Solar panel install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 5678ta, Jan 28, 2017.
  1. Jun 25, 2017 at 1:32 PM
    #81
    5678ta
    5678ta [OP] Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Added new update from oven torture test to first post. Record tying high temp on one day.
  2. Jul 13, 2017 at 3:30 AM
    #82
    5678ta
    Hogan
    Henderson, NV
    Added another update from my latest trip. Text in first post is Blue.
    Spare Parts, yonah and SOSC like this.
  3. Jul 24, 2017 at 8:16 AM
    #83
    UTBoatFanatic
    UTBoatFanatic Well-Known Member
    Don
    Midvale, UT
    2017 Dark Grey Tacoma Double Cab Off-Road - Manual Transmission
    Leer Shell
    I have a quick question. I have an ARB 50Qt fridge that I just installed, and I bought an Optima Yellow-top battery that I had planned to drop in a box and just wire up a 12v plug to it as a temporary measure while I wait for the rest of the parts to get this really wired in for good. Basically, what I did was get a 12V plug kit, install a 15 fuseholder in line and then just wire the thing directly to the posts on the battery. I've got a spotlight that works just fine when plugged in to the plug, so I know there's juice. I've got the Optima digital charger that shows the battery is fully charged. But the fridge refuses to turn on when plugged into this plug. If I plug the fridge into the plug in the dash of the truck, it starts up and runs just fine. Am I missing something simple? I swapped the leads from the plug to see if it was a polarity issue, but no joy.
    ShemRahBuck and 5678ta[OP] like this.
  4. Jul 24, 2017 at 9:02 AM
    #84
    5678ta
    Hogan
    Henderson, NV
    Try plugging into truck, letting fridge run for a few minutes then turn the fridge off. Let it sit turned off for a minute. Pull plug and hook up to your AUX battery and power on. I know my ARB is finicky sometimes. There is a low voltage cutoff switch that won't let you turn on unless you surpass a certain voltage. Perhaps pulling power while the fridge is on, is simulating a low voltage episode.
  5. Jul 24, 2017 at 10:19 AM
    #85
    yonah
    yonah Well-Known Member
    Calling-in from east of the Rockies
    Maybe the primary wire to the 12v socket is a small gauge and creating excess resistance? The ARB fridge's circuitry will mistakenly interpret this as a sub-11.8v (or whatever voltage you set it to) battery and cut off the fridge. I believe the ARB 12v plug kit is supplied with a 20', 10 AWG primary/ground harness which connects the 12v plug to the battery to prevent this from happening. If the 12v socket is poorly made, it could be creating the resistance as well.
    5678ta[QUOTED][OP] likes this.
  6. Jul 24, 2017 at 11:05 AM
    #86
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Good thread OP.
    5678ta[OP] likes this.
  7. Jul 25, 2017 at 7:28 AM
    #87
    UTBoatFanatic
    Don
    Midvale, UT
    Leer Shell
    Solved it: It was the plug. I bought a $5 unit from Pep Boys that had two clips and a plug, clipped that to the battery and the fridge started right up. Thanks for helping me with this!
  8. Jul 29, 2017 at 9:54 AM
    #88
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Wow this is awesome!
  9. Sep 26, 2017 at 7:23 PM
    #89
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    sub for later
  10. Sep 29, 2017 at 11:57 AM
    #90
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    I see in the first post you mention a fuse holder. Where in the system did you install the fuse?
  11. Sep 29, 2017 at 12:15 PM
    #91
    5678ta
    Hogan
    Henderson, NV
    At the battery. The charge controller has one as well. I have an RTMR now so I use one of the Fuse-only circuits for solar input.
  12. Sep 29, 2017 at 3:34 PM
    #92
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Brilliant :cheers:
    5678ta[OP] and BassAckwards like this.
  13. Oct 1, 2017 at 6:59 AM
    #93
    21LostBoy
    21LostBoy Well-Known Member
    Clint
    Nebraska
    2015 Toyota Tacoma TRD Sport DCSB
    Very impressive install and I appreciate everyone's input to clarify and fine tune the process. Looking forward to completing my own build.
  14. Apr 1, 2018 at 2:52 PM
    #94
    MatrixDJ
    MatrixDJ New Member
    Michael
    Las Vegas
    2017 Silver Tacoma Off-Road 4x4
    Rough Country Nerf Steps, BFP Custom Toyota Grill, Dog Platform, Blacked out emblems (5hp ea.)
    Subbed, thia is awesome!!
    I live in Vegas as well and considering this for camping purposes. Thank you!
    5678ta[OP] and ilubtimmyhos like this.
  15. Apr 1, 2018 at 4:38 PM
    #95
    5678ta
    Hogan
    Henderson, NV
    Tape is still holding strong. No lifting. Still get up to 14.3v in good conditions.
    Not much else to say. Setup is working good. Every now and then i forget to turn the fridge off or i charge my tablet or handheld radio and it drains the battery but the Optima recovers with a jump pack. I park in my garage, so no sunlight in there.
  16. Apr 1, 2018 at 4:39 PM
    #96
    I am Root
    I am Root UID 0
    Root
    I am root
  17. Jul 23, 2018 at 1:07 AM
    #97
    Aldizzle13
    Aldizzle13 Well-Known Member
    Bay Area
    2012 Tacoma TRD Sport 4x4
    subd cus this is sick :smokertransformer:
  18. Jul 23, 2018 at 7:56 AM
    #98
    gnardoggie
    gnardoggie Well-Known Member
    clean install - I've been trying to decide where to mount my semi-flex panel for a while now.
  19. Jul 23, 2018 at 9:26 AM
    #99
    ScottyBoy215
    ScottyBoy215 Well-Known Member
    Scott
    Scottsdale, AZ
    2015 MGM Tacoma Off-Road
    JD Fabrications front end Hydro bumps & limit straps King 2.5's Bilstein rear shocks Leer 10XR PRO grille
    That's awesome
  20. Jul 24, 2018 at 10:33 PM
    #100
    5678ta
    Hogan
    Henderson, NV
    Thanks guys. I'll actually be adding a second panel to try and boost the average voltage. I recently discovered that AGM batteries should be charged at 14.0+volts and my average is typically mid-high 13.
    I have a second 100W panel from a different manufacturer that is larger and different design, that will go on the camper. Output in full sun should be upwards of 10amps combined.
