SMKYTXN'S 2011 DCFBFTMFW Solid Axle Swap
Discussion in 'Solid Axle Suspension' started by SMKYTXN, Jun 18, 2017.
  1. May 30, 2018 at 8:04 AM
    #721
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :ohsnap: Go hard or Go home.
    SMKYTXN[OP] likes this.
  2. May 30, 2018 at 8:05 AM
    #722
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Sounds good, you have my number so just text me in the morning. I will have everything packed, so will just be waiting or doing a couple last minute things around the house.
    SMKYTXN[QUOTED][OP] likes this.
  3. May 30, 2018 at 8:08 AM
    #723
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Can't just go out and run access roads!
    ETXTacoma likes this.
  4. May 30, 2018 at 11:20 AM
    #724
    SMKYTXN
    Nathan
    Houston
    DCFB
    A different kind of roll call? :rofl:
    B2A62635-C313-4C0D-94C5-66B83D45E5E0.jpg 76F97F2A-570D-478E-8493-51841480C9B7.jpg 120BC9E6-D0D2-45AB-BE2A-195F8BB774FF.jpg
  5. May 30, 2018 at 11:59 AM
    #725
    ETXTacoma
    Steven
    Tyler, Texas
    You need like a parts broken area and put a trail toys logo every time you go somewhere and you break something the very first day... kinda like WW2 pilots and their kills, but the exact opposite...
  6. May 30, 2018 at 6:19 PM
    #726
    SMKYTXN
    Nathan
    Houston
    DCFB
    She’s back together and loaded. Headed out in the am.
    Nimble9, Neutral, Slashaar and 8 others like this.
  7. May 30, 2018 at 7:15 PM
    #727
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Bad ass rig man
    ETXTacoma and SMKYTXN[OP] like this.
  8. Jun 2, 2018 at 8:29 AM
    #728
    outdoorguy87
    outdoorguy87 Well-Known Member
    Justin
    2016 Taco TRD OR DCLB
    AFe cold air intake system, levelling kit, OEM massive LED projector heads, CBI offload bed rack with THULE box, Winjet LED rears
    Love this post. This is why i have a truck
  9. Jun 2, 2018 at 8:36 AM
    #729
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Im thinking of going to RT as well, down for heading south to sand hollow for some wheeling after RT?
  10. Jun 2, 2018 at 11:59 AM
    #730
    SMKYTXN
    Nathan
    Houston
    DCFB
    We’ll see. I have to be back on the 31st for the TX4WD fall run.
  11. Jun 2, 2018 at 12:04 PM
    #731
    SMKYTXN
    Nathan
    Houston
    DCFB
    Having a good time out here at the Razorback Rambke. 2CA28E77-A432-445F-86D3-6A1C4709D5E6.jpg
  12. Jun 2, 2018 at 4:03 PM
    #732
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    How was the knuckle machining and arms you had done? I was looking at Sky to do it but noticed you used 4 Wheel Supply. They seem to be a little cheaper.
  13. Jun 3, 2018 at 1:08 PM
    #733
    SMKYTXN
    Nathan
    Houston
    DCFB
    The machining work was just fine as well as the new arms. I didn't see anyone else willing to mess with my particular knuckles so I went with them.
    stumbles[QUOTED] likes this.
  14. Jun 4, 2018 at 4:15 PM
    #734
    SMKYTXN
    Nathan
    Houston
    DCFB
    The Razorback Ramble was a blast, though a bit on the warm side. I managed to not break anything on the rig, well nothing obvious. I'll give her a good onceover this week to see how things faired.
    IMG_7892.jpg IMG_7899.jpg IMG_7903.jpg IMG_7902.jpg IMG_7937.jpg IMG_7941.jpg IMG_7970.jpg IMG_7977.jpg IMG_8004.jpg IMG_8077.jpg IMG_8124.jpg IMG_8123.jpg IMG_8185.jpg IMG_8184.jpg
  15. Jun 4, 2018 at 4:18 PM
    #735
    SMKYTXN
    Nathan
    Houston
    DCFB
    ETXTacoma and ChadsPride like this.
  16. Jun 4, 2018 at 4:32 PM
    #736
    ETXTacoma
    Steven
    Tyler, Texas
    You bet man! Thanks for letting me ride shotgun and tag along for all the trails that we did! I had a blast and even if I may not have wheeled a lot, I still got in enough hard stuff for me that I am satisfied and the trip was well worth the time, money, and sweatx10.
    I will definitely be going back to that park this year!
    Misplaced Nebraskan likes this.
  17. Jun 4, 2018 at 4:39 PM
    #737
    SMKYTXN
    Nathan
    Houston
    DCFB
    There's plenty for all levels out there, that's for sure. We'll see if I can swing the cruiser crawl in October. Should be a good time.
    ETXTacoma[QUOTED] likes this.
  18. Jun 4, 2018 at 4:42 PM
    #738
    ETXTacoma
    Steven
    Tyler, Texas
    Yea, now that I see that the dates for Rock Therapy would be the weekend after SCC... who knows. All depends on $$$ for me and if I could swing both back to back. Highly doubt it, so would have to see which one I could do, then Fall Run the weekend after Rock Therapy and I won't miss Fall Run.
  19. Jun 12, 2018 at 10:55 AM
    #739
    SMKYTXN
    Nathan
    Houston
    DCFB
  20. Jun 20, 2018 at 1:00 PM
    #740
    94blake
    94blake Active Member
    Blake
    Winnipeg
    '12 tacoma sport someone give me a locker hook up
    list is always changing, just check out my build thread if I've made it yet
    Hey man love the rig, just wondering how did you keep your wheel speed sensors? or does your speedometer just not work?
