Smaller rotors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hitsy, Jan 2, 2016.
  1. Jan 2, 2016 at 6:31 AM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
    risk of having smaller rotors from like a 4x2 to a 4x4, i have a 4x4 2.7 2007 5 speed tacoma, wanting to put a rotor from a 4x2, 6 lug, same caliper, would it work? or what would be the risk, im not racin or wheelin just daily to and from work.
  2. Jan 2, 2016 at 6:35 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    What do you want to do??
  3. Jan 2, 2016 at 6:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    What is the goal of this 'change'?
  4. Jan 2, 2016 at 8:45 AM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
    15 inch rims. Ik some 2nd gens run single piston calipers, but wonderin if just changin the rotor would be any differnece or if the rotors are different, i believe theyre smaller just abit.
  5. Jan 2, 2016 at 8:47 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    The issue with running 15" wheels is that the wheels contact the caliper on the 2nd gen tacoma. Changing to a smaller (shorter diameter) rotor wouldn't change where the caliper is located as the caliper is mounted to the spindle.
  6. Jan 2, 2016 at 8:49 AM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
    Smaller caliper woukdnt be an option i guess unless redoing the brake system in a way, its easier to get 16s or 17s i can agree on that, really keen one these 15s, not sure if swapping the caliper and rotor out would be viable, and running 2inch spacers would clear on these rims.
  7. Jan 2, 2016 at 8:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    The Private is correct. You're not on the correct part of the problem. The caliper is a fixed position. While it may still adequately grip a smaller rotor (which I'm not even sure of), the smaller dia. rotor won't lower the amount of wheel clearance needed.
  8. Jan 2, 2016 at 8:51 AM
    Bishop84
    Bishop84 Well-Known Member
    Arent the single pistons only 5 lug?
  9. Jan 2, 2016 at 8:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't let looks turn you into a hack.
  10. Jan 2, 2016 at 8:52 AM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    Don't.
  11. Jan 2, 2016 at 8:55 AM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
    I like the stanced trucks, not goin big on tires(265/10.50), just different rims, -47mm. Just tryna figure out how ima do it i guess. Thank ya'll
  12. Jan 2, 2016 at 9:07 AM
    Hitsy
    Hitsy [OP] Member
    Brandon
    07 Taco, 4x4 2.7
  13. Jan 2, 2016 at 9:14 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Youd be better off buying a 90s Nissan Kingcab if you want to pull off the look of spidered out small wheels on a low truck.
    Why ruin a Tacoma?
  14. Jan 2, 2016 at 9:16 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Yeah... I think it became a bad idea when the other guy who did it said "I broke a caliper even after I grinded it down. Now I've got a total of 4" of spacers per axle!"
    Is 1" of wheel diameter really worth all that?
    Lord Helmet likes this.
  15. Jan 2, 2016 at 9:24 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    X2 brotherman. 4" of spacers is going to cause a lot of excessive wear and tear to your front components. I'd recommend sticking with 16"s; however, it's your money and your truck - just my two cents.
  16. Jan 2, 2016 at 10:33 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  17. Jan 3, 2016 at 3:36 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is a 6 lug the 4X2 rotor it would be the same size as a 6 lug 4X4 rotor.
    They use the same parts.
  18. Jan 3, 2016 at 3:58 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Beyond all the obvious reasons NOT to, consider this.. brakes work by changing kinetic (motion) energy into heat energy, which is then sucked up by the metal mass of the rotor/drum then air cooled by the spinning motion, to be ready the next time you apply them. That's why hot brakes (insufficiently cooled) don't work. Any reduction in size, even normal wear, compromises this process. You need the heaviest (most mass) heat sink (rotor/drum) you can find. Nothing less.
