*****SOLD******
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ratcityrain, Jul 18, 2016.
  1. Jul 18, 2016 at 8:51 AM
    ratcityrain
    ratcityrain [OP] Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    We are upgrading to a new truck so no longer need this. Remote start is only a year old and works flawlessly. Enables you to remote start your truck to make it cool on hot days and to warm it up cold days. Nothing is better than getting into a cool or warm truck.
    Looking for $175 shipped
    PLEASE NOTE: This only works with Tacoma’s that have a G stamped on the key itself. Please look at your key and see if there is a G stamped into the key near the top right below the black handle portion.
    Installation is plug and play. There are only 6 wires (Parking lights, Brake, Horn, Lock, Unlock and IMMO) that need to be tapped into for accessories if you wish to have those. Can control remote start, unlock and lock doors, sound the horn, parking lights come on when unlocked and or when locked.
    Comes with:
    · Brain and wire harnesses
    · 2 remote controls – 1 regular and 1 2-Way FM/FM rechargeable LCD paging remote, Up to 3000 Ft. range, LCD graphics and real-time page back for confirmation of lock, unlock, trunk pop and remote engine start
    · Car charger to charge the lcd remote control
    · Owner and installation manual
    · Pictures of where wires are located
    · Links to installation videos
    Install time took me approx. 4 hours and that was taking my time to locate where all the wires were and testing them
    Retail currently on Amazon is $275 when available. Please note that the cap on top of the antenna on the lcd remote has disappeared so the spring for the antenna is lose. The remote still works, but it just has the spring exposed and I assume it can be cut down shorter and still work correctly.
    Also the factory remote still will continue to work even with this unit installed.
    Please email me if you have any questions
    Thank you
  2. Jul 18, 2016 at 2:59 PM
    RavegreenA4
    RavegreenA4 Well-Known Member
    Gilbert, AZ
    2013 Tacoma Double Cab Long Bed Limited
  3. Jul 28, 2016 at 11:25 AM
    ratcityrain
    Seattle, WA
    Weekly bump, this is still available
  4. Aug 8, 2016 at 1:20 PM
    ratcityrain
    Seattle, WA
    Still available for anyone interested.
  5. Aug 9, 2016 at 6:06 AM
    ThatKidNoe
    ThatKidNoe Active Member
    Utah
    2011 Metallic Gray Tacoma Off-Road TRD
    30in LED bar on front bumper, Aftermarket Grille with Tacoma Letters custom cut and painted, TRD Front Grille Badge, Plasti Dipped Emblems, 2 Ten Inch Kicker Comps w/ custom box alpine amp.
  6. Aug 25, 2016 at 2:14 AM
    AustinM2015
    AustinM2015 Well-Known Member
    Austin
    New Braunfels Texas
    2007 V6 4x4 standard
    Would you go any lower in price ?
  7. Aug 25, 2016 at 5:26 PM
    Santanero714
    Santanero714 Well-Known Member
    Still available?
  8. Aug 26, 2016 at 3:29 AM
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    Does this model shut the trucks engine off Once you open the door?
  9. Aug 26, 2016 at 6:39 AM
    13tacocharged
    13tacocharged Member
    2013 Tacoma TRD OR 4x4
    No. Either the brake will if you don't have the key in or the fob can.
  10. Aug 26, 2016 at 7:10 AM
    ratcityrain
    Seattle, WA
    Yes it is currently still available.
    The engine only shuts off when you press the brake or after 20 min of run time and or with the remote like 13tacocharged said
  11. Aug 26, 2016 at 10:56 AM
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    Interested if still available?
  12. Aug 26, 2016 at 3:23 PM
    ratcityrain
    Seattle, WA
    It is currently still available
  13. Aug 27, 2016 at 10:04 AM
    Tacoma_Cal
    Tacoma_Cal Well-Known Member
    Cal
    Lifted 2006 Tacoma V6 Crew Cab TRD
    No mods as of yet other than the fact that it is lifted. I just purchased the vehicle, so I am eager to see what everyone is doing with their rigs!
    Would this work with a 6 speed manual?
  14. Aug 28, 2016 at 8:36 AM
    ratcityrain
    Seattle, WA
    I believe so, but this one is now sold
