Smog Pump Noise on Cold Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mskeels4270, Sep 22, 2018.
  1. Sep 22, 2018 at 12:01 PM
    Mskeels4270
    Mskeels4270 [OP] New Member
    Hello,
    I have a 15 Tacoma Double Cab. I believe this whining noise I hear upon cold start is the smog pump. I’ve attached a video I took on cold start. Does anyone else’s sound like this? It does go away after 30 seconds or so but annoying.
    Thanks,
  2. Sep 22, 2018 at 1:12 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welcome! That is your secondary air injection pump like you thought. I recommend taking the foam filter out of the inside and adding a 1" unifilter to the end. This will prevent the foam filter from getting sucked into the air injection pump and causing the valves to get damaged if the filter breaks down over time.
    Here is a link with more info
    https://www.tacomaworld.com/threads/secondary-air-pump-mod.558917/page-2
  3. Sep 22, 2018 at 2:02 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Normal!
  4. Sep 23, 2018 at 5:10 AM
    Greenpants
    Greenpants Well-Known Member
    Massachusetts
    2009 4x4 Tacoma 4 banger
    The tailgate mod
    Thats the normal sound. I think its a little louder after the UNI filter mod.
    greenpants....mike
    seanile likes this.
  5. Sep 23, 2018 at 5:17 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    A little louder? Mine sounds like it has a supercharger on cold starts.
  6. Sep 23, 2018 at 11:51 AM
    Mskeels4270
    Thanks for the info guys. I knew the noise on shutdown was normal but the noise on startup I just noticed. Oh well, I just ordered my unifilter for the mod.
