So Toyota is wussing out on the Engine, dang it. 270HP but add gearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shr133, Jun 19, 2015.
  1. Jul 8, 2015 at 9:02 AM
    #581
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Toyota doesn't use mulitport for "cleaning," that's just a bonus.
  2. Jul 8, 2015 at 8:01 PM
    #582
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    While I agree the 3.4 (5vz-fe) and 4.0 (1gr-fe) are great, proven reliable and robust engines;
    One can not simply forget the 3.slow (3vz-e) which was by every measure a POS.. barely enough nuts to drive, absolutely horrible reliability in comparison to ANY other toyota truck engine. And for icing on the cake its incredibly inefficient. .
    The 3.0 was a hack job. The 22re-t was a fill the gap engine. In the mid 80's the other small truck manufacturers caught toyota with their panties down... They introduced V6 engines to their trucks and toyota was not even close to ready to put a v6 in their truck. 86 and 87 got the 22re turbo to fill the gap because it was easy.. 88 the rushed POS 3vz-e was introduced. . 95 the 5vz finally replaced it, with the updates it was the engine they should have built.
    Fast forward to now and to me it looks like a similar situation. Toyota market share is threatened because they aren't ready with a new truck and they slap one together. Then they throw in some borrowed tech from other platforms and call it all new.
    This could turn out to be the best Tacoma yet, or it could be the next big failure!
    Just something I was thinking. .
  3. Jul 9, 2015 at 5:02 AM
    #583
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    The only truly effective way to clean them was to pull the intake manifold and use acetone or carb cleaner to soften the baked carbon, then scrape it off using a dentist's pick. It usually took 6-8 hours from start to finish. No thanks!!
  4. Jul 9, 2015 at 6:24 AM
    #584
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I didn't think the 3.0 was unreliable. Underpowered, sure. The bad rap comes from the auto trans blowing up all the time.
  5. Jul 9, 2015 at 6:52 AM
    #585
    Old School
    Old School You are ignoring covfefe by this member.
    3.0 had a lot of head/gasket problems!
  6. Jul 9, 2015 at 6:57 AM
    #586
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Never owned one :notsure:
  7. Jul 9, 2015 at 7:04 AM
    #587
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    My blown and seized 1989 3.0L 1 ton pickup with 128k disagrees with you.
  8. Jul 9, 2015 at 7:23 AM
    #588
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Well if it feels well enough to disagree with me, can't be that blown...
  9. Jul 9, 2015 at 7:32 AM
    #589
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Those had notoriously bad head gasket issues. Hell I think the recall ended not too long ago if it's still not going on.
    Mine had 130k or so on it when it went
  10. Jul 9, 2015 at 7:40 AM
    #590
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not arguing. Ive heard of the motor being a dog. Heard of the trans blowing. Never heard of a blown gasket except the motor Brent rebuilt. Never really cared about the 3.0 beyond that :notsure:
  11. Jul 9, 2015 at 8:22 AM
    #591
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Yes they did. My '95 Runner had the head gasket replaced before I bought it, and later on I had it compression checked, and I had a couple iffy cylinders. The engine was a dog on grades.
  12. Jul 9, 2015 at 8:57 AM
    #592
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    I'm going to sit back an laugh so hard if Toyota comes out with a completely different configuration than what has leaked. Watch 'em offer a Cummins with 1200 HP and 1700 ft/lbs....that gets 30 mpg's after you select the "Economy Mode" on the factory installed tuner....
    Watch it happen.
    shr133[OP] likes this.
  13. Jul 9, 2015 at 9:02 AM
    #593
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I wasn't aware Cummins made a V6...
    :D
    Looks like intakes might really help this engine compared to the naturally aspirated 4.0 L. I remember watching a youtube video not to long ago where a couple of jokers got 20 HP on a dyno out of an s2000 with an aftermarket dry filtered CAI. The guy who ran the dyno knew his shit and basically said the more baffles and hollows attached to the intake the more likely a CAI will streamline things and give some benefits. That is one big arse sound chamber to the left of the engine so I'm thinking that could mean CAI's will be helpful to this setup.
  14. Jul 9, 2015 at 9:04 AM
    #594
    Roll Tide
    Q
    01 T4R
    I'm pretty sure its an I6.
  15. Jul 9, 2015 at 9:06 AM
    #595
    Roll Tide
    Q
    01 T4R
  16. Jul 9, 2015 at 9:14 AM
    #596
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yes, Cummins specializes in I6 Diesels. So do most Diesel truck engine manufacturers. The space requirements lengthwise aren't as tight so I6 makes sense in a heavy truck. The I6 is a less complex engine than a V8 while still being perfectly balanced.
  17. Jul 9, 2015 at 9:20 AM
    #597
    Roll Tide
    Q
    01 T4R
    Maybe the Gen4.
  18. Jul 9, 2015 at 9:29 AM
    #598
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    IF Tacoma eventually gets a Diesel it will be an I4 from there own lineup overseas. You heard it here first :D.
    I'm guessing that's why all of the rumors around Toyota using the Cummins and Ecoboost in the Tundra right when the new Tundra release happened ended up being untrue. I'm guessing Toyota looked into buy those powerplants for the Tundra and decided it was best for their business philosophy to rely on another manufacturers engines. They're probably right if that was the case.
  19. Jul 9, 2015 at 9:33 AM
    #599
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The Hino diesel / electric hybrid truck uses an inline 4cyl
  20. Jul 9, 2015 at 9:36 AM
    #600
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Hence the word "most".
    There are supertankers with I3 engines. It all depends on how the system is mated up. The purpose will dictate the engine used. Hybrids can use the electric motor for torque and tend to use smaller engines if they are going for the best mpg.
