So educate me on the way these bushings and washers go.
Discussion in 'Suspension' started by raswank, Nov 1, 2010.
  1. Nov 1, 2010 at 10:01 AM
    raswank
    raswank [OP] Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Have the 5100 c clamp set 1.75. Then goes the coil spring plate. Now with the pictures attached explain the rest. 1 small rubber bushing with 1 small silver washer. 1 big rubber bushing with 1 big silver washer. How do those go?
  2. Nov 1, 2010 at 10:02 AM
    raswank
    Rick
    Auburn,Ma
    The 2 washers have grooves on one side. Is there a certain way the get placed on? Thanks for any help.
  3. Nov 1, 2010 at 10:06 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    You put that one on first. Then the next one. After that you get the other and finally the one you havent used yet is last. Hope that helps.
  4. Nov 1, 2010 at 10:30 AM
    raswank
    Rick
    Auburn,Ma
    Thanks for the quick response but that really does not help. The small bushing has 1 flat side, and the other side has a raised ring on it. So does the ring face up or down? Then the small washer looks like a tea cup saucer. Does it get tipped over or stay up like a saucer? Now the big bushing is flat on both sides. Now the other bigger silver washer is like a tea cup saucer as well. Does that get tipped over or stay upright. And actual picture would be great.
  5. Nov 1, 2010 at 10:32 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I was only kidding. I didn't expect that to help. Let me try to find a picture.
  6. Nov 1, 2010 at 10:37 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
  7. Nov 1, 2010 at 11:09 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 285 x 70 x 17 Toyo Tires on 17" x 8" ICON Wheels
    The spring seat on that shock is installed upside down. Make sure you flip that over. And the smaller bushing/washer should go under the top plate, and the large ones on top.
  8. Nov 1, 2010 at 11:16 AM
    raswank
    Rick
    Auburn,Ma
    that is great except there are 2 rubber bushings that only shows one. do you need to use the black long plastic piece on the shock as well
  9. Nov 1, 2010 at 2:03 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I don't remember mine having two bushing pieces...maybe one of those is part of the black dust cover?! I have the dust cover on mine. The spring perch is def upside down. If you turn it around you'll notice a recess in it that slides over the c-clip. The part where the end of the spring sits is to face the rear of the truck FYI. Hope this helps...
