smaller tire fitment
Discussion in 'Wheels & Tires' started by anotherreject, Jan 5, 2012.
  1. Jan 5, 2012 at 10:28 AM
    anotherreject
    anotherreject [OP] Well-Known Member
    i tried to do a search but when i click it my computer says "page can not be displayed"
    normally the threads on here are about squeezing bigger tires onto a stock setup, im trying to find out what smaller tires will fit.
    the taco is a stock '05 double cab short bed trd sport
    i rarely do any hard off road stuff so im not looking to get a lift and huge tires. im just looking to replace my stock tires right now for as cheap as i can.
    will a 245/70/17 or 235/65/17
    A) fit on the stock trd sport wheels? i was thinking they may be too skinny and the bead could come off the wheel
    B) cause any other issues im not thinking of?
  2. Jan 5, 2012 at 12:29 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Either of those tires will fit with no issues, but a couple of points to consider:
    1: A 265/70/17 is so common that it will almost always be cheaper than either of the sizes you listed.
    2: A 235/65/17 is a tiny tire and will look completely ridiculous.
  3. Jan 5, 2012 at 1:11 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
  4. Jan 5, 2012 at 1:24 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Keep the stock diameter for best mpg. 245/70r17 would provide the best results based on what you have said, followed by 265/65r17.
  5. Jan 6, 2012 at 5:46 AM
    anotherreject
    if i can save up enough for a new set of 265/65/17 or 265/70/17 (about $160 a piece) i will get those. downfall to the 265/70 would be needing a 5th for a matching size spare.
    i was considering the 245/70/17 from treadwright, at $80 a piece. even after shipping and buying a 5th for a spare i would be spending about $150 less. the 265/70/17 from treadwright ar about $115 if i recall correctly.
    im on a budget and also trying to save to go on my first vacation in 4 years.
  6. Jan 6, 2012 at 5:53 AM
    KPT
    09 Prerunner
    You wouldn't necessarily need a new spare if you are only going to throw it on the front to get to a tire repair place.
  7. Jan 6, 2012 at 5:56 AM
    anotherreject
    true
  8. Jan 6, 2012 at 6:26 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    anotherreject, Look at the for sale section here at TW for low mile take off tires, as well as Craigslist in your area.
  9. Jan 6, 2012 at 9:52 AM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I would also add that even on the rear, a little different sized spare will be fine if it's basically to get you to a tire shop. I wouldn't waste your money on a 5th tire for any of the tire sizes being considered.
  10. Jan 7, 2012 at 6:17 AM
    anotherreject
    ok thanks
  11. Jan 7, 2012 at 6:27 AM
    MQQSE
    MQQSE Bannable
    Rob III
    Monkey Mountain
    "Stitch"
    Awaiting parts
    This ^^^^^ and also: check auto wrecking yards in your area too. My son got a fantastic deal on a set of low mile BFG All Terrain A/T KOs for his truck that way. Worth checking around.
  12. Jan 7, 2012 at 6:32 AM
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    Why don't you buy three tires to fit the size of the spare (I am assuming it is stock size) and have the best of the ones you are replacing become your new spare?
    Then you only need to buy 3 new tires and you will have all of them stock size.
  13. Jan 7, 2012 at 7:20 AM
    anotherreject
    i was gonna do that until we had our first snow and i got see how bad the stock dunlop at20's are
  14. Jan 7, 2012 at 8:49 AM
    MQQSE
    MQQSE Bannable
    Rob III
    Monkey Mountain
    "Stitch"
    Awaiting parts
    ... And they suck in rain too! Least that's my experience. Say NO to Dunflops!
