Sold! Please Delete
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by txtaco87, Jan 11, 2016.
  1. Jan 11, 2016 at 1:01 PM
    txtaco87
    txtaco87 [OP] Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Up for sale is a set of Revtek coil top spacers for the 2nd gen Tacoma. They measure roughly 1.5". I ran them on my 08 pre runner for a little while before upgrading to the 5100s. I'm asking $30 obo for the (2) spacers. They have a little weight to them so if I'm shipping it will be on buyers dime. The paint on them is flaking off but you can fix that with some rattle can. They work just fine. Located in Houston, Tx.image.jpgimage.jpgimage.jpgimage.jpg
  2. Jan 13, 2016 at 6:24 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
  3. Jan 26, 2016 at 8:09 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Morning Bump!
  4. Jan 27, 2016 at 3:54 AM
    GYOAZ
    GYOAZ Well-Known Member
    Gary
    Tucson, AZ
    2015 Tacoma SR5 4X4 MGM access cab
    Billies and Eibachs, Camburg BJ UCAs, Demello hybrid sliders SOS HC rear bumper, SOS front bumper, Warn M80000, fully armored, Safari snorkel, No-slip locker, diff breather, bumper and roof mounted light bars, onboard Viair, 275/70 17 BFG ATs, and a badass sound system.
    what hardware is needed to use these? how much lift do they provide?
  5. Jan 27, 2016 at 5:53 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    No additional hardware is needed, they will sit between the top of the factory coil spring and the top mounting plate as seen in the pictures below. They provide 3" lift in the front IF you use a top plate spacer with it. Top plate spacers will require longer studs in the plates. image.jpgimage.jpg
  6. Jan 27, 2016 at 5:58 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    If you install these spacers on the front without the top plate spacer and have nothing done to the rear it should level it out. I'm sure if i'm wrong someone will come correct me here. This is a link to the kit for front and rear i found just now http://www.4wheelparts.com/Suspension/3-Inch-Lift-Kit.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=REV426A
    But i wised up and went with 5100s, and will soon order the toytec/eibach 3" coil to go with it. But for someone who wants to just lift the front a little to level it out and not spend alot of money this will work ok.
  7. Jan 27, 2016 at 7:12 AM
    GYOAZ
    Gary
    Tucson, AZ
    Ok. So it looks like it pre loads the springs. How was the ride compared to stock? I'm assuming a bit stiffer.
  8. Jan 27, 2016 at 8:07 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Yes it is a bit stiffer, i'll somewhat compare it to my current setup with the Bilstein 5100s set at 2.5" with the factory coil. Which also pre-loads the spring. Stock is always going to be softer.
  9. Feb 16, 2016 at 8:21 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
  10. Apr 22, 2016 at 8:28 PM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Bump, somebody make me an offer. Take these off my hands
  11. Apr 22, 2016 at 11:40 PM
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    how much would these be shipped to 90606?
  12. Apr 23, 2016 at 1:57 PM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
