soft top for camping?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by big sky, Aug 23, 2012.
  1. Aug 23, 2012 at 3:57 PM
    big sky
    big sky [OP] Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    I was considering getting a soft top, mainly for camping purposes- are they suitable for that use? is one brand or style better than another for this purpose?
    need protection from inclement weather- will have a large pad & sleeping bag underneath
    thanks in advance
  2. Aug 23, 2012 at 4:08 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I've slept in my Bestop Supertop numerous times while camping. The short bed is kinda cramped with the tailgate up and the windows in place, but it's very nice. Completely leak proof, except for one small section in the corner near the passenger rear door. Duct tape took care of it. It's very convenient, but if you're thinking about camping in snow, forget it. Way too cold. I slept with the windows down in the desert for a breeze, it was very nice.
  3. Aug 23, 2012 at 4:14 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Do want. I need something that folds clear of the box, or is very easy to remove, as I carry dirtbikes sometimes...
  4. Aug 23, 2012 at 4:32 PM
    The Traveler
    SoCal
    The Bestop ^^ Folds forward and flat in less than 10 seconds to give you full functionality and space of the bed.
  5. Aug 23, 2012 at 5:51 PM
    big sky
    Montana
    curious if the rear window could be propped up some way, thinking it might allow the tailgate to be down???
  6. Aug 23, 2012 at 5:54 PM
    The Traveler
    SoCal
    They are independent of each other. The rear window can be closed with the tailgate opened, or vice versa. There are two straps that hold the rear window in a rolled up position as well if you'd like.
  7. Aug 23, 2012 at 6:01 PM
    big sky
    Montana
    thanks- looks like it would definitely be a viable option :)
  8. Aug 23, 2012 at 7:01 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I've used my bestop for camping as well. The short bed does suck, but I barely fit sleeping diagonal. They don't keep warmth, so make sure you have a good sleeping bag. The trip below, it was 30 degrees over night. When I woke up, frost was all over.
    And yes, it'll hold moisture out
  9. Aug 23, 2012 at 7:06 PM
    big sky
    Montana
    warm sleeping bag and pad- check :)
    how is the bestop installed, is it integrated w/ the Tacoma rail system?
  10. Aug 23, 2012 at 7:09 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    yeah
  11. Aug 23, 2012 at 7:13 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
  12. Aug 23, 2012 at 7:16 PM
    RattleSnake44
    RattleSnake44 Well-Known Member
    SoCal
    06 DCSB PreRunner TRD Offroad
    OME 3" Lift, Dakar Leaf Packs, ARB Front Bumper, Warn M8000 winch
    Soft topper rules!
  13. Aug 23, 2012 at 8:12 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    The only real difference are the windows
  14. Aug 24, 2012 at 12:33 AM
    The Traveler
    SoCal
    I've "slept" in 24 degrees below freezing in that thing, but it was dry. And yeah...it's pretty much a hardshell at that point.
  15. Aug 24, 2012 at 9:00 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    I've actually slept with one of these in the back with me
    Not sure how healthy that is, like if the propane leaked or anything, but it worked and I was cozy as hell.
    I had it on, and right when I was about to fall asleep, I got up to turn it off. Then in the early morning when I woke up to the cold, I turned it on and slept for another few hours. Worked out great.
    Oh another thing, I keep an empty bottle with me in the back so that if I need to take a leak, I just go in there instead of having to get out and messing with the back part and tailgate. Then I just throw it out in the morning and use a fresh one for the next day :D
