So I wanted to get an opinion...
Discussion in '1st Gen. Tacomas (1995-2004)' started by AidenWolfLeVay, Nov 30, 2018.
  1. Nov 30, 2018 at 12:06 PM
    AidenWolfLeVay
    AidenWolfLeVay [OP] Member
    Aiden
    Deltona, Florida
    1997 Toyota Tacoma Xtracab 3.4L V6 DOHC 4x4
    External: None Internal: Floor mounted tablet holder
  2. Nov 30, 2018 at 1:43 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    The clutch you listed comes with a pressure plate. Why are you buying a second one?
  3. Dec 11, 2018 at 6:09 PM
    AidenWolfLeVay
    Aiden
    Deltona, Florida
    Not planning to buy two, just getting an opinion from others about which would be better.
  4. Dec 11, 2018 at 7:27 PM
    02hilux
    02hilux Paved roads not required
    Planet: EARTH
    The question you should ask yourself is, what do you see yourself doing with it? Purpose of use and built?
  5. Dec 12, 2018 at 12:24 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Clutch Aisin or Marlin Crawler
    Suspension depends on how your using the truck
  6. Dec 12, 2018 at 5:46 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2004 4x4 2.7L
    Aisin is a nogo. Uses too many plastic pieces and can cause a failure. Correct response is OEM, Marlin, Exedy.
  7. Dec 12, 2018 at 8:00 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    So Aisin is no longer OEM on the Tacoma`s after 2000 ??
    Just what plastic parts as there are none in my Brand New Clutch ??
  8. Dec 12, 2018 at 8:54 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    As others has said, to have an informed opinion on what suspension you should get, it really helps to know what type of driving you do, the terrain to drive it, your skill level, miles on the truck, do you want to lift it to fit bigger tires, etc...
    But just so you know, 4x4 Tacomas don't have struts. They are coilovers (a shock with a coil). I would hope that a company selling you truck parts should know that. That said, there are FAR better brands than Rancho...
    If your front shocks are worn out, you might as well get new rear ones, too.
  9. Dec 12, 2018 at 10:46 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
  10. Dec 12, 2018 at 11:30 AM
    jbrandt
    Justin
  11. Dec 12, 2018 at 11:36 AM
    Blue92
    Daniel
    North Carolina
    2004 4x4 2.7L
    Aftermarket Aisin and OEM Aisin are 2 different things. @Speedytech7 can explain better.
  12. Dec 12, 2018 at 11:47 AM
    Speedytech7
    ゼイン
    5520 E Sprague Ave, Spokane Valley, WA 99212
    93 80 Series LC & 96 Turbo V6 Taco 4WD
    I've done a mod or two
    An OEM Aisin clutch from the dealer is fine. The afyermarket Aisin clutches you can buy have plastic spring retainers in the clutch disc that are known for breaking and causing the spring to eject and jam everything up
  13. Dec 12, 2018 at 11:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    Ewwwww. That's just wrong.
    I think he meant you already have one on the truck. Most need a resurfacing, not replacement. Unless you are changing the diameter, weight, or have totally toasted the OE unit.
    Marie @HeadStrong Off-Road is a good call to make on suspension, when you can define your needs.
    :bananadance: :amen:
    :thumbsup:
  14. Dec 12, 2018 at 8:16 PM
    UnderFire
    UnderFire Well-Known Member
    LUK is my go-to for stock replacement clutches.
