Snow chains??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KALRODJ, Dec 9, 2013.
  1. Dec 9, 2013 at 9:16 AM
    KALRODJ
    KALRODJ [OP] Member
    Paul
    Planning on taking a trip to see some friends in Oregon for the holidays, and i want to buy a set of chains that aren't too difficult to put on, are NOT wire rope constructed, and won't beat the stuffing outta my Tacoma. Any words of wisdom from experience are appreciated!
  2. Dec 9, 2013 at 9:29 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Practice installing them. Here is a good video about installing them and I would suggest never to drive over 30 mph. Usually 25 to 30. Also the tensioner is usually extra, but it is wise to use it. Bungee cords will substitute. http://www.youtube.com/watch?v=qs3r1z5loBk They cost from 25 dollars to over 600 dollars depending on brand, size, type, and where they are purchased. Sears and most auto parts stores sell them along with Amazon. Here is some to look at. http://www.amazon.com/s/?ie=UTF8&ke...vptwo=&hvqmt=b&hvdev=c&ref=pd_sl_73raqcokm1_b
    Unless you are required to use these things by law or you are on some serious ice or extremely deep snow a good set of snow and ice tires will do wonders without chains especially if you have 4X4 and even if not . If you are using a pick-up I suggest a couple hundred pounds of bags of sand or kitty litter over or behind the drive axle. It can also be used to get you out of a tough spot if needed. Have a safe trip.
  3. Dec 9, 2013 at 9:29 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT
  4. Dec 9, 2013 at 12:00 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
  5. Dec 9, 2013 at 12:02 PM
    Manwithoutaplan
    ID
    Maybe try Craigslist that is where i bought mine from.
  6. Dec 9, 2013 at 12:07 PM
    BamaToy1997
    Bill
    Navarre, FL
  7. Dec 9, 2013 at 12:08 PM
    jethro
    Geoff
    Southern NH
    That's what I was told!:p
  8. Dec 9, 2013 at 12:09 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  9. Dec 9, 2013 at 12:10 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I have chains and cables for my truck. The cables are easy to put on and ride alot better. If the weather is bad though. Nothing better than a good set of chains. Just practice alot. Putting them on in a storm or at night is hard.
  10. Dec 9, 2013 at 12:19 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I see no chains either. :notsure:
  11. Jan 16, 2014 at 12:20 PM
    beeesmitty
    beeesmitty Well-Known Member
    NC
    11' SR5 DC BSP 4X4
    265/75/16 Cooper ATP, TRD FJ Trails, 5100's @ 2.75, ReadyLift 2" Blocks
  12. Jan 16, 2014 at 12:46 PM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    Don't think your supposed to run them in front!
  13. Jan 16, 2014 at 12:50 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    There isn 't enough room up front
  14. Jan 16, 2014 at 12:58 PM
    evan
    evan Well-Known Member
    SK, Canada
    I used to drive a 3 ton flat deck and it was horrible in snow when empty. I had chains but never actually installed them. I would just lay them out in front of the tires where I needed traction.
  15. Jan 16, 2014 at 12:58 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    i run chains up front and back
    otherwise the back tires, that have tons of traction, do a really awesome job of pushing your tractionless steering tires straight into a ditch, when you're dealing with ice
    ...but, i probably have room, cause i do this ultra strange thing
    ... ...you guys ready?
    i don't run oversize tires :eek::eek::eek::eek::eek::eek:
  16. Jan 16, 2014 at 1:55 PM
    OZ-T
    Peter North
    British Columbia
    My tires are only 10mm wider than stock , so they only reduced the clearance to the UCA etc by 5mm or 1/4" , I don't see how chains would fit in there , probably why the manual says to only run chains in the rears
  17. Jan 16, 2014 at 1:59 PM
    flatblack
    CDA
    the manual also tells you what size tires to use...
    you using them?
    brizower likes this.
  18. Jan 16, 2014 at 2:01 PM
    OZ-T
    Peter North
    British Columbia
    I'm not running stock tires anymore as I just stated
  19. Jan 16, 2014 at 2:02 PM
    flatblack
    CDA
    exactly... so, apparently what the manual tells you to do isn't final word with you
  20. Jan 16, 2014 at 2:04 PM
    evan
    SK, Canada
