So, my wife was doing donuts.....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thmaxxer, Dec 4, 2009.
  1. Dec 6, 2009 at 1:45 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    why?:confused:
  2. Dec 6, 2009 at 1:48 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    yeah i was thinking the same thing
  3. Dec 6, 2009 at 1:53 PM
    Yoytoda
    Roland
    completely stock
    anytime you hold the steering wheel against the lock hard, even when not doing donuts, is bad. The power steering is still trying to push and the stop isnt allowing it. My sister had a saab and she was talking to a friend at the mall while holding pressure on the wheel and it blew a line. The oil was all over the place and hit the exhaust and caught fire. the fire burned through the radiator and when the coolant hit the oil fire spread it all over and the car burned to the ground. i was standing there pretty helpless...
    Ever since then i wont even turn my wheels on dry pavement unless the truck is moving. Ex. when backing out a parking spot wheels cranked to the left...then i put in first and start rolling forward then turn to the right to drive on...
    OP replace PS pump and youll be fine
  4. Dec 6, 2009 at 5:20 PM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    so i could play in the snow
  5. Dec 6, 2009 at 6:09 PM
    Yoytoda
    Roland
    completely stock
    i was just saying because a 2wd is all you need for donuts and having a blast in parking lots.
  6. Dec 6, 2009 at 7:04 PM
    DaytonLax14
    Corey
    Ohio
    yeah i'll probably find some parking lots when it gets icey
  7. Dec 8, 2009 at 3:36 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I HATE weather guys
    Predicted 4" of snow... we got some cold rain. 50 miles north of here, they got like 10 inches.
  8. Dec 8, 2009 at 5:00 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Hell of a wife you got there, bud. My girlfriend is the same way. She's got spunk! She backs down to no one.
  9. Feb 16, 2010 at 7:42 AM
    BigRedTaco2004
    BigRedTaco2004 New Member
    Reston, VA
    04 XCab SR5 2.7L 4wd
    Ok, so I seem to have killed my P/S pump doing donuts in the snow as well.The pump started screaming and I lost power assist. I got a reman pump from Advance and installed/bled the system last night. I works great for the first few minutes of a cold start, but after that only has assist above 1500 - 1750 RPM. Did I kill the rack as well?
  10. Feb 16, 2010 at 7:46 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    i did the same thing no joke!!!
    put a pin hole in my rack and pinion and need to get it replaced but im to cheap....
    and burn out the pump!
    good stop leak and a new pump should fix the problem
