Solar panel install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 5678ta, Jan 28, 2017.
  1. Jan 31, 2017 at 6:12 PM
    #41
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    Sub'd to see how the tape holds up! I may end up doing something similar. Awesome job!
    5678ta[OP] likes this.
  2. Feb 4, 2017 at 9:44 AM
    #42
    BlackT
    BlackT Member
    Tom
    Rhode Island
    2016 trd or
    Looks great man!
    I have a group 31 battery on the way and the solar panel is the next purchase. I'm going with a 100 watt hard panel on the rack but I really like the film on the roof idea. Nice instal!
  3. Feb 4, 2017 at 6:00 PM
    #43
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Baad Assed!
    Dang..... I like that set-up and could grab one for the Skiff!
    Thanks so much for sharing your creative genious,
    and looks good too
  4. Feb 4, 2017 at 6:12 PM
    #44
    mike5krnr
    mike5krnr Well-Known Member
    2008 Toyota TRD
    3" lift, Warn 9000 winch, LED flood light, 10lb Powertank, Thule Rack, Maggiolina Roof Top Tent
    Pretty cool!
  5. Feb 5, 2017 at 2:10 PM
    #45
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I thought about this yesterday. (Slow, huh?)
    I didn't mean so hot to melt anything. Just enough heat to simulate a hot summer day so it doesn't happen going down the road at high speed.
    If you have a laser thermometer you could gauge the heat applied better.
    5678ta[QUOTED][OP] likes this.
  6. Feb 5, 2017 at 2:18 PM
    #46
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    @DVexile...this could be a future addition to the dietTaco
  7. Feb 5, 2017 at 2:32 PM
    #47
    jerent66
    jerent66 Well-Known Member
    Santa Cruz County
    TRD OFFROAD 6SPD MT 4x4
    Nice!
    :cheers:
  8. Feb 5, 2017 at 2:41 PM
    #48
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Very nice! :cheers:
  9. Feb 7, 2017 at 6:54 PM
    #49
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Daria likes this.
  10. Feb 7, 2017 at 10:39 PM
    #50
    5678ta
    5678ta [OP] Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    I'll try it on a test piece since i have extra tape and wrap. I'll just use a plastic bottle to simulate the smooth plastic-ish surface of the panel. I might have a pull scale somewhere to figure out the pull force and i do have a laser temp gun.
    MartinDWhite likes this.
  11. Feb 25, 2017 at 12:56 PM
    #51
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    I like this a lot. Nice work!
  12. Feb 27, 2017 at 12:24 AM
    #52
    5678ta
    Hogan
    Henderson, NV
    Updated first post
  13. Feb 27, 2017 at 5:26 AM
    #53
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Awesome thank you for the updates! This is all new to me so basically the charge controller works just like the voltage regulator in the alternator? The panel charges and when the batt gets up to around 14 or so volts the charge controller stops the juice to the batt to prevent over charging. Then when the batt gets down to whatever the set voltage is it kicks back in and charges again.
  14. Feb 27, 2017 at 5:38 AM
    #54
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    More or less. There are PWM(cheaper, smaller) and MPTT(expensive, more efficient, more current/voltage handeling) controllers, they work in different ways but that's the basics.
  15. Feb 27, 2017 at 5:42 AM
    #55
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Sub'd for longevity. Good looking install OP.
  16. Feb 27, 2017 at 6:23 AM
    #56
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Maybe you can look into something to 'seal' the edge of the leading tape. Something like nail polish, but not sure you want that on the paint ....... just an idea.
  17. Mar 30, 2017 at 6:07 AM
    #57
    MartinDWhite
    MartinDWhite Well-Known Member
    Martin
    Greenville, SC
    2004 4-dr 4x4 Tacoma TRD
    Relentless front and rear bumpers, Warn M-8000S Winch, Relentless RockSliders, bigger tires, bed cover RTT ... and more big changes in the works.
    So cool! Good job!
  18. Apr 13, 2017 at 11:28 AM
    #58
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Just checking in to see how things are working. I'm about to pull the trigger on this panel and controller
    Chux and 5678ta[OP] like this.
  19. Apr 13, 2017 at 5:31 PM
    #59
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    Awesome project!
  20. Apr 13, 2017 at 5:52 PM
    #60
    CiscoSF
    CiscoSF Well-Known Member
    San Francisco, CA
    2017 TRD Sport
    Nice work, thanks for posting -- I've been mulling over adding a solar panel.
