So how bad is the ride without the leaf spring TSB fix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vikinglord, Oct 20, 2012.
  1. Oct 20, 2012 at 6:50 PM
    Vikinglord
    Vikinglord [OP] Active Member
    Michael
    Nashville
    Gold Prerunner
    Hey gang. I was reading the towing bible, which lead me to several post concerning the rough ride when loaded TSB. I bought this truck used from a guy who was meticulous with the service, but did not get the leaf springs\shocks changed. I checked and there are only 3 leafs on each rear spring assembly.
    The truck is way out of warranty, so I doubt screaming to Toyota at this point will not do much good. I checked prices and it is over $500.00 a side for just the springs.
    I will be pulling a trailer that will have a total weight around 4000lbs. I am going to put on a tranny cooler, but I am wondering how bad the ride really is without the TSB fix? Anyone got experience with this?
    Thanks as always
  2. Oct 20, 2012 at 6:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I used to haul a 400 lb sport bike before I got the TSB and I bottomed out hard on every little bump in the road. With heavier loads, the truck would just sit on the bump stops.
  3. Oct 20, 2012 at 6:58 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    You'll probably want to get it since you'll be towing so much weight. I've never towed without the extra leaf, so I can't testify to that, but I hear it's pretty bad.
  4. Oct 20, 2012 at 7:01 PM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    where are you buying at 500 a side?
    alcan leafs can make you an awesome set of custom leafsprings for 650, mine are 7 leaf and they are awesome... i got 5inches of lift and pull an 18hp kubota probly close to 3000lb and it squats maybe an inch
  5. Oct 20, 2012 at 7:02 PM
    Pugga
    Massachusetts
    Screw the TSB, it's not that much better for towing and hauling. Alcan can make you a custom leaf pack for a little over $500 total, both sides. Check out their website. Another good option would be a set of air bags. For variable loading requirements, the air bags aren't a bad option at all.
  6. Oct 21, 2012 at 7:56 PM
    Vikinglord
    Michael
    Nashville
    Gold Prerunner
    Thanks everyone. I will not have anything in the bed of the truck, just the trailer. But the tongue weight I imagine will play into the leaf springs. I will contact Alcan Spring. About how much does a shop charge to put swap them out?
  7. Oct 23, 2012 at 4:11 AM
    zacksblacktaco
    west virginia
    06 trd sport access
    probly around a 100 bucks, i wouldnt pay anymore than that.
    if you know anyone that has a body lift, i would ask them
  8. Oct 23, 2012 at 6:02 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Personally, I'd hook it up and go for a drive first to find out if I needed an upgrade or not. You've already siad it above, but it all depends on the tongue weight you end up with. The stockers may end up being fine. Find out _if_ it needs an upgrade first.
  9. Oct 23, 2012 at 8:40 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    If you bought a Tacoma for any use beyond fashion accessory, you need new springs.
  10. Oct 23, 2012 at 8:49 AM
    acdronin
    acdronin Well-Known Member
    Ditto on the airbags, it's really cost effective, pretty easy to install and allows you the options to tailor the stiffness to the load when you need it and deflate them when you don't. I don't have a compressor, I just ran the stems to either side of the 7 pin, drilled right through the plate, I keep a bicycle pump in the truck for this purpose. Unloaded I run around 10lbs, loaded I've gone up to the limit on the bags which is 125lbs, you won't believe how stiff that is.
  11. Mar 2, 2013 at 8:31 PM
    Dantwenty2
    Dantwenty2 Well-Known Member
    Saugus, CA
    2009 TRD OFF-ROAD DCSB
    Fox 2.0 coilovers, yellow fogs, Peltyfry bed light bar with Rigid Duallys.
    How do we get the TSB leafs? Don't mean to jack the thread, but if someone could PM this info I would appreciate it. I haul an 18ft boat and a trailer loaded with 3 dirt bikes, a quad, and tons of camping gear. Thanks!
  12. Mar 2, 2013 at 8:38 PM
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    If your vehicle is still under warranty, take it to a Toyota dealership. I've heard stories of people having trouble getting warranty work done, but I went in for the squeaky blower motor TSB fix and they had no issue doing the fix that day.
  13. Mar 2, 2013 at 8:47 PM
    Dantwenty2
    Saugus, CA
    Thank you for the quick reply Jux. My 09 is still under warranty since I purchased the extended warranty when I bought the truck. Now I just have to figure out which Fox shocks to get for the rear and possibly an AAL. THANKS!
  14. Mar 2, 2013 at 9:00 PM
    TexasCub
    TexasCub Well-Known Member
    2013 PreRunner
    AIR BAGS!
  15. Mar 3, 2013 at 3:58 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    AIR BAGS! Firestone RideRites, easy self install. Better end result. For me it was one of those things I should have done along time ago.
  16. Mar 3, 2013 at 4:19 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  17. Mar 3, 2013 at 6:05 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    the leaf spring tsb is usually only covered under the 3year/36k mile coverage but it doesn't hurt to try.
  18. Mar 3, 2013 at 6:51 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The key word is harsh ride that may help but it is a tab not a recall.
  19. Mar 4, 2013 at 4:39 AM
    Dantwenty2
    Saugus, CA
    Hopefully the 100k warranty I purchased will make things easier...
