Smoke on startup only
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dbrawner, Nov 5, 2019.
  1. Nov 5, 2019 at 12:14 PM
    #61
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you mean it's good for MORE than breakfast ?
  2. Nov 5, 2019 at 12:32 PM
    #62
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    "it has been smoking significantly upon startup."
    i see it stops smoking about 1/2 thru the 15sec. video. this means the issue is in the top end, most likely valve seals as you have stated.
    PCV valve also ? take it back to the dealer ASAP, like this week, tomorrow, and tell them you want the valve seals replaced.
    NOT the f'in rings, geez people.
    Boghog1 likes this.
  3. Nov 5, 2019 at 12:32 PM
    #63
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I wouldn't let them put any kind of additive / treatment in my motor if I planned on keeping the vehicle , no f--ing way.
  4. Nov 5, 2019 at 12:35 PM
    #64
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    dont run anything in it and get it diagnosed first
    100% looks like valve stem seals. Dealer will charge you 1200 -1500 ish for fix, independent would be something like 400 - 900 to fix.
    They guy who traded it probably thought the motor was bad or something, also double check it doesnt it isnt massively overfilled with oil
    Clipper16 and GreyBaldTaco like this.
  5. Nov 5, 2019 at 12:41 PM
    #65
    Bleep100
    17 Sport
    The bad thing is they probably already have added something to the oil trying to hide it .
    auskip07 and fiftyxp like this.
  6. Nov 5, 2019 at 12:52 PM
    #66
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Definitely do not run the Lucas through it
    BSFord and 2019tacosr5 like this.
  7. Nov 5, 2019 at 1:08 PM
    #67
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Wow, already 4 pages on this thread. Idk OP, looks pretty normal to me :notsure: doesn't hurt to being it in the the service department to see what they say, but as the temps get cooler its pretty normal to have see some exhaust come out. It goes away too so I dont see what all the fuss in this thread is about. If it were an oil or antifreeze leak, I'm pretty sure it wouldn't go away after warm up...
  8. Nov 5, 2019 at 1:10 PM
    #68
    fiftyxp
    blue smoke is like not normal ever and should be checked out
  9. Nov 5, 2019 at 1:12 PM
    #69
    GrittyTaco
    GrittyTaco Well-Known Member
    Hatboro, pa
    2017 dclb trd or
    That is definitely not normal.
    MoneyMan55, Junkhead and fiftyxp like this.
  10. Nov 5, 2019 at 1:13 PM
    #70
    thdrduck
    thdrduck Well-Known Member
    Sooo, anyone else have that many miles on their 3rd gen v6? Anyone else see this with their truck? 77k is a goodly amount on a 3 year old truck.
    I also suspect valve seals, just wonder why. My experience is seals wear when guides get worn and that usually happens at higher miles, at least on rocker shaft motors. I have seen a motor leave the factory without valve seals, but that was GM and along time ago.
  11. Nov 5, 2019 at 1:13 PM
    #71
    fiftyxp
    theres a few 100K plus here
    Junkhead likes this.
  12. Nov 5, 2019 at 1:13 PM
    #72
    BSFord
    2018 TRD Sport 4x4
    agree if it's blue, I cant tell from the vid.
  13. Nov 5, 2019 at 1:14 PM
    #73
    fiftyxp
    at least on my pc it looks blueish
  14. Nov 5, 2019 at 1:14 PM
    #74
    Bleep100
    17 Sport
    I bet it burns a qt of oil every 2 or 3 thousand miles .
    fiftyxp likes this.
  15. Nov 5, 2019 at 1:15 PM
    #75
    2019tacosr5
    2019tacosr5 Well-Known Member
    Jacob
    2019 White Tacoma SR5 V6
    That shit messed up the engine in my poor old Tundra 4.7. It had 170k on it and didn’t burn any oil, then my stupid ass saw lucas in auto zone saying it helped old engines last longer. So I got some and put it in at the next oil change. It knocked so bad for the first minute or two on cold start once it started getting cold outside. Back then I didn’t know much about vehicles and thought it was just piston slap, until I changed the oil without lucas and it went away. From that point forward it had very low oil pressure at idle and I think a collapsed lifter. I had to run 10w-40 in it just to keep oil pressure at acceptable levels. That poor old v8 was still so tight after 170k hard miles, the Lucas was just too thick to flow at all. NEVER EVER put Lucas in any modern engine, it’s only made for old sbc’s that burn like a quart every 100 miles...lol
  16. Nov 5, 2019 at 1:15 PM
    #76
    ryan760
    ryan760 Well-Known Member
    Still worth checking the PCV first IMO (quick, easy, and free to do), then yeah, if not that, move to the next thing (valve stem seals).
  17. Nov 5, 2019 at 1:15 PM
    #77
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
  18. Nov 5, 2019 at 1:17 PM
    #78
    BSFord
    2018 TRD Sport 4x4
    And that's when I'd be taking it in to get checked out if it were my truck, not for a tiny bit of exhaust on start up... something to keep an eye on for sure
    GreyBaldTaco likes this.
  19. Nov 5, 2019 at 1:18 PM
    #79
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If it were water vapor it would take longer after starting from cold to show up. This is basically instant, which tells me it's burning in the combustion chamber. Since it makes more smoke when sitting overnight,that leads me to valve stem seals since it has time for more oil to leak into the cylinders.
    kahanabob likes this.
  20. Nov 5, 2019 at 1:18 PM
    #80
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Smoke on start up is an indication of worn valve guides or worn valve stem seals . If you notice smoke on acceleration or deceleration that's an indication of worn rings
