So Toyota is wussing out on the Engine, dang it. 270HP but add gearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shr133, Jun 19, 2015.
  1. Jul 19, 2015 at 11:07 AM
    #941
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    People blindy assume that displacement means EVERYTHING for torque... when it doesn't... especially against an engine that is over 10 years old.
    computeruser6 likes this.
  2. Jul 19, 2015 at 3:01 PM
    #942
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    But Sterdog, red plus green equals 7 & and my grandfather told me apricots, therefore random unsubstantiated opinion.
    NMroamer and because_wumbo-truck like this.
  3. Jul 19, 2015 at 7:23 PM
    #943
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    Both being equally fit who would you want you to help move that piano? A 110 lb woman or a 200 lb man.
  4. Jul 19, 2015 at 7:34 PM
    #944
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If the 110lb girl is a power lifter and can lift more I'd take her over some 200lb lard ass man.
    PS: Your comparison proves you know nothing about engines or power delivery.
    Yota64 and Sterdog like this.
  5. Jul 19, 2015 at 8:44 PM
    #945
    littlezav
    littlezav Well-Known Member
    Leon
    Brooklyn, NY
    Apparently torque numbers are in. 270 hp and 261 Ft/lb. Check out the trd off road spec sheet that was posted in the 3rd gen forum
  6. Jul 19, 2015 at 10:18 PM
    #946
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    How long until CarandDriver picks up on these numbers?
    HORSEPOWER AND TORQUE
  7. Jul 19, 2015 at 10:34 PM
    #947
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    If true, it's less than I wish for, but probably all that I need. I am interested to see the torque curve (I wonder if it makes the "high" rpm for max torque a meaningless number). Also curious about mpg.
  8. Jul 19, 2015 at 10:49 PM
    #948
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yeah, the curve is what matters. Still, this engine is a bit disappointing on paper. Maybe with the gearing and the mpg it won't matter.
    Ridgeline sucks more with even less power and the Colorado is heavier which likely evens the field until Nissan revamps the Frontier. This Tacoma will do fine and that torque number is about where I thought it'd be but I was hoping for a lower rpm to get that torque.
  9. Jul 19, 2015 at 10:57 PM
    #949
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I was hoping for 300HP and about 275 torque.
  10. Jul 19, 2015 at 11:07 PM
    #950
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Engine code 2GR-(J)? Why no mpg numbers?
  11. Jul 20, 2015 at 5:01 AM
    #951
    4.0 TEQ
    4.0 TEQ Well-Known Member
  12. Jul 20, 2015 at 5:31 AM
    #952
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Not a good analogy.
  13. Jul 20, 2015 at 6:37 AM
    #953
    NMroamer
    Fred
    Albuquerque
    2015 TRD OR
    You are right I don't, just hoping some would explain how an small motor can out pull a much bigger one.
    4.0 TEQ likes this.
  14. Jul 20, 2015 at 6:47 AM
    #954
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Because displacement doesn't equal power to the wheels or even HP/Torque ratings:
    5.3 L L83 GM EcoTec3 5300 V8 355 hp (265 kW) @ 5600 RPM 383 lb·ft (519 N·m) @ 4100 RPM
    Ford Ti-VCT V8 5.0 L 385 @ 5750 rpm 387 @ 3850 rpm
    Fords 5.0 L is a slightly more powerful motor than GM's 5.3 L. The 5.0 L is also better geared with a higher ratio giving it a much better feeling for power.
    I suspect even if the 270 HP and 261 ft lbs of torque numbers are correct that the 4.1 rear end and weight savings are going to make the new Tacoma feel more powerful.
    ItalynStylion likes this.
  15. Jul 20, 2015 at 7:03 AM
    #955
    NMroamer
    Fred
    Albuquerque
    2015 TRD OR
    Thanks, Leaving Albuquerque to go North camping we start out at over 5400 feet and have to pull a five percent grade on I 25 to Santa Fe. Travel trailers have really taken over here for camping because like so many other places the weather can turn nasty in heartbeat. Those new motors are going to get put to the test in New Mexico and other mountain states.
  16. Jul 20, 2015 at 7:11 AM
    #956
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Honestly at that altitude the only gasoline engine that will feel good with a trailer, even in a full sized truck, would be the Ecoboost or something else with forced induction. The Turbos put you back at sea level.
  17. Jul 20, 2015 at 8:50 AM
    #957
    NMroamer
    Fred
    Albuquerque
    2015 TRD OR
    Just saw on another thread the numbers for the motor. 270 hp at 6800 rpm. 261 ftlb torque at 4600 rpm.
  18. Jul 20, 2015 at 8:50 AM
    #958
    Z50king
    Eric
    Southern California
    Stock and loving it
    Wowo
  19. Jul 20, 2015 at 8:56 AM
    #959
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Wrong, 270 HP at 6000 RPM and 261 ftlbs at 4600 RPM! Get it right lol.
  20. Jul 20, 2015 at 10:03 AM
    #960
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    Not good at all.
    that hp at 6000 rpm and a motor that really never sees anying more then 3 to 4 k normal is a problem.
    Also local dealer told me the mpg will be +1 real life and that is about it.
