Sold
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by Animus313, Jan 23, 2018.
Thread Status:
Not open for further replies.
  1. Jan 23, 2018 at 10:26 PM
    Animus313
    Animus313 [OP] Well-Known Member
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    Hello All,
    Selling my 2000 Toyota Tacoma Xtra Cab V6 3.4L 5spd 4x4 TRD with custom tire swing rear bumper
    Tacomaworld member pricing list at $7500 and open to offers. Title in hand. Located in Post Falls, Idaho
    I’ve owned the truck for 6 years and currently has 187,XXX miles on it. It is not my daily driver so the miles won’t go up much. Was a California truck for most of its life. First 2 I owned it the tuck was in Texas, then back to California for 2 years. This will be only the truck’s second winter on winter stricken roads.
    2000 Toyota Tacoma Xtra Cab TRD option
    Engine: The rock solid V6 3.4L
    Transmission: 5spd Manual
    Drive train: 4x4, J shifter T-case, E-locker rear diff lock
    Suspension: Installed the Bilstein/Eibach 3” lift kit from Toytec a little over a year ago.
    Front: Bilstein 5100 shocks with Eibach springs- rides a little rough on some trail and washboard dirt roads. I went with the higher 620lbs spring rate with this kit as I had plans to build a winch bumper for the front. Polly bushings were installed with it.
    Rear: Toytec 2” adjustable shackles, rear leafs also have an add-a-leaf
    Diff Drop installed
    Cooling: Has an electric fan installed nothing fancy but it does keep the engine temp slightly cooler than the stock fan. Cut of switch wired to the cab to turn off the fan. Stock fan included. Installed power steering fluid cooler for those hot days on the trail with oversized tires.
    Wheels & Tires: Eagle Alloys 16” Wheels with 265/75/16 Goodyear Wrangler tires, less than 1 months on them and again, not my daily driver.
    Exterior:
    Body is in fair, owner before me used it as a work truck which beat the bed up some. Fresh coat of truck liner on it. Truck was used on wooded and brushed trails so there are scratches and dings. Truck was used as a weekend trail/camping fun vehicle. A previous owner decided to do a clear coat over the truck but didn’t remove the badges, went to remove them to clean them up and it caused some damage, cleaned up the areas with color matched paint and clear coat.
    Hood had the common clear coat pealing, paint was stripped, re-primed, and then vinyl wrapped with OD Green wrap. Have enough left over I planned to do the tail gate with.
    Rear bumper: custom build a rear bumper with tire swing. Tire is mounted on the right (passenger side), on the left room for two military style fuel cans. The bumper was over built. I remove the bumper each spring to recoat the bumper. Original bumper included.
    Rear frame has been boxed to handle the extra weight of the bumper with the rear cross member removed and replaced.
    PIAA lights mounted to front bumper
    Diff breather mod
    Interior:
    Vinyl flooring-not professionally installed but looks good
    Seats are out of 1995 4Runner modified to fit, driver side has lumbar and side adjusts.
    JVC audio unit-CD Player, Bluetooth with mic for calls, iPod/USB input.
    Cobra 18 WX ST II CB radio- antenna included, no mounting bracket though
    Grenade shift knob
    Viper power lock and alarm system
    External speaker in headliner for radios- had a HAM radio hooked up to it.
    Replaced in the last 2 years:
    Lower control arm bushings to Whiteline bushings
    Upper control arms
    Upper and lower O2 sensors
    Spark plug wires and coil packs
    Suspension
    Last 3 months:
    Upper and lower ball joints
    Used steering rack- original needed replaced, didn’t like how the remanufactured one purchased to replace it drove so I found used one with low miles and replaced that one.
    Front output shaft was leaking, seal replaced
    Alignment done last week
    Spare tire shown is included but he mounted tire is different than the running tires.
    All original/extra parts I have are included, including an extra steering rack if wanted. I also have some seats out of a VW Jetta I modified to fit in (drive side is powered). They sit higher than the stock seats. Included if you want them.
  2. Jan 27, 2018 at 8:36 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Nice truck, I saw this on craigslist the other day! GLWS :thumbsup:
    Animus313[OP] likes this.
  3. Feb 1, 2018 at 12:25 PM
    07toyota1991
    07toyota1991 Well-Known Member
    1999 Toyota Tacoma Regular Cab 2.7 5spd
    5100's with OME 883, Dakar's, SCS Ray 10, 285/75/16 Cooper STT Pro, LCE header, Magnaflow exhaust, ARE shell, Addicted offroad front plate bumper with Warn VR8S
    Any interest in pulling fender flares off and selling to me? lol
    ManInTheMaze likes this.
  4. Feb 2, 2018 at 11:23 AM
    Animus313
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    Eh, I'd like to keep them with the truck. lol. All they are are the stock ones painted OD Green with some spray paint. And I replaced the rubber trim with some different trim rubber.
  5. Feb 2, 2018 at 11:50 AM
    07toyota1991
    I figured you would want too but thought I would ask. My truck is also green and I cant find those flares anywhere! Dealer price is $250/flare new. I would give you a decent chunck of $ to make it worth your while plus pay shipping?
  6. Feb 3, 2018 at 3:17 PM
    Animus313
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    They are pricey to get from a dealer. Sorry for now I'll keep them with the truck.
    Truck still for sale.
  7. Feb 14, 2018 at 9:19 PM
    Animus313
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    Bump! Still for sale. Price drop $8000
  8. Feb 17, 2018 at 11:41 AM
    tacomah7
    tacomah7 Well-Known Member
    Brendan
    1999 Tacoma 4x4
    3" suspension lift (Sway Away 2.0 Racerunners with eibach 14" 650lbs coils) All Pro Offroad Rear Expo Leafs w/ toytec boss shocks 4crawler 1" body lift Trail gear front bumper & rock sliders Trail gear rear bumper w/ custom tire carrier 33x12.5x15 Cooper Stt Pro Glare led 42" curved lightbar spidertrax 1.25" wheel spacers on the front Smittybilt 9500 winch Trd E locker w/ 12voltguy harness
    beauty truck man, i like the rear tire carrier, how do you find those whiteline lca bushings? any squeaks?
  9. Feb 17, 2018 at 11:52 AM
    Animus313
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    Whiteline doesn't specify them for Tacomas specifically but they are these ones from this thread:
    https://www.tacomaworld.com/threads/lca-bushings-oem-energy-suspension-whiteline.394935/
    The fit right in. Been running them for about 2 years now. At first they did have some squeaks, but I believe it was mostly my fault. I spaced while installing them to put the supplied grease on the inside before I put the bolt back though. It was annoying so what I did was get some heavy silicone spray and a very liquidy white lithium grease spray and would soak them each day alternating sprays. Did that for about a week and the squeak was gone.
  10. Feb 17, 2018 at 3:02 PM
    tacomah7
    Brendan
    1999 Tacoma 4x4
    sweet thanks for the quick reply, thats good to know about the squeaks, ive read that some guys have the alignment go out becuz the bushigns arent tapered all the way, anyways good luck with the sale!
  11. Mar 4, 2018 at 11:40 AM
    Animus313
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    Still for sale. Price drop to $7500 OBO
Thread Status:
