Winter Tires.
Discussion in 'Wheels & Tires' started by SNOWTRD, Oct 17, 2015.
  1. Oct 17, 2015 at 6:13 AM
    SNOWTRD
    SNOWTRD [OP] Member
    Victoriaville
    2016 TRD Off Road QuickSand
    None (Its just fine!)
    Hi guys,
    Will Pick up this one on Monday. Far from the desert as you can see with the snow cover on the Tacoma!
    Does anyone had already switch to winter tires size P265/65R17 yet ?
    Looking for any comments on best set of tires for icy roads.
    Regards,
    big_jarv and EB Group like this.
  2. Oct 17, 2015 at 6:32 AM
    CoastieLT
    CoastieLT Well-Known Member
    Virginia
    I would consider the Cooper A/TW tires, particularly if you are looking for something to leave on year round.
    nv529, JADaus and TRDPro4x4 like this.
  3. Oct 17, 2015 at 6:49 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    4wd button
    Chad7088, Hoff, BSFord and 4 others like this.
  4. Oct 17, 2015 at 6:54 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Nothing better thant real snow rated tire! I bought a couple set of Toyo GO-2 for my previous vehicule and now bought a the new gen Toyo Observe GS-i5 and I am very happy with it on snow and ice.
    NMBruce, over60, BSFord and 2 others like this.
  5. Oct 17, 2015 at 7:10 AM
    BigWig
    BigWig Active Member
    2012 base tacoma
    Nokians for absolute sure...I took my Tacoma everywhere last winter and didn't slip once. Studs would have made it unstoppable and really really stoppable (in a good way)
    Dagosa likes this.
  6. Oct 17, 2015 at 8:27 AM
    tacofan13
    tacofan13 Well-Known Member
    JR
    2017 Quicksand DCSB 4X4
    I like General Altimax especially when they go on sale. I bought 16 inch steel wheels and got 245-75-16. Where are you by the way?
    tomwil and Dagosa like this.
  7. Oct 17, 2015 at 8:37 AM
    Kemosabe
    Louis
    Agree on Nokians! Forgot about those!
  8. Oct 17, 2015 at 8:37 AM
    kendrickdlr
    kendrickdlr Well-Known Member
    Kendrick
    2004 Black V8 4Runner 4WD
    According to TireRack and Consumer Reports, Bridgestone Blizzaks are the way to go.
    BSFord, kgilly, mudnrox and 4 others like this.
  9. Oct 17, 2015 at 8:38 AM
    pghmtnbiker
    pghmtnbiker Well-Known Member
    Jon
    Pittsburgh, PA
    2016 Tacoma Access Cab Off Road Super White
    DoorDing likes this.
  10. Oct 17, 2015 at 9:08 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    A lot of great tires mentioned. Most are right. Winter tires have softer rubber which is better on icy roads. Good AT tires can handle snow, but only winter tires can do decently on ice. I have found that nearly all the name brand winter tires have very good winter performance.
    The difference in price is how the better ones ride and handle and are quieter on dry pavement. If you can put up with the slight loss in dry road performance, the Altimax are excellent bang for the buck. Unless you live or travel regularly on dirt roads which stay icy all winter, I would not mess with studs. Studs compromise dry road handling too much to make it worth while unless you really need them and are prepared to drive much slower on paved roads.
    Otherwise, in one year you can render studs practically useless if you do a lot of high speed driving. Stopping distance, cornering, noise and just about everything on dry paved roads is compromised with studs.
  11. Oct 17, 2015 at 9:17 AM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    How does that help you stop and corner ?
    stealthmode, ronoc, Snowman and 3 others like this.
  12. Oct 17, 2015 at 9:24 AM
    pghmtnbiker
    Jon
    Pittsburgh, PA
    under 45 degrees Fahrenheit AT and summer tires harden up and their grip on road surfaces begins to be adversely affected. When temps drop below mid-40s you should be running winter tires. Don't wait for the snow.
    4WD has nothing to do with how the rubber reacts to the road surface. Don't listen to anyone who tells you differently.
  13. Oct 17, 2015 at 9:31 AM
    MQQSE
    MQQSE Chief Pal Guy
    Rob III
    Palmer, Alaska
    Cav Blu '19 DCSB OR MT
    This ... Been running nothing but them for 5 Winters, this will be my 6th. Ran studded for 8 Winters prior, primarily Nokians and Hankook. I wouldn't go back to studded for anything ... Well maybe if I drove solely on the ice road. ;)
    Dagosa and DoorDing like this.
  14. Oct 17, 2015 at 9:32 AM
    Red All Around
    Red All Around Active Member
    Brandon
    Utah
    05 DCLB 4WD
    Leer 100XR Topper shell, WeatherTechs, Heavy duty rear leaves, Bilstein 5100 rear shocks, Bushwacker fenders.
    I've ran the General Altimax's on previous cars in icy/snowy conditions; I was so impressed (never slipped or slid, even w/o studs) I'll gladly use them again.
    Dagosa and tomwil like this.
  15. Oct 17, 2015 at 9:41 AM
    MQQSE
    MQQSE Chief Pal Guy
    Rob III
    Palmer, Alaska
    I've had friends run both them and the Michelin X-ice with like results. Studless winter tire technology has made huge advances over the last ten years or so. :thumbsup:
  16. Oct 17, 2015 at 9:56 AM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Exactly right.
  17. Oct 17, 2015 at 11:06 AM
    SNOWTRD
    SNOWTRD [OP] Member
    Victoriaville
    Tanks for your opinions on winter tires. I already check a few of them.
    Pat
  18. Oct 17, 2015 at 11:15 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Because my state does not allow studs, one of the best snow tires I've had were Green Diamonds. They had diamond-hard silicium carbide granules embedded evenly throughout the tire's tread, giving the effect of having studs.
    Unfortunately, they are hard to obtain now, which is why I went with General Altimax Arctic.
  19. Oct 17, 2015 at 11:25 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    where did it snow already?
  20. Oct 17, 2015 at 11:41 AM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Price of diamonds has gone up......
