So, I decided to seafoam my old 96 with almost 200,000 miles on it...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taylor, May 2, 2013.
  1. May 2, 2013 at 7:19 PM
    Taylor
    Taylor [OP] Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    The results were a bit more dramatic than I thought. It's the 2.4 liter.
    I was expecting lots of white smoke, not SOOT. You can see the grass was already black from the initial seafoam introduction. Some actual black pieces came out.
    I seafoamed my current 03 3.4 liter and there was not an ounce of smoke.
    http://www.youtube.com/watch?v=d6sZy4MYNy0
    Safe to say that the cat is screwed, or at least its life has been shortened.
    I have no idea how to embed this video...
  2. May 2, 2013 at 8:05 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I'm thinking on sea foam my 2002 with almost 150K. During its life I've used nothing but Chevron and Shell gas and synthetic oil. Also added FP60 and FP60 Plus every fill up. It helps to lubercate the fuel system, intake valves and upper cylinders. No oil burning, gas mileage isn't bad considering I'm running 265/75R16's.
  3. May 2, 2013 at 8:23 PM
    shift96
    shift96 Well-Known Member
    that was a great idea..
  4. May 2, 2013 at 8:26 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
  5. May 2, 2013 at 8:29 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Im so conflicted on this......My truck has 58k on it, but its a 2005. Its just running really sluggish lately and seems like it needs a good cleaning. Im afraid to seafoam a 8 year old truck even though the miles are low
  6. May 2, 2013 at 8:34 PM
    MEDICDUDE423
    MEDICDUDE423 Well-Known Member
    East TN
    03 Tacoma Limited X-Cab 4WD
    what is FP60?
  7. May 2, 2013 at 8:35 PM
    NW4RUNNER
    NW4RUNNER Well-Known Member
    4 runner trail
  8. May 2, 2013 at 9:32 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    It runs great! Seafoam brought down my idle, and it idles smoother. A little more power, but barely noticeable.
  9. May 2, 2013 at 9:35 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    same thing I was thinking.........I wasnt sure but I was gunna suggest changing them.
    clean ur MAF sensor and throttle body first..............see if that helps before u resort to seafoam......also ur about due for new plugs, make sure to gap them....dont listen to the "they are pregapped" crap....better safe than sorry.
    use oem denso, chris4x4 has a good writeup btw.
  10. May 2, 2013 at 9:44 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    Yeah I was planning on cleaning the throttle body and maf since my intake will be off tomorrow anyways. The plugs only have 13k on them but yeah they are for sure denso and I gapped them haha! The throttle body was cleaned when I last changed the plugs but we just had a couple desert trips so might as well do it now
  11. May 3, 2013 at 12:08 AM
    gnstalodz
    gnstalodz Well-Known Member
    ca, bayarea
    02 PreRunner Doublecab
    I have to research what seafoam really does. I have a 02 with 160K.
  12. May 3, 2013 at 5:50 AM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I think it can wait. It's not road worthy, has no tags, and no insurance and won't for a while. I'm the only person around here who takes the effort to work on stuff, so I'm sure it'll be there a while. It's not even really my truck anymore. I'll try to change them before my dad decides to make it road worthy.
  13. May 3, 2013 at 6:05 AM
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    When you say sea foamed it, what exactly did you do or how much and where did you add it? I've added it twice but I added 1 oz to 1 gal and didn't get any smoke. I have 63,000 miles
  14. May 3, 2013 at 6:56 AM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    People are going to say use the brake booster, but don't.
    Take the air intake tube off before the throttle body. Buy a can of the SPRAY seafoam and spray the seafoam onto or past the throttle plate while revving it. It's super simple and I don't see why more people don't do it this way.
  15. May 3, 2013 at 1:02 PM
    ARB1977
    North Texas
    It's a fuel additive you add to the gas. It's made by lube control.
  16. May 3, 2013 at 1:05 PM
    ARB1977
    North Texas
    Or you can suck it up through the pcv hose after the throttle body.
  17. May 3, 2013 at 1:11 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I've used seafoam in all of my vehicles except my tacoma (only have 26k on this one). Usually when I do it, I drive it around for a little bit after it quits smoking then change the oil, filter and plugs. I've never had any issues with it or anything it seems like it brings a little life back especially on some of my higher mileage cars. I had a crx with 330k miles and used it on it. I wish I recorded it, I smoked up the whole neighborhood.
  18. May 3, 2013 at 1:17 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    did it on my 01 xterra with 130,xxx on her. yea she smoked like a mother! but afterwards ran like a champ and no adverse effects. drove her till 270,xxx+ and still never had anything go wrong. i put it in the fuel every 30,000 now.
  19. May 3, 2013 at 4:14 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Yeah, but I hate pulling those little hoses. Easier to tear than the big ones :D
  20. May 4, 2013 at 7:31 AM
    WThomas1250
    WThomas1250 Well-Known Member
    I have a question for you guys that have used Seafoam, do you HAVE to change the plugs right after you use Seafoam? My plugs were done less than 5K ago, but I've been considering Seafoam for my 3.4L as it's creeping up to 200K. A friend of mine said you don't have to but I've also heard that you do have to. Thanks!
