so i noticed this under the steering wheel...help plz
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Jun 6, 2008.
  1. Jun 6, 2008 at 12:13 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    anyone know if this thing is supposed to be attached to anything?
  2. Jun 6, 2008 at 2:55 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    That picture is far to horrible for me to even begin to know what I'm looking at.
  3. Jun 6, 2008 at 3:32 PM
    Marioso
    San diego Ca
    2.0 mp phone cam...its a plug
  4. Jun 6, 2008 at 3:47 PM
    Dcrooks84
    Dcrooks84 Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    Does everything work? Is there any place that you can fit it into? Automotive makers make male and females specific sizes so you really can't plug something in the wrong spot. My guess is there was probably some sort of an option you don't have that this particular wire would go to.
  5. Jun 6, 2008 at 4:00 PM
    tjdriscoll
    tjdriscoll Active Member
    07, Tacoma Std Cab, 2WD, 5-M, 2.7 L I4, Indigo
    OEM Foglights, iPod adapter, Bedlights-Underbody lights, more to come soon.
    it could be the connector for the radio controls on the steering wheel (that is if you don't have it already), my other thought it either the cruise control or the intermittent wipers
  6. Jun 6, 2008 at 4:24 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    are u sure its not the plug thats connected to the tmps reset button?
  7. Jun 6, 2008 at 4:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    LMAO! :D
  8. Jun 6, 2008 at 4:26 PM
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    do you have a tow package? it may be for your trailer brake controller the adapter plug should have came with the truck (i found mine in the glove box)
  9. Jun 6, 2008 at 4:30 PM
    Marioso
    San diego Ca
    i have a tow package and no radio controls
    whats tmps or whatever that was
  10. Jun 6, 2008 at 4:37 PM
    The_Hodge
    SC
    nvm...i dont think the 05's had tpms
  11. Jun 6, 2008 at 4:38 PM
    Marioso
    San diego Ca
    tire pressure? i dont know if mine has it but if it does maybe thats why it didnt turn on when i got a flat
  12. Jun 6, 2008 at 4:41 PM
    tjdriscoll
    i don't think the 05's had TPMS on any models. they started with the 06's. but since you don't have it, it's nothing to worry about.
    I still think that wire is for the steering wheel controls for the radio. some models have them, and others don't. (it depends on what kind of package your taco has)
  13. Jun 6, 2008 at 4:44 PM
    Marioso
    San diego Ca
    so stupid why they wouldnt get a sensor on the trucks retarded
  14. Jun 6, 2008 at 6:02 PM
    slackdaddy2001
    slackdaddy2001 Active Member
    07 Tacoma DoubleCab, SR5 Offroad Pkg.
    That is for your front left blinker!
  15. Jun 6, 2008 at 6:36 PM
    ae86coupe
    ae86coupe your worst nightmare
    Milpitas, CA
    MyWhiteSR5
    if you had and aftermarket alarm installed. that could be one of the wires..
  16. Jun 6, 2008 at 7:02 PM
    beehunt
    beehunt Well-Known Member
    Bay Area, Ca
    '08 TRD Sport Black Sand Pearl
    3in Level kit
    if you have the tow package SR5 i do believe that it is for the trailer breaks check your glove box and the other end of the connector is prob in there so you don't have to run wires if you get some trailer brakes down the line
  17. Jun 6, 2008 at 9:38 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    My '07 2.7/5spd reg cab PreRunner has the same plug/harness, I thought it might be the wires that SET uses to add the port under dash courtesy LED lamps, so I probed it with my Fluke and it had a very low voltage signal 3.5 volts or something on one lead, no power or continuity on the other, but had nothing to do with the interior lighting. Must be as others have said; a harness for an option that does not exist on some vehicles.
