soft brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clia25, Nov 5, 2008.
  1. Nov 6, 2008 at 12:59 PM
    Teufel Hunden
    Teufel Hunden No Better Friend, No Worse Enemy
    Northern Virginia
    09 MGray DC SB TRD-OR 4x4 V6 Auto SR5
    Undercover tonneau, OEM tow package with hitch, OEM retractable roof rack, Front window tint (legal), WeatherTech FloorLiners, Door sill protectors, Tacoma bed mat, Rear leaf spring TSB, OEM DRL mod, Door edge guards, AFE Pro-Dry S Air Filter, Removed secondary air filter, Smoked LED 3rd brake light, Romik running boards, Go Rhino hitch step, Extra set of D-rings mod, Bed cargo net, TRD wheel locks, OBX sport pedal covers.
    Don't worry, there is nothing wrong. That is just the way the brakes are in the 2009's. The brake system has been slightly changed in the 2009 models to accommodate all of the new features that it now has to control. Take a look at page 3 of the PDF located here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/17430-detailed-2009-tacoma-changes.html
    I also noticed (as compared to a 2008 model) that they moved the master cylinder from the left side of the engine compartment (as you are looking at the truck from the front) to the right side, directly under the brake fluid reservoir.
  2. Nov 7, 2008 at 1:16 PM
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    Just wanted to post I bought a new 07 Tacoma TRD Prerunner 1.5 years ago and bought an 08 same truck 5 days ago and the brakes on my 08 are NOTICEABLY softer. I'm going to try and adjust the pedal throw if I can under it, or take it in, something isn't great and it's pissing me off.
  3. Nov 11, 2008 at 5:10 PM
    mrw3685
    TX by way of KS
    08 Prerunner TRD
    I'm not sure how many people read this but since I've seen TONS of posts about crappy/shitty/mushy brakes on 08 Tacoma's I just wanted to post an answer that doesn't involve you going out and spending money on steel braided brake lines to marginally fix the problem.
    Anyways, the answer?! Have Toyota put in a new brake master cylinder. Only thing I can think of is they have a batch of trashy ones they put on new trucks. Had mine replaced and it work like a charm, truck has all of 250 miles on it.
  4. Nov 14, 2008 at 12:46 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    The answer is much simpler than changing MC or lines.
    Bleed the brakes.
    My wife's RAV4 had air in the lines from the factory. easy to tell...while stopped, try pumping the pedal and see how it feels firmer?
    My 06 Taco has air and I'm going to bleed them this weekend.
    Amazing a company can deliver a vehicle with air in the lines.
  5. Nov 14, 2008 at 12:52 PM
    rangejeep
    rangejeep Well-Known Member
    Charlotte, NC
    05 Tacoma 4x4 TRD Off Road
    Mine are soft too. I'm going to upgrade after I get a 3 inch lift.
