Smell from heater
Discussion in 'Detailing' started by Deoxide, Nov 28, 2013.
  1. Nov 28, 2013 at 2:20 PM
    Deoxide
    Deoxide [OP] Member
    Louisiana
    2012 DCSB TRD Sport
    20%/5% tint Weathertech floor liners
    I have no clue where to post this but when I use my heat and change it defrost/feet or just feet area it has a really weird smell. Anyone have a clue why? 2012 double cab
  2. Nov 28, 2013 at 2:22 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Explain the smell?
    Could be coolant, could be the smell of feet.
    Does it smell like anti freeze?
  3. Nov 28, 2013 at 2:30 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Possibly a dead rodent? Whens the last time you cleaned your in cabin air filter?
  4. Nov 28, 2013 at 2:51 PM
    Deoxide
    Deoxide [OP] Member
    Louisiana
    2012 DCSB TRD Sport
    it's been there since i got the truck so I just never turned it to the feet option or what ever. can't really explain the smell not like bad feet or anything. i just changed the in cabin air filter.
  5. Nov 28, 2013 at 2:52 PM
    Deoxide
    Deoxide [OP] Member
    Louisiana
    2012 DCSB TRD Sport
    ill go see if i can figure out what it smells like and ill get back with you guys
  6. Nov 28, 2013 at 3:30 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    AC compressor runs when on defrost to dry the air, could be mildew on the evaporator.
  7. Jan 10, 2014 at 9:31 AM
    minerally
    minerally Member
    same deal with my 2012 DCLB. smell is worse with defrost or defrost/feet setting. filter changed. any luck getting this to go away deoxide?
  8. Jan 13, 2014 at 8:14 PM
    Deoxide
    Deoxide [OP] Member
    Louisiana
    2012 DCSB TRD Sport
    I haven't figured anything out I have had people tell me it smells like vinegar tho. It's only on feet and defrost/feet. I have just avoided using those settings as much as possible.
  9. Jan 13, 2014 at 8:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Maybe it's your feet?
  10. Jan 13, 2014 at 8:32 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Previous owner have children? Spilled milk that spoils smells a bit like vinegar. Buddy couldn't sell a trade in cuz of spilled/spoiled milk. Removed everything in the cab, gave it a bath and most of it went away.
  11. Jan 13, 2014 at 8:34 PM
    Taco'09
    Taco'09 Well-Known Member
    Inside the HVAC box there is a shallow depression at the base of the evaporator. Perfect place for condensation off the evaporator to collect and grow stinky stuff. A hose drains this space to the outside. Maybe outlet of hose plugged?
  12. Jan 14, 2014 at 1:55 PM
    Deoxide
    Deoxide [OP] Member
    Louisiana
    2012 DCSB TRD Sport
    Same smell if I am not in the truck
  13. Nov 3, 2018 at 8:22 AM
    brother.earth
    brother.earth DrinkSmokeFish!
    Southwest Idaho
    2011 Taco TRD Sport
    Sorry for the revival, but I’m curious if any conclusion came from this! Same situation here, get a smell only when on defrost or foot setting with the heat on (not through head vents, not when A/C is on, and it’s worse at the low setting than with just def)
    At first it almost smelled like a massive overuse of air freshener. Kinda spicy/floral/maybe a tiny bit sweet and a tiny hint of possible gasoline smell but not enough to say “yeah, that smells like gas”...
    I’m stumped!
