So Toyota is wussing out on the Engine, dang it. 270HP but add gearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shr133, Jun 19, 2015.
  1. Aug 3, 2015 at 10:53 AM
    #1521
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    From my understanding, it is only minor things...drive shaft vibe, decent gear ratios in the manual (and fix the throwout bearing), the frames are still rusting prematurely...better mpg and hp/tq.
    In a nut shell, yes?
  2. Aug 3, 2015 at 10:54 AM
    #1522
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    How many people are having trouble with the HVAC fan? a coworker has already gone through 3 of them. Apparently according to him its a common problem.
  3. Aug 3, 2015 at 11:28 AM
    #1523
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    TA-DA!
    Ask, and ye shall receive.
  4. Aug 3, 2015 at 11:44 AM
    #1524
    BeaverNation
    BeaverNation Well-Known Member
    Exactly what I wanted, glad you pointed that out bama boy...
  5. Aug 3, 2015 at 12:10 PM
    #1525
    SwollenGoat
    It is the resistor, yeah? IIRC it has been updated.
    Basically little things...other than the frame.
  6. Aug 3, 2015 at 12:13 PM
    #1526
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    I wonder if Toyota will fix the hole in guage cluster next to the trip reset where mosquitoes get in and trap themselves. I've had the same two dead mosquitoes hanging out next to my tachometer for 8 years.
  7. Aug 3, 2015 at 12:16 PM
    #1527
    Roll Tide
    Q
    01 T4R
    Keep in mind, mpg's are suspect. If you're buying a truck for the mpg's....you'd be better off knocking out the back window of a prius. Also, financially, just keep your second gen. It really isn't worth the beating you'll take at the dealer/bank for a couple of suspect mpgs, and a round wheel arch.
  8. Aug 3, 2015 at 12:22 PM
    #1528
    TacoJonn
    Jon
    Laramie, Wyoming
    +1, why my paid-off gen 1 is still much cheaper to drive than a new Tacoma!
  9. Aug 3, 2015 at 12:23 PM
    #1529
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    In real world the 3.5L V6 will probably get 2 mpg better than the 4.0L V6. Everyone on here is hating on the Colorado V6 real world mpgs but for some reason thinks that the '16 Tacoma V6 will average 25. Keep dreaming. The 2nd gen will probably get better towing mpgs than the high strung 3.5L so MPGs will probably be a wash 2nd gen vs "3rd" gen.
    EPA should test mpgs in NYC, Bay Area, Seattle metro, LA, Dallas, etc.... to get us some real #s. Not from an air conditioned laboratory.
    because_wumbo-truck likes this.
  10. Aug 3, 2015 at 12:25 PM
    #1530
    Roll Tide
    Q
    01 T4R
    Yep. Same here. Plus, they look better.
  11. Aug 3, 2015 at 12:38 PM
    #1531
    SwollenGoat
    Did someone say Prius truck!?
  12. Aug 3, 2015 at 12:41 PM
    #1532
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    The 2gen is better.
    SwollenGoat[QUOTED] likes this.
  13. Aug 3, 2015 at 12:43 PM
    #1533
    Roll Tide
    Q
    01 T4R
    BWAHAHAHAHAHAHA
  14. Aug 3, 2015 at 12:44 PM
    #1534
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    The resistor has been updated. GM is actually having the same problem on the H3's and Colorado's from the same years.
  15. Aug 3, 2015 at 12:45 PM
    #1535
    SwollenGoat
    Never save any money buying a new truck.
    I "could" use a new one, nothing out there is really blowing my socks off to plunk down my cash, $30K+ keeps my old craaaap running an awful long time. Hell, my knee-grows you can pick up three 1st gens for $30K...
  16. Aug 3, 2015 at 12:46 PM
    #1536
    SwollenGoat
    the GM and the Toyota are interchangeable, yeah?
  17. Aug 3, 2015 at 12:47 PM
    #1537
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    The H3 and the Tacoma are interchangeable. Both were made by Denso I believe originally. The Colorado unfortunately has one less setting but is almost the same part. It can be moded to fit, but it is not a plug and play fix for the Colorado.
  18. Aug 3, 2015 at 12:49 PM
    #1538
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    It depends. I've seen plenty of people have an engine issue, then a transmission issue, then an ignition issue, then a transfer case issue...
    Sometimes buying a newer truck can save you money over running a money pit.
  19. Aug 3, 2015 at 12:54 PM
    #1539
    TacoJonn
    Jon
    Laramie, Wyoming
    The crappy part is my lethargic 3.4 liter gets roughly the same MPG has a the GM 6.2 liter V8. At some point I will have to shell out major $ for a new truck. That is why I am waiting to see how the gen 3 Tacoma V6 performs.
  20. Aug 3, 2015 at 12:56 PM
    #1540
    SwollenGoat
    True...still that is under $10K in repairs, with a truck I have known for the last 14 years. (buying a spare used one or 3 is an unkown)
    A fresh brandy new would be nice...but nothing out there really exciting me. Oil burner Collie maybe...but no manual trans, no extra cab...and well..it is a GM product...which is a slight step above as Dodge. ...imo.
