Snow Chains
Discussion in 'Wheels & Tires' started by thegreatsam, Mar 26, 2010.
  1. Mar 26, 2010 at 8:18 AM
    thegreatsam
    thegreatsam [OP] Well-Known Member
    Sam
    Vancouver, WA
    06 Double Cab TRD Off-Road
    2 Weeks ago I purchased my first truck, a 2006 Tacoma Double Cab. I've never owned a truck, let alone anything with 4x4 capability.
    Next week I'm headed up to the mountain for some spring snowboarding (16"+ of snow this week, another 10"+ forecast by Tuesday!). I'll be picking up chains for the new truck Monday. I've always believed in at least carrying chains when headed through the passes, regardless if I think I'm going to use them or not. Better to have and not need then need and not have.
    My question is, if I do need to chain up for whatever reason, where should they go? I know for 2wd drive only trucks they say to install them on the rears, but if I throw my truck in 4wd, should they go on the front or the rears?
    The chances of me needing them are small, but I'd still like to go to the mountain prepared.
    Thanks!
  2. Mar 26, 2010 at 8:24 AM
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    Unless your tires are completely bald, you'll never need chains on your 4x4. Halfway decent tread and weight in the bed will get you anywhere you need to go.
  3. Mar 26, 2010 at 11:58 AM
    thegreatsam
    Sam
    Vancouver, WA
    Well, I'm hoping I *don't* need them, and I probably won't, I just thought it would be useful to know on the off chance I do.
  4. Mar 26, 2010 at 12:05 PM
    DOERanger
    DOERanger Well-Known Member
    Jordan
    Knoxville, TN
    2010 DC Sport SB
    No Mudflaps, Fog lights on all the time, Map light/Dome light mod, Door sill protectors, In-channel window guards, Re-badged and sock-monkeyed,many more to come.
    Are they chains or the cables? Have you increased the clearance on the front wheel wells?
  5. Mar 26, 2010 at 12:10 PM
    BSPDX
    BSPDX Well-Known Member
    You won't need them... I live at the base of the mountain and have never chained my taco... But, since you feel the need to be on the safe side which is completely fine since your kinda new to trucks its IMHO a good idea. on 4wd rigs you will want to chain up the fronts first and the rears second. if you have only one set of chains they should go on the front. Good luck & enjoy!
  6. Mar 26, 2010 at 12:11 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Snow? Whats that?? :notsure:
  7. Mar 26, 2010 at 1:53 PM
    thegreatsam
    Sam
    Vancouver, WA
    Ahh, thanks. I'm pretty comfortable driving in snow, been up every week since Christmas with my little 2wd Integra, chaining about half the time, but I wasn't sure which end to chain up on the truck if I ran into trouble.
    Thanks again!
  8. Mar 26, 2010 at 1:56 PM
    thegreatsam
    Sam
    Vancouver, WA
    I had planned on picking up chains Monday just as a precaution. The tires the guy has on are 265/75/16 BFG AT's, and its running at stock height....is there a clearance issue with chains?
  9. Mar 26, 2010 at 2:00 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Are you sure about this, I think you should put chains on the back first before the front, even if It's 4wd. I'm not an expert with driving a 4wd in the snow, but I guess you know something I don't?
    But yes you shouldn't need to use the chains if you have a 4wd, but it may be a good idea to have them anyways, because some states require that you have them with you anyways.
  10. Mar 26, 2010 at 2:01 PM
    BSPDX
    you should be fine... cables are a smoother ride, but with a 4wd you will only chain up if traction is severely needed and in that case I would get chains. The clearence difference between chains and cables is very minimal and you shouldn't have any issues with either choice.
  11. Mar 26, 2010 at 2:02 PM
    BSPDX
    I'm positive! you want the chains on your steering tires first.
  12. Mar 26, 2010 at 2:13 PM
    thegreatsam
    Sam
    Vancouver, WA
  13. Mar 26, 2010 at 8:01 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I usually chain up the rears If need be. But I haven't had too yet this year. :)
    OH... And hi neighbor! I see your in the same area as me. I was ganna go up tomarrow also....(maybe)
  14. Sep 26, 2010 at 7:23 AM
    Black Hills Tony
    Black Hills Tony Active Member
    Joseph, Or
    03 TRD 4WD
    Chains in the front are pretty awesome because they can chomp through thick crusty snow. Be careful though, the owners manual for my 2003 taco says "do not use tire chains on the front tires" (page 275). I'm guessing it's a clearance issue between the tire and the frame when the wheels are turned.
    It's a good idea to practice putting them on before you need them. Maybe when you are practicing, you can try them on the front.
  15. Sep 27, 2010 at 4:04 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Put the chains on your rear wheels :thumbsup:
  16. Sep 27, 2010 at 1:31 PM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    Total BS :). Went to Goat Mountain, I put chains on front and back and ran circles around a guy with 285 Mud Terrains, 3 passengers, and gear. I also had very little experience in comparison to him. I could creep down the hill while he had ABS yelling at him the whole time, and I could take off safer.
    Went again with Mountainwolfpup to Mt Hood. I led the crew, so I had to do all the plowing. We got to the point where we had to turn around, and he had to winch and dig with a shovel. I had some digging, but drove it all.
    Like Bill Burke says, 4 tires, 4 chains.
    In back, you can get going, but have no grip to steer.
    In front, you can steer, but can't really get started... or you have your butt slide around.
    Chains on front might be difficult or impossible depending on setup. The stock UCA is really close to the inner sidewall, among other stuff in that area where a chain could hang up. I've successfully ran Les Schwabs on the stock setup, but they are real tight and I did bend a corner of the belly pan (which was already bent and asking for it).
    Burke and a lot of guys recommend RUD chains, but I think they are real spendy if I remember.
  17. Sep 29, 2010 at 12:56 PM
    chrisx1
    chrisx1 Well-Known Member
    NE Missouri
    95 4cyl 4x4 5sp
    15x8 Pro Comp Wheels w/4" backspacing, 31x10.50 Mickey Thompson MTZ's, Bilstein 5100's set to 2.5", URD Short Throw Shifter kit, URD rear O2 sensor simulator
    Another vote for the front if you only have one set. Steering and stopping are way more important than starting.
    I have driven 4x4's all my life (I'm 40), and never owned more than one pair/set of chains for my truck. When the need arises - throw them on the front and watch everyone else spin.
    All that said, you need to practice putting them on in the garage or on a flat dry surface as said above. You also need to make sure they are on the tire TIGHTLY! Any flopping parts will grab your brake/suspension/inner fender parts and the result will be bad.
    Also stop and visually inspect the inside of the wheel every so often. Make certain that everything is tight.
    Bungee straps across the outside of the tire in an "X" pattern help to keep the inside tight against the tire.
    Now it is also my opinion that you should avoiding chains/cables if at all possible due to the chances of tearing something up. :D
  18. Sep 29, 2010 at 1:30 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    The manual says to chain up the rear on my 07 Offroad. The upper control arm's are so close to the tires up front it seems it would be impossible to run chains on a stock set-up. I think you'd be better off getting a good set of winter traction tires.
  19. Sep 30, 2010 at 1:22 PM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    you boys need to grow up and smell the asphalt chains go on the rear!!!!!!!!!!!!
