snatch block
Discussion in 'Off-Roading & Trails' started by SoutheastTaco, Jan 11, 2010.
  1. Jan 11, 2010 at 7:32 AM
    SoutheastTaco
    SoutheastTaco [OP] Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    can somebody please explain to me how to use a snatch block i've seen them just never used or seen one be used i cant figure it out i believe the proper term for me is ra'tard? thanks for any info
  2. Jan 11, 2010 at 7:47 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    You attach your block to a stable object (tree, using a tree saver), run your cable from your winch through the block and back to your vehicle. http://www.youtube.com/watch?v=Td92wGxvujU
    Also very good for pulling friends from around a bend. When your not able to be directly in front or behind them. Run the cable from your winch to your block then to friends truck. Attach the block to a fixed object again and pull away.
    This drawing shows a typical Double Line:
    A Double Line as used for self recovery using an anchor point such as a tree.
    Indirect Double Line PullIndirect pulling may be required because of obstacles. The pulley block is attached to the load and the wire rope is attached to an anchor point offset from the direction in which the load is to be moved. Note that this procedure is not recommended unless necessary as the winch pulling power and line speed will decrease as the angle between the wire rope increases.
    [​IMG]Single Line Pull
    Whilst this configuration uses a pulley block it is only a single line pull and the pulling power will be as the winch line pull rating as described above.
  3. Jan 11, 2010 at 7:57 AM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    Great info thanks!!!​
  4. Jan 11, 2010 at 8:04 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    No problem man, better to ask here than to show up to wheel and not know whats up and risk getting hurt. Have fun playing with this.
  5. Jan 11, 2010 at 8:12 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  6. Jun 15, 2011 at 10:43 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Great write up!
  7. Jun 15, 2011 at 11:02 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    I have used snatch block's to lift things from time to time :D
    I used 4 block's to lift this F550
  8. Jun 15, 2011 at 11:13 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    :eek::eek::eek::eek::eek::eek:\
    DAMN SON!
  9. Jun 16, 2011 at 5:50 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I am gonna go out on a limb here and guess that the hoist on the beam wasnt working?
  10. Jun 16, 2011 at 10:31 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
  11. Jun 17, 2011 at 5:09 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
