Smoking While on a Incline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheTacoma, Sep 20, 2017.
  1. Nov 20, 2021 at 6:06 AM
    #621
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Damn
  2. Nov 20, 2021 at 6:10 AM
    #622
    shotgunbilly420
    Ive had mine for a few years now and still works great. Now I empty catch can at 5k mi. oil changes
    Skydvrr, TAC1[QUOTED] and 02Duck like this.
  3. Nov 20, 2021 at 6:21 AM
    #623
    shotgunbilly420
    You ever have your truck tuned
  4. Nov 20, 2021 at 7:29 AM
    #624
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    I still have no smoke on inclines and empty it every 3500ish miles , still worth it in my opinion
    TAC1[QUOTED] and shotgunbilly420 like this.
  5. Nov 20, 2021 at 8:26 AM
    #625
    TacomaDad18
    TacomaDad18 overlanderrr asf
    1uz 2018 SR5
    Hard round things Soft round things Metal bouncy things Shifty thing Locking thing
    It was tuned by a friend with OV.
  6. Nov 20, 2021 at 11:44 AM
    #626
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you both!
  7. Dec 21, 2024 at 1:12 AM
    #627
    Gagedakine808
    Gagedakine808 Member
    Gage
    2017 Trd off road 4x4
    It happened to me recently. I had a mechanic tell me. It’s a fuel related issues so I changed all fuel injectors. Nothing has h changed everytime I drive on a normal road up hill. It does that same noise.
    nDub likes this.
  8. Dec 21, 2024 at 10:36 AM
    #628
    eurowner
    eurowner Duke Sky
    Scoty
    It is Not fuel related. It is engine oil pooling.
    TS4x4 and Flori-duh Taco like this.
  9. Dec 22, 2024 at 5:37 AM
    #629
    Gagedakine808
    Gage
    Mines did the same thing, did you find out the problem??
  10. Dec 22, 2024 at 6:12 AM
    #630
    545
    545 Well-Known Member
    2015 Access Cab
    You knocked a hole in your block?
  11. Dec 23, 2024 at 9:24 PM
    #631
    TacomaDad18
    1uz 2018 SR5
    yeah the 3.5.
    seriously though, it had to have hydrolocked because there were two intake ports full of oil when I pulled the motor.
    Flori-duh Taco likes this.
  12. Dec 23, 2024 at 9:25 PM
    #632
    TacomaDad18
    1uz 2018 SR5
    2*
    :rofl:
  13. Dec 25, 2024 at 1:42 PM
    #633
    Gagedakine808
    Gage
    when I change my intake manifold gasket I found that 3 ports had oil in them but the others didn’t. So what did you do to make you car to stop smoking? I can’t really buy a used engine because the shipping to hawaii is expensive as shit . I did add an additive to an oil because I thought it was my valve stem seals. When I did so, no smoke on start up anymore so I was assuming the culprit was my stem seals?
  14. Dec 25, 2024 at 1:46 PM
    #634
    Gagedakine808
    Gage
    Also when I did a compression test my engine all the compression Met the requirements which is really weird. So I’m wondering if your smoke came on start up as well?? Happy Holidays :)
  15. Jan 9, 2025 at 5:31 AM
    #635
    TacomaDad18
    1uz 2018 SR5
    To answer both questions:
    Mine only smoked once, the motor ended up hydrolocking and blew a hole in the block on driver and passenger side.
    I was on an incline just idling. Smoke happened, motor blew (didn’t even know it) truck shut off. Oil everywhere and that was the end of th me 3.5. Can’t speak on the 3.5 anymore as the truck has a v8 in it now.
