SOLD! [Bishop/BigPine, CA] REDUCED $400 Cash! 2016 O.R. wheels w/TPMS, Wrangler TrailMark
Discussion in 'Wheels & Tires Marketplace' started by Hobbs, Dec 29, 2018.
Thread Status:
Not open for further replies.
  1. Jun 11, 2019 at 8:07 PM
    #1401
    Hobbs
    Hobbs [OP] Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Sounds like you have a capable rig. You're gonna weld on you LBJ's huh?
    sawbladeduller likes this.
  2. Jun 11, 2019 at 8:25 PM
    #1402
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Yep. Two buddies and myself have had a total or partial failure in the last two months. All involved the bolts. The only way to totally prevent that from happening is to weld the LBJ to the spindle. We wheel hard enough that we are putting a ton of stress on the system often. That's causing the bolts to shear. Once it's welded I'll never have to worry about sheared bolts again. lol
  3. Jun 11, 2019 at 8:34 PM
    #1403
    Hobbs
    Yep…
    Do you increase the likelihood of a ball joint failure running it this way? You would have to have back-up modded spindles.
    sawbladeduller and tcjacado like this.
  4. Jun 11, 2019 at 8:40 PM
    #1404
    theesotericone
    Bishop CA
    It doesn't. The LBJ takes the same force regardless of if the bolts are there or if it's welded. My LBJ's are fairly new and play free so I'm not overly concerned with them failing. I wouldn't need modded spindles if they do fail. I'd need to carry a spare driver and passenger side spindle, LBJ's and 8 LBJ bolts. It's an hour field repair tops.
    The only real downside to this is that instead of being able to pull the 4 LBJ bolts to replace a blown CV you'd have to pull the ball joint out of the LCA. I have RCA CV's so I don't expect them to break. Ever. lol
  5. Jun 11, 2019 at 8:43 PM
    #1405
    Hobbs
    Yep…
    Yeah, the LBJ's take the same force, but you are putting higher loads with big tires and removing the weakest link (sheared bolts). I'm curious what the second weakest link might be...
    EDIT: hopefully none!
  6. Jun 11, 2019 at 8:58 PM
    #1406
    theesotericone
    Bishop CA
    My buddies and I are always wondering what the next weak link is. Example. About 9 months ago I bit the bullet and went with RCV CV's. You'll see posts of mine where I was a huge proponent of having the weak link easy to replace, ie the CV. After replacing 10 of them I started to rethink my position. I was in contact with RCV when they where developing the 1st gen Taco/3rd Gen 4Runner CV's. I waited the better part of 6 months until they where finally ready. AFAIK I was the first 3rd Gen 4Runner to get them.
    The big question was what's the next weak link? The pinion and ring are actually fairly strong. The stub shafts in the ADD system is not. I am sure that that will be the next failure point. The big question is can it stand the torque from hard wheeling. We all know the stock CV's can't. But, no one had ever run bullet proof CV's. With my RCV's I've wheeled them a ton. I haven't had to replace a CV in that 9 months. I've also never had any issues with the stub shaft. So, for now at least, it appears the stub shaft is strong enough. If that ever changes I've already talked to RCV about making a 4340 stub shaft. They will do it.
    So this is just another test to see if a theory works. If it does I'm out nothing. If it doesn't I have to replace 2 spindles and 2 LBJ's. A few of us are looking into making the system strong enough for our needs but that will entail a lot of CAD and testing. In the meantime I'm just gonna keep wheeling and most likely breaking shit. lol
  7. Jun 12, 2019 at 8:21 AM
    #1407
    magicgus323
    magicgus323 Well-Known Member
    Gustavo
    Visalia Ca. East LA LBC
    2016 White Tacoma Sr 2.7
    TRD rims and suspension, TRD grill, stereo iPhone mirroring stormtrooper decal backflip bed cover painted bumper and mirror caps
  8. Jun 12, 2019 at 9:03 AM
    #1408
    Hobbs
    Yep…
    See you in a while.
    StayinStock likes this.
  9. Jun 12, 2019 at 9:09 AM
    #1409
    tcjacado
    tcjacado Well-Known Member
    Is the dungeon ready?:cool:
  10. Jun 12, 2019 at 9:11 AM
    #1410
    Hobbs
    Yep…
    Have you seen Pulp Fiction??
    StayinStock and tcjacado[QUOTED] like this.
  11. Jun 12, 2019 at 9:11 AM
    #1411
    tcjacado
    :yes:
    :yay:
  12. Jun 12, 2019 at 11:39 AM
    #1412
    magicgus323
    Gustavo
    320D70CE-C9CE-4B72-AEA7-6545ABC24609.jpg DDF9F959-2574-449B-9B7F-F4FC7CAA8618.jpg Thanks Mr. Hobbs!
  13. Jun 12, 2019 at 11:46 AM
    #1413
    Hobbs
    Yep…
    Gustavo came through!
    Thank you Gustavo!
  14. Jun 12, 2019 at 11:49 AM
    #1414
    Hobbs
    Yep…
    I promised myself I wouldn't cry.
    I should have known better..... :(
  15. Jun 12, 2019 at 11:57 AM
    #1415
    tcjacado
    It's a sad day indeed.:pout:
  16. Jun 12, 2019 at 12:32 PM
    #1416
    theesotericone
    Bishop CA
    Amazing. Well to fill in the tires not selling gap I've got some 295/70r17 Nitto Ridge Grapplers for sale. Less then 5000 miles on them and 11 to 12/32nds left. I'll get some photos up sometime in the next month. Lol
    StayinStock and Hobbs[OP] like this.
  17. Jun 12, 2019 at 2:10 PM
    #1417
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Tears of joy.
    Congrats @magicgus323 you got a nice set of rims/tires. Enjoy em.
  18. Jun 12, 2019 at 2:32 PM
    #1418
    Hobbs
    Yep…
    Will those tires fit on my truck with no lift?
  19. Jun 12, 2019 at 2:43 PM
    #1419
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Wait wait wait. This thread says tires are for sale still?
    I’m reporting.
  20. Jun 12, 2019 at 2:51 PM
    #1420
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Tires still available?
    Hobbs[OP] and StayinStock like this.
Thread Status:
