SMKYTXN'S 2011 DCFBFTMFW Solid Axle Swap
Discussion in 'Solid Axle Suspension' started by SMKYTXN, Jun 18, 2017.
  1. Mar 2, 2018 at 4:53 PM
    #521
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Did you by chance try a land cruiser 1.125" master cylinder?
    ChadsPride likes this.
  2. Mar 2, 2018 at 4:55 PM
    #522
    madmax700r
    madmax700r Well-Known Member
    Washington
    98 4bt swapped on tons and 43’s
    Why not go 1 ton master cylinder and full hydro boost? This is on my first gen
    Slashaar, ChadsPride and ovrlndkull like this.
  3. Mar 2, 2018 at 5:09 PM
    #523
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    What does your pedal do? Lots of travel then it finally engages and stops?
    Nope, that one wasn't on my list. So far I've tried the stock MC and the Tundra MC. The Tundra MC has a 0.94" diameter and the GM mc has a bore of 1.3".
    At this point it's not a force issue it's a proportion issue. The hydro boost would push harder, but if there's not enough fluid to push it's not going to help. We'll see what the new master does for me and if the Tundra dual diaphragm booster is enough to push it.
  4. Mar 2, 2018 at 5:13 PM
    #524
    madmax700r
    Washington
    Well if you do want to go full hydro I have about $250 into my master cylinder/booster. So it’s not super costly to swap.
    Edit: now that I think about it idk if the set up I have will work since it is Alittle longer then the factory set up and you will loose certain electrical connections for your abs and such. So scratch that.
  5. Mar 2, 2018 at 5:20 PM
    #525
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    yup, lots of travel then stops. I mean, it will definitely lock them up but lots of travel.
  6. Mar 2, 2018 at 5:21 PM
    #526
    xweslingx
    Wes
    Durham, NC
    We don't have abs at this point anyway so it doesn't sound bad.
  7. Mar 2, 2018 at 5:33 PM
    #527
    RedBeard1
    Red
    I only suggest the Land Cruiser MC because it shares the common Toyota mount flange. I used it and a Early Tundra booster on my first gen toyota when I went to tons and 42" worked good for me but it was also not a daily driver. It would however lockup 42s on pavement.
  8. Mar 2, 2018 at 9:17 PM
    #528
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yeah, the ABS pump is long gone and the only other electrical component is the level sensor. One more light on the dash won't hurt. :rofl:
    You're still on the stock mc and booster, right?
    The area of the LC mc isn't quite as large as I need it to be. At least not as big as I think, but we'll find out.
  9. Mar 2, 2018 at 9:20 PM
    #529
    SMKYTXN
    Nathan
    Houston
    DCFB
    One step down. The mc is now bolted up to the booster. I’ll measure for and make the plunger on Sunday when I get out to the shop.
    C0B4ACDD-93B2-4834-9CCF-600E57B636FB.jpg E45A67AA-0D59-4164-A7A6-DEEEF21A154C.jpg FC6E980B-BCF6-4218-8732-F9521DEF8397.jpg
  10. Mar 2, 2018 at 11:42 PM
    #530
    xweslingx
    Wes
    Durham, NC
    Still on stock mc and booster yes.
  11. Mar 3, 2018 at 1:23 PM
    #531
    SMKYTXN
    Nathan
    Houston
    DCFB
    So here's my take on the problem I have with my current setup. Current being a Tundra master cylinder and booster.
    The relatively small mc produces more pressure, but pushes a smaller volume of fluid. So that ends up with a much greater pedal travel to achieve that pressure.
    The hydraulic ratio between the mc and caliper piston is what I'm basing the new mc choice on. The higher the ratio between the two the less pedal effort is required and the longer the pedal travel to achieve the clamping force.
    The Tundra MC has a bore of 0.94" and an area of 0.69 sq. in. The chevy 3/4 ton calipers on the truck have 2-15/16" pistons. Each caliper is a single piston. The area of the caliper piston is 6.77 sq. in. So right now my hydraulic ratio is 6.77 / 0.94 = 9.81:1. In order to decrease that ratio I will need a larger bore master cylinder or smaller piston calipers. The smaller calipers aren't a good idea with the weight of the rig, so a new master cylinder is in order.
    The GM MC has a 1.3125" diameter bore and an area of 1.35 sq. in. So my new ratio will be 6.77 / 1.35 = 5.01:1. That decrease in hydraulic ratio will mean a higher pedal with an increased effort in pedal force to achieve the same braking force. The next question will be does the Tundra dual diaphragm booster have enough balls to overcome that higher force or not. Time will tell on that one.
    Obviously we're not going to get, nor do we want to get down to a 1:1 ratio. Meaning the master and caliper have the same size. We want that hydraulic advantage of a smaller piston pushing a larger one. We also don't want the hydraulic advantage to be too high causing the pedal to be too easy to push.
    So that's where I'm headed with this. I'll report back when I have everything installed and test.
    Biscuits, JTB727, Brice and 10 others like this.
  12. Mar 5, 2018 at 5:30 PM
    #532
    SMKYTXN
    Nathan
    Houston
    DCFB
    Success! The combination of the Tundra booster and the gm one ton master cylinder did the trick. I now have a pedal with stock travel length or a hair less.
    I did discover a few things during the install. One being that I need to size the hole in my adapter to accommodate an oring on the master. I also need a gasket between the adapter and the booster.
    For now I have temporary rubberized gaskets in place that are doing a decent job. I still have a slight vacuum leak, but it’s not horrible. I’ll revise my cut file and make another adapter.
    I’ll get the pictures posted when I get back to the house.
    tacoma16, Biscuits, SuperBad and 9 others like this.
  13. Mar 5, 2018 at 5:31 PM
    #533
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    :yes:
  14. Mar 5, 2018 at 6:12 PM
    #534
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    I’ll take one if your selling
    Ariyan and ChadsPride like this.
  15. Mar 5, 2018 at 6:29 PM
    #535
    SMKYTXN
    Nathan
    Houston
    DCFB
    That’s the plan bud. Give me a bit to get the kit together.
  16. Mar 5, 2018 at 6:33 PM
    #536
    SMKYTXN
    Nathan
    Houston
    DCFB
  17. Mar 5, 2018 at 8:01 PM
    #537
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Awesome! Normally I don't care much for flatbeds, but that thing is awesome. :thumbsup:
    :jellydance:
    I need more taco money....:pout:
    SMKYTXN[OP] likes this.
  18. Mar 5, 2018 at 8:02 PM
    #538
    Manwithoutaplan
    ID
    well done sir!
  19. Mar 5, 2018 at 10:15 PM
    #539
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Not sure if this is of any help at this point buuuutttttttt http://home.4x4wire.com/erik/4runner/brakes/
    Slashaar likes this.
  20. Mar 5, 2018 at 10:18 PM
    #540
    SMKYTXN
    Nathan
    Houston
    DCFB
    Slashaar and Brice[QUOTED] like this.
