So I'll be the idiot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sloppyjoe, Aug 12, 2010.
  1. Aug 12, 2010 at 6:15 AM
    sloppyjoe
    sloppyjoe [OP] They are more like guide lines.
    All Over
    Silver and simple
    Non
    I was at my shop last night and was changing the oil in the Tacoma, I had about 10 things going at the same time. I did not stop the last jug at the half mark so I actually put in 6qts of oil. What should I do? I dont want to try to drain just a bit out b/c if I cannot get the plug in I loose all the royal purple I just bought. I was thinking of just removing the oil filter and putting on a new one, that might get some of the oil out without loosing alot. What say you keepers of the Taco World! New Tacoma guy in need of (ass)istance, Thanks. JOE>
    P.s. if I am worrying for nothing you can tell me that too, I just do not want to harm my new truck.
  2. Aug 12, 2010 at 6:18 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    A half quart extra is not a huge deal, but I would try to get a little out. I would loosen the drain plug but not remove it. It should leak past at a rate you can control.
    If you take the filter off, you might indeed have to replace it if you damage it in the process.
    The last option I can think of is to get a clean bucket, drain it all and pour the proper amount back in.
  3. Aug 12, 2010 at 6:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    That
  4. Aug 12, 2010 at 6:21 AM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    no worries
  5. Aug 12, 2010 at 6:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What he said
  6. Aug 12, 2010 at 6:22 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    your good man, maybe loosen the filter a few times in the next week if you want just to let some out
  7. Aug 12, 2010 at 6:26 AM
    Hellmutt
    Hellmutt Well-Known Member
    Piqua, Ohio
    '08 SR5 TRDsport 4x4 DC
    sadly, I've only put Husky Liners in it thus far - tend to blow all my cash on my bikes and guitars.
    I would hook up a drain line to the filter basin and just crack the filter loose a bit -- keep your eye on the drain pan below and tighten the filter back up once it's lowered a 1/2 qt. -- I've done this before and this remedied the problem fairly simply.
  8. Aug 12, 2010 at 6:43 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Ehh, dig around the forum for oil change nightmares. What you did is nothing!
  9. Aug 12, 2010 at 7:35 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    Awesome I am going to trade out the oil filter. That should get rid of a quarter quart or so, I will not worry about that small of an amount, Thanks for all the quick replies. JOE>
  10. Aug 12, 2010 at 7:56 AM
    saumon
    saumon Well-Known Member
    Montreal, Qc, Canada
    2015 DC LB 4x4 SR5 SSM
    x2
    Some are known to have drained their AT in the process...
  11. Aug 12, 2010 at 12:07 PM
    sloppyjoe
    All Over
    Silver and simple
    Non
    I can see where that could happen. I have never seen that small of an oil pan I can see someone doing that. I mean I even looked twice to see what the crap was up under there. I ended up stopping by the Advanced auto to pick up a new filter, I figured that if I could get the amount that the filter holds out I would end up pretty safe. Once again Thanks to all who have replied to help me. JOE>
  12. Aug 12, 2010 at 12:12 PM
    oldsman71442
    oldsman71442 Well-Known Member
    Jeff
    oahu HI/ Redding CA
    10 DC 4x4 TRD Sport
    Why would you use royal purple? Just my $.02
  13. Aug 12, 2010 at 12:17 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  14. Aug 12, 2010 at 12:27 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    1/2 qt wont kill you...
    Just last week my buddies girl tried putting coolant in her car cause she was low (or at least thought she was). Yup right in the oil tank. Worst part was she drove it then to jiffy lube to ask what she should do... Dude just looked at her and shook his head.
    Needless to say its a goner.
  15. Aug 12, 2010 at 12:34 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    If it were me I'd definitely pull the plug and let some out. Too much oil I've heard can be just as bad as too little, but for different reasons.
    This would also be a good reason to go fumoto.
