soft brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clia25, Nov 5, 2008.
  1. Nov 5, 2008 at 7:27 PM
    clia25
    clia25 [OP] Active Member
    Houston
    sr5
    Anyone experienced soft/spongy brakes on 09 models? what are some corrective options?
  2. Nov 5, 2008 at 7:29 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    buy some stainless steel brake lines.
  3. Nov 5, 2008 at 7:40 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I know on my 2001 I changed did a brake job and was having soft brakes once I was finished and come to find out it was because my rear brakes were not adjusted right.
    Just a thought!
  4. Nov 5, 2008 at 7:45 PM
    clia25
    Houston
    sr5
    i would rate myself better than average when it comes to working on cars. with that being said, is brake lines replacement a do it yourself job or a shop job?
  5. Nov 5, 2008 at 7:50 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Anyone can change brake lines. But there are a few things you should know - before jumping in.
    The brake lines at the calipers (front) has a banjo bolt and copper crush washers. You CAN NOT re-use the crush washers. Buy new ones.
    And - you should know how to bleed brakes properly.
  6. Nov 5, 2008 at 7:52 PM
    konigcoma
    konigcoma Member
    houston tx
    08 black access cab
    altezza black tails 18in konig unknowns
    my pedal is soft on my 08 im gonna check it out this weekend
  7. Nov 5, 2008 at 7:57 PM
    stucksucksnayota
    Barry
    I most have missed something if your pedal is soft why are yall talking out replacing the brake lines???
  8. Nov 5, 2008 at 10:04 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    The idea behind why a pedal feels soft and changing the lines to braded steel is that the rubber lines "give" and allow the fluid pressure to expand the lines. When this happens, that makes the system "soft" and feel unresponsive because... it is. When you apply x force on the pedal and some of that force is transfered to expanding the lines... your'e not getting the full pedal force you think you should be getting. Switching to steel corrects this by not allowing expansion in the lines, forcing all the pressure to go directly to the calipers.
    Kinda wordy explanation but, hopefully that helps. Also, from peeps that have changed over was it a really noticable change? I'm considering upgrading all the lines and getting some better drilled/slotted rotors down the line as the stopping power isn't nearly as good as I wish it was and feel it could be.
  9. Nov 5, 2008 at 10:08 PM
    Janster
    Jandy
    Lancaster, PA
    It makes perfect sense.... I just can't justify the cost to buy them - especially in this economy.
    My husband and I installed stainless lines (and a lift kit) on a jeep this past weekend. The owner of the jeep said his brakes felt better than they've ever felt before..... I can believe it.
  10. Nov 5, 2008 at 10:11 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Eh for about $100 shipped off e-bay... seems like a relatively inexpensive mod, and worth it esp if it helps stopping power. I spend more than that on stupider stuff.... lol.
  11. Nov 5, 2008 at 10:13 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I need to do this. Too often, we concentrate on performance upgrades and forget about more important things like safety. I did this on my '05 Altima and it definitely made a difference in braking distance and feel. I later replaced the OEM rotors with slotted ones and I'm now a believer for life in these mods. Definite improvement.
  12. Nov 6, 2008 at 4:48 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    my brakes are hard to push, they are just fine and dandy!
  13. Nov 6, 2008 at 5:26 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I'm with Wilson, going to check the piggy bank and start searching.....
  14. Nov 6, 2008 at 5:27 AM
    Janster
    Jandy
    Lancaster, PA
    I know, I know..... I've got a $350 exhaust out in the garage that I 'had' to have. ;)
  15. Nov 6, 2008 at 11:37 AM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    The '09 I test drove a month or so ago had soft breaks. We'll see what mine is like when it comes in in a couple weeks.
  16. Nov 6, 2008 at 11:43 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    The brake pedal on my '09 makes a noise when I push it - hard to explain, but kinda like a short hissing, SPHFT.
    Does that make sense? I don't recall this in my '06.
  17. Nov 6, 2008 at 12:06 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Look for the Goodridge brand. That's what I used on my Altima and they're a good quality and price.
  18. Nov 6, 2008 at 12:09 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    yes it makes sense, i have the same problem on my 09...im glad to know im not the only one
  19. Nov 6, 2008 at 12:10 PM
    LonghornTaco
    Minnesota
    But is something actually wrong or is that "just the way it is"?
  20. Nov 6, 2008 at 12:13 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^My guess is that it's just how it is. I've seen this same complaint many times on the forums over the 1+ year I've been a member. I personally don't have any issue with my brakes other that I'd like a shorter stopping distance.
