08 AM
    Acharenio
    Arizona, USA
    2018 TRD Off Road
    none
    thank you for the help, and no extra weight, only when i go camping or hunting that i put the gear.
  7. Mar 29, 2019 at 8:19 AM
    truckbeans
    truckbeans Well-Known Member
    Kent
    Sylva, NC
    2018 DCSB OR
    OME 887s, nitrochargers all around, Headstrong progressive add-a-leaf, 255/85-R16 Yokohama Geolandar M/T, Full set RCI skids, RCI sliders, SOS Slimline w/ Smitty 10k winch
    It may be worth it to wait on those. I'm running 2" OME lift with no shims and no vibration. I could also just be one of the lucky ones.
    Acharenio[OP] likes this.
  8. Mar 29, 2019 at 10:19 AM
    Jasn
    Jasn Well-Known Member
    Kentucky
    2016 TRD Sport
    The factory shocks are the limiting factor even with the factory leafs. This is by design. So other than limiting leaf extension, its not an issue to keep the factory shocks. Myself...I'd rather not lose the extension and I'd go with longer shocks if I changed the leaf pack.
  9. Aug 13, 2019 at 11:27 PM
    Acharenio
    Arizona, USA
    2018 TRD Off Road
    none
    i think i'm going to order the 2" ome lift, what is the opinion on those and would you get the stock or medium?
    thanks for the help, i have been debating on what to get but not sure yet.
    thank you
