Soggy Bottom
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackonwhite, Jun 30, 2008.
  1. Jun 30, 2008 at 3:52 PM
    blackonwhite
    blackonwhite [OP] Well-Known Member
    06 white tacoma black 17' ssr wheels
    Has anyone had a problem with their floor pans filling up with water? It happened when i first got my truck but the hose for the air conditioner had fallin out of the firewall and was running inside the cab.. i checked it this time and it wasnt it but everytime it rains my passenger side floor is soaked and i cant tell where its leaking from
  2. Jun 30, 2008 at 3:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds like it could be a windshield seal, or maybe the cowling under the windshield has a bad spot in it. are you still under warranty??
  3. Jun 30, 2008 at 4:45 PM
    blackonwhite
    Yea i t should still be under warranty.. When i bought the truck it had 3000 miles on it and it was on the used lot at a toyota dealer... It came with a 100000 mile/ 7 year warranty but who knows what the warranty covers
  4. Jun 30, 2008 at 4:47 PM
    blackonwhite
    also did you notice much of a difference when you removed your secondary filter
  5. Jun 30, 2008 at 5:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd take it back to the dealer and see if they can find the problem.
    as for my removing the sec. air filter......didnt notice much, but i can tell it breathes a little easier.
  6. Jun 30, 2008 at 5:17 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I had a similar problem when I took my mudflaps off, when it rained and I drove through water the driver side floor got wet. I know the problem was under the truck because if I just left the truck parked outside in the rain the driver side floor would remain dry. Anyway I put the mudflaps back on and inside never got wet again. I haven't found the source of the leak as yet but I'll keep you posted.
  7. Jun 30, 2008 at 6:37 PM
    blackonwhite
    Alright thanks guys
  8. Jun 30, 2008 at 8:27 PM
    blackonwhite
    I just pulled the kick panel out of my truck and pulled up the carpet far as i could and the only place i can see that it could be leaking is arund the cowl..or the base of the windshield... the rubber seals at the bottom of the windshield can be pulled up a lil so that could be where its coming from... but soon as i find out ill let everyone know
  9. Jul 1, 2008 at 8:08 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    i believe there is a TSB for that problem.. go look at the list of TSBs at the top of this page.
  10. Jul 1, 2008 at 8:13 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    maybe it was going through bolt holes.
  11. Jul 1, 2008 at 11:09 AM
    Asgard
    Is that normal, or should I have it looked at ?
  12. Jul 1, 2008 at 11:16 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I don't know. I've never examined my flappers. Are they bolted on? When you take them off, I'd make sure to keep something in the holes left by the fasteners.
  13. Jul 1, 2008 at 11:51 AM
    Vege-Taco
    Vege-Taco Chips and Salsa Specialist
    Shawn
    Arizona
    2017 Tesla Model S 100D
    Bugs on the windshield
    I remember as a kid, my dad's '85ish Toyota pickup's AC drained inside the glove box. I thought it was pretty neat to have ice cold running water while driving down the interstate between Flagstaff and Phoenix, Arizona. :D The water tasted dusty, but it was cold and wet, so I drank it several times.
  14. Jul 1, 2008 at 1:59 PM
    Asgard
    I left the bolts in but I remember when I was putting them back on I was missing a bolt (had to buy one from the hardware store), maybe that hole was the source of the leak.
