Smoking While on a Incline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheTacoma, Sep 20, 2017.
  1. Sep 20, 2017 at 1:35 PM
    #41
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I experienced that... twice :frusty:
    And the joy of replacing a VP44.
    Jeff1795[QUOTED] likes this.
  2. Sep 20, 2017 at 1:37 PM
    #42
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    I never smelt anything.
    lol well shit, smoke just started happening, and I couldn't tell. not until it toned down and was obvious from the tail pipe.
    JimboAnz[QUOTED] likes this.
  3. Sep 20, 2017 at 1:39 PM
    #43
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
    For what it's worth, previous internal discussion on the situation led me to wonder if it was a malfunction in the valve timing (a theory which stemmed from the clicking), causing uncombusted deposits to burn from the previous cycle. Why this would occur only at incline is what makes me question the plausibility of such an issue.
    Sandytaco14 likes this.
  4. Sep 20, 2017 at 1:41 PM
    #44
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    I have nothing useful to offer this thread... but I will say, the white smoke makes for a cool photo. :thumbsup:
    Boneretreiver, Ch78, JaBoudy and 6 others like this.
  5. Sep 20, 2017 at 1:45 PM
    #45
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Diesel yes gas motor no
  6. Sep 20, 2017 at 1:46 PM
    #46
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    This happened to @BigMike
    https://www.tacomaworld.com/threads...-new-2016-tacoma.427850/page-16#post-15873101
    I'm not sure if he ever figured out the cause.
  7. Sep 20, 2017 at 1:50 PM
    #47
    Hiluxski
    Ventura California
    agree lousy design and the reason I know it is I owned an early Toyota 4 x 4 with this exact design flaw as I posted earlier in this thread. Toyota made the return oil passages in the head too small so the oil would gather in the top of the motor causing oil not returning to the pan fast enough. So I agree it is a bad design but that does not mean a bad design could not make it into production. This 3.5 is more of a car motor so it does not surprise me that they would find annoying issues in first years of production in 4x4 application.
    jetfishn, aussieboyroo and TacoTRD78 like this.
  8. Sep 20, 2017 at 1:50 PM
    #48
    Toyko Joe
    Toyko Joe Here for the pictures
    Condensation or accumulated water rolling into the intake?
  9. Sep 20, 2017 at 1:52 PM
    #49
    nDub
    Lead Free Gasoline
    No on their side. Smells like burning oil though
    TheTacoma[QUOTED][OP] likes this.
  10. Sep 20, 2017 at 2:02 PM
    #50
    Hiluxski
    Ventura California
    Do you suggest a oil change and make sure the level is right? It is dead center of the 2 notches on the dip stick right now.[/QUOTE]
    As long as the oil level is correct a change is not necessary. I wouldn't bother taking it to Toyota because they're not going to be able to duplicate the problem unless they put front end up on a lift and duplicate the exact same incline and so on and then the dealer is most likely to tell you it's too high of an incline and it's not designed for that even though we all know that's not true and the truck should easily handle what you did without any issue. I believe this is 3.5 growing pains and a design flaw that will be corrected by Toyota at some point. On the flipside Toyota needs to know about to correct it so if you want to be the guinea pig go ahead but you could be setting yourself up for problems as well.
    Mongoose and TheTacoma[OP] like this.
  11. Sep 20, 2017 at 2:06 PM
    #51
    TheTacoma
    TheTacoma [OP] Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    As long as the oil level is correct a change is not necessary. I wouldn't bother taking it to Toyota because they're not going to be able to duplicate the problem unless they put front end up on a lift and duplicate the exact same incline and so on and then the dealer is most likely to tell you it's too high of an incline and it's not designed for that even though we all know that's not true and the truck should easily handle what you did without any issue. I believe this is 3.5 growing pains and a design flaw that will be corrected by Toyota at some point. On the flipside Toyota needs to know about to correct it so if you want to be the guinea pig go ahead but you could be setting yourself up for problems as well.[/QUOTE]
    I am mainly concerned about it causing problems. It's going to be really annoying if I only have a couple of attempts at a hill climb before having to back out and let it reset before another attempt.
  12. Sep 20, 2017 at 2:09 PM
    #52
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    You know who knows about 3rd Gens? Unfortunately, he is on an unplanned vacation.
  13. Sep 20, 2017 at 2:11 PM
    #53
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    If this is an AT, I'd say the white smoke could be burning ATF. I had an old Toyota pickup that sucked in ATF intermittently through the block every once in a while and it would lose power and leave a white smoke screen behind me. The last time was when I saw a red light glowing behind me through the smoke!
    Edits: Pull the plugs and see if any one of them is gummed up with burnt oil. It could be that you may have a head gasket issue, or ATF is getting into the engine elsewhere, and the oil is getting into a cylinder.
    This is definitely a warranty issue for sure!! Don't drive further until you can verify the condition of your motor oil!
    TheTacoma[OP] likes this.
  14. Sep 20, 2017 at 2:26 PM
    #54
    TheTacoma
    Birmingham, AL
    I will give that a try! That is my main concern, if it's a head gasket issue I need that taken care of before warranty is out!
  15. Sep 20, 2017 at 2:33 PM
    #55
    OnHartung'sRoad
    I endorse this answer, it sounds like a better explanation than mine! But still rule out the possibility that one of the cylinders is burning oil by inspecting the plugs.
  16. Sep 20, 2017 at 2:37 PM
    #56
    TheTacoma
    Birmingham, AL
    I have very little knowledge of engines, I know he said it's a issue on a cummins. Could it also be the issue on a gas? I do seem to lose power after it's been smoking for a couple mins.
  17. Sep 20, 2017 at 2:39 PM
    #57
    Griffin9798
    Griffin9798 Well-Known Member
    West GA
    2017 TRD Off Road
    what is that clicking sound just before the smoke?
    and btw, i've been to choc before, that's not a leisurely stroll for a nearly stock 3rd gen. An "A" for effort fo sho!
  18. Sep 20, 2017 at 2:39 PM
    #58
    TheTacoma
    Birmingham, AL
    THIS^^
  19. Sep 20, 2017 at 2:40 PM
    #59
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Something is being starved of oil.
  20. Sep 20, 2017 at 2:56 PM
    #60
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    @Jake4848 didn't you have a problem in ardbeg doing a hill climb with it stalling because of oil pressure?
    for OP any consideration for something damaged when you dropped off something?
    Prior to the smoke something about wheels off the ground then it appears you dropped pretty hard on something.
