Smaller tire sizes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CanTac, Nov 29, 2011.
  1. Nov 29, 2011 at 4:03 AM
    CanTac
    CanTac [OP] Well-Known Member
    Peterborough On./Ocala Fl.
    23 TRD Sport 4X4 D/Cab Long Box
    Have done search on tires and it seems that everyone is going with larger size tires. I would like any
    information on going to a taller, skinny tire? Anybody gone that way? Something that is not going to really change the speedo, same height as stock, but skinnier. Currently running 265-65-17 and time for a change.
  2. Nov 29, 2011 at 5:02 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Fuel mileage may increase a bit and so should wet traction. Braking and overall traction on dry pavement my decrease a bit also.
  3. Nov 29, 2011 at 5:08 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I had 245/75/16s on my prerunner when I got it. Didn't like. The 265/70/16s on it now are much better ride, handles better & mpg/speedo unchanged. Since you seem to be headed other way I might suggest a 245 or 255/70/17. Whichever keeps you closer to same OD as the 265s you have now. Check sizes on a tire size calculator to see like this....
    245/70/17 seems to be closest to not changing speedo....
  4. Nov 29, 2011 at 7:05 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you're doing this for milage, just fyi, I went from the 245/75-16 to a 265/70-16 and saw no milage gain or loss. Also wet and dry traction went up, and, IMHO, ride was better.
  5. Nov 29, 2011 at 7:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    245/75R17 is a little taller and an inch narrower but you may have trouble finding tires that aren't D or E rated. 245/70R17 is the same height and an inch narrower.
