snow taco's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by borgieman, Dec 14, 2016.
  1. Dec 14, 2016 at 2:46 PM
    borgieman
    borgieman [OP] Member
    I have a '10 taco w/ 3"lift. im running on 285/70/17 toyo tires. this past snowfall,about 2", i couldn't stop sliding,even in 4/4. is this typical of all tacomas,being that there light, or do my tires just suck?
  2. Dec 14, 2016 at 2:47 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    throw some sandbags in the back and try it again
    Woundedyak and Hairy Taco like this.
  3. Dec 14, 2016 at 3:51 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Snow, or ice? I've never had any issues with my Tacoma or any other vehicle in snow. Ice is another story and you'll often have a layer of ice with snow on top and not realize the difference. Chains are really needed for icy conditions. But tires do matter. Generally speaking wider tires, and tires with a mud tread suck in snow covered pavement. A narrower tire with an All Terrain tread does best in those conditions. Now really deep snow acts more like mud and a mud tire may be helpful
  4. Dec 14, 2016 at 3:53 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Weight in the bed does help some. Still, on ice, 4X4 basically means squat. It helps in snow, though.
  5. Dec 14, 2016 at 3:54 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    TOYO MTs or ATs. MTs are dangerous on ice. Ask me how I know?
    Kyitty likes this.
  6. Dec 14, 2016 at 3:55 PM
    WarrenG
    WarrenG Well-Known Member
    I had toyo at2's, the flat out suck in winter...
    Mush Mouse likes this.
  7. Dec 14, 2016 at 3:58 PM
    Mademan925
    Nick
    Discovery Bay, CA
    I have Goodyear MTRs. They are terrible on ice but I got them siped and let some air out and they have been much better. They still suck though. I like driving my wifes all wheel drive jeep with ATs in the snow much more then my truck
  8. Dec 14, 2016 at 4:03 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    I had the original Toyo AT on a previous truck. Great highway tire, got 65k out of a set on a heavy Suburban. Absolutely worthless in the snow or off the pavement. I would have thought they would have made the AT2's better. I wouldn't know since the only place to get Toyo's in Oregon is Les Schwab's and I wouldn't take my truck for their incompetent tech's to screw up or damage.
    I've been very happy with my BFG KO2's. I've only slid when I've wanted to ;) I do have about 300lbs extra in the bed with the canopy and winter gear.
    I would try airing down if your tires are otherwise good.
    TacomaTrav and Skrain like this.
  9. Dec 14, 2016 at 4:11 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Sandbags and proper winter tires will make a world of difference.
    Plain Jane Taco likes this.
  10. Dec 14, 2016 at 4:11 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Fat tires and no weight bad combo. I have a dully Dodge with really good tires it is rear drive with limited slip it will not even move in slick weather! No problem with stock size snow tires (picture of a mountain on the side wall) and 4WD with the Taco.
  11. Dec 14, 2016 at 4:14 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    When I'm in 4x4 I don't slide around on icy packed roads with my Cooper ST Maxx. In 2WD the rear can slide a bit since there's no weight back there.
    What kind of "Toyo" tires? Street tires? Off-Road? Winter?
  12. Dec 14, 2016 at 7:09 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I'd say it's your tires.
  13. Dec 14, 2016 at 7:35 PM
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    Ya, that is what I'm thinking too.
    This is my first winter in my Taco. Only had it in snow a couple times so far and it's been pretty good. But I'm running Dynapro A/Ts, stock size.
  14. Dec 14, 2016 at 8:17 PM
    Tacomagirl76
    Tacomagirl76 REG. CABS RULE!
    Some where in New England!
    2014tacoma reg cab
    Duratra wrangler tires,tinted windows,kicker rear speakers,JL Audio front,fosgate amp. More to come
    Mine does great in snow. It's all about the tires
  15. Dec 14, 2016 at 8:38 PM
    Pigpen
    Dan
    Northwest Montana
    Tires
    No vehicle does well in snow without good tires. AT tires are decent in all terrain types. Snow tires really do work well in snow.
    My Taco kills it in the snow, on and off road.
    Plain Jane Taco and TacomaTrav like this.
  16. Dec 15, 2016 at 3:25 AM
    MonkeyWrench462
    MonkeyWrench462 Well-Known Member
    Christopher
    Minnesota
    2013 Tacoma TRD
    K&N Air Filter, Supreme Suspension 3" Lift, Daughters First Pair of vans from Mirror
    How do you know????????
    AJH387 likes this.
  17. Dec 15, 2016 at 3:46 AM
    gearcruncher
    Canadain bumper technician
    Spend some time at one of the multiple " snow tire threads "
    I use studded Good year WRT ice tires that had a good rating a few years ago and they work amazing on snow and ice even with this very lightweight truck . Maybe a studded tire is overkill depending where you live but for me and my 8 months of winter driving , it made sense to go with as much traction and braking available at the time .
    There are better winter tires available now .
    Here is one of the winter tire threads https://www.tacomaworld.com/threads/winter-tires.396277/
    timbobzimbob likes this.
  18. Dec 15, 2016 at 8:29 AM
    tgear.shead
    tgear.shead Well-Known Member
    Ok, so your truck came from the factory with either 245 or 265 tires. You changed them out to 285 and raised the center of gravity, and you are seriously asking if they all drive the same? Of course not. When you alter that kind of characteristic, it IS GOING TO CHANGE HOW IT BEHAVES!!!
    Which I would presume was the POINT of making changes. After all, why change something if it doesn't... you know... CHANGE something.
    So here is the thing with tires; picking a tire is a tradeoff. Big wide tires are good for MUD AND SAND -- things that may not have a BOTTOM, so you need to float up to the top as much as possible. In the snow, you need something entirely different. Under the snow, you have a hard surface, typically PAVEMENT. To maximize traction, you need to get past the snow and stick that tire right against the hard surface below it, so you need the exact OPPOSITE of what does well in mud and sand. You need NARROW tires. The NARROWER the tire, the more it is able to dig its way past the snow and get good traction on the hard surface below it.
    Now since you obviously want the wider tires for warm weather, seems to me that you would be best off with a set of dedicated winter tires. Aim for something nice and narrow, like 235's. Maybe even 225's.
    Also, the lift isn't doing you any favors in the snow. Low is stable.
  19. Dec 15, 2016 at 8:36 AM
    Mademan925
    Nick
    Discovery Bay, CA
    So it snowed heavy christmas eve December of 2014. The snow plows were not up and running on the little streets. The cars were still driving on the roads and compacting the snow. Christmas was cold and the snow turned to ice. I made this same turn multiple times on both those days. The next morning however I was in 4hi chatting with my wife driving slow and safe. I started to make the right turn. Almost a down hill U turn onto the street my inlaws live on. The snow had still not been plowed.
    The turn is the purple pin
    Photos of the turn the next day saturday.
    Looks like some one did the same thing Saturday
    I started the turn like normal but the truck quickly decided to ignore my turning and braking. Even though I was going slow I hit a post (an older post) that was rotted on the bottom and broke upon contact with my relentless bumper. We started going over the edge and I thought for a moment. This is it.
    The cable had been cut when they replaced the two new posts on the end and instead of sinking a new cable in the ground they Ubolted the two cabels pieces together. This did not hold so the post just fell over. The saving grace was my truck was completely sideways and I hit a new post on the side of my truck that held us in place.
    I was looking over the edge in shock. It happed so slow it felt unreal. Like this cant be happening. The ABS brake system would not let the tires stop.
    My wife quickly snapped me in gear and said what do we need to do. I handed her my phone and said take pictures Ill grab the recovery gear. I couldn't back up because the post was resting against the side of my truck. I ran the winch to a tree across the road but this did not work as the back end if the truck started going down the hill while the front went up. I grabbed the snatch block given to me by my TW secret santa and ran the cable back to my slider. Once I was off the post. I had the wife spin the wheel in reverse while I winched sideways. This seemed to have the best result.
    The good news is we were safe. My $250 diductible is nothing and the body will be fixed. I had to make the same turn several more times this weekend. What did I learn? 40 PSI is too high. A nice 30 in the mountains helps. Using my gears to brake gives me much more control. It was an experience that will be with me for a long time.
    sawjai526 likes this.
  20. Dec 15, 2016 at 9:02 AM
    Hairy Taco
    North of Hell
    08 TRD
    Yikes! Glad it didn't turn out for the worse.
