So I broke a TPMS
Discussion in 'Wheels & Tires' started by whitedlite, Sep 4, 2018.
  1. Sep 4, 2018 at 9:10 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    The Denso's work with our trucks but they need to be programed into the ECU to work there is a 7 digit code that needs to be programed. You can use tech steam or and autell to reprogram.
    It also does not matter if you mix the different sensors, as long as the sensor is the right type.
    Also watch as they are different for alloy and steel wheel.
  2. Sep 4, 2018 at 9:11 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I’d like to know this also. I want to run two spares w tpms installed to keep all six in a rotation. Wondering if problems like this will arise...
  3. Sep 4, 2018 at 9:14 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    You can run two spares but you will need a sensor that can be cloned. This way your two spares will have the same 7 digit code, as the ECU can only hold 4-5 different codes depending on year. I have a 2015 it only has 4 slots for the code, no spare.
    This is how people run two sets of rims.
  4. Sep 4, 2018 at 9:17 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    I’ll get info for you and @Hobbs tomorrow :)
    Hobbs and Rujack[QUOTED] like this.
  5. Sep 4, 2018 at 9:17 PM
    Rujack
    Thanks - that’d be awesome
  6. Sep 4, 2018 at 9:21 PM
    Rujack
    Are the oem sensors clone-able?
  7. Sep 4, 2018 at 9:28 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    The Oem sensors are Pacific. They look EXACTLY like the Denso sensors, I am almost 100% sure they are made by Denso. The OEM are not sensors are not clone-able as far as I know, neither are the Denso's.
  8. Sep 4, 2018 at 9:41 PM
    Rujack
    So I’d have to replace all my sensors?
    Or, I could just get oem ones and have a tire shop scan them right? Not a huge deal if it’ll work.
  9. Sep 4, 2018 at 9:46 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    You could just get a clone-able/programable sensor for your 2nd spare. You would need someone with an autell or similar programing tool to scan your 1st spare and program the sensor for the 2nd spare to the same 7 digit code.
    If you wanted to run a second set of rims you would put 4 programable sensors in the second set of rims have the sensors clone your factory rims 7 digit ID. Then the ECU would never know the difference.
  10. Sep 4, 2018 at 10:10 PM
    whitedlite
    whitedlite [OP] Well-Known Member
    USA!
    3RD Gen TRD 4WD
    This thread turned very knowledgable. Thanks @arcenik
  11. Sep 4, 2018 at 10:19 PM
    Rujack
    I thought it was earlier stated that cloneable sensors wouldn’t work along side oe sensors...
  12. Sep 4, 2018 at 10:27 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I currently have 1 VDO redi-sensor and 3 stock sensors in my truck. Maybe they were not doing it right. It would not make sense to have to change all the sensors when one goes bad.
  13. Sep 5, 2018 at 7:56 AM
    Rujack
    Well I totally hijacked this thread, so I’ll start a new one more to this topic specifically. Thx for the input!
  14. Sep 5, 2018 at 8:30 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    my questions were answered already, i'm happy. continue on. I'm just in the back reading.
  15. Sep 5, 2018 at 8:39 AM
    #35
    Rujack
