*Sold*
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by GT7, Jan 28, 2020.
  1. Jan 28, 2020 at 7:58 PM
    GT7
    GT7 [OP] One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Brian crower stroker crank
    Cp coated pistons 95.5 mm
    Rods from brian crower
    Acl bearings
    Kelford cams
    New valve springs from kelford
    1mm larger exhaust and intake valves, valve seals
    Arp head studs
    Darton sleeves
    Cometic head gasket
    https://store.briancrower.com/collections/1grfe/products/bc0368?variant=4507577155
    I will ship on my dime. I also have a long block with 100k miles the buyer can have included with purchase, but I will not ship on my dime.
    spent around 9k for everything including spare long block.
    no trades. No part out unless you only want the bottom end components.
    $7,000 obo for the lot
  2. Jan 29, 2020 at 5:38 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Bump
  3. Jan 30, 2020 at 6:17 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  4. Jan 30, 2020 at 6:37 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    I know .... :(
  5. Jan 30, 2020 at 8:03 AM
    feesquivel
    feesquivel Well-Known Member
    West Texas
    Would all this be required for a turbo application? I'm curious what were you building
  6. Jan 30, 2020 at 9:01 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    The cams would not work for the turbo. Because of the valve overlap.
    every thing else is good to go
  7. Jan 31, 2020 at 7:58 AM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    this is a great setup and great deal. and no wait time.
    good luck with sale man.
    Deeps and GT7[OP] like this.
  8. Jan 31, 2020 at 8:21 AM
    tvagreene
    tvagreene Well-Known Member
    James
    Ooltewah, TN
    2010 Pyrite Mica Double Cab TRD Sport 4x4
    TRD exhaust, matte black badges and Bedside stickers, Bilstein 5100s front and rear, Eibach Coils, heated leather seats
    What kind of power would a setup like this put out?
    GT7[OP] likes this.
  9. Jan 31, 2020 at 8:24 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Depends supercharger or turbo?
    if neither probably less then 300 whp i would guess
  10. Jan 31, 2020 at 8:26 AM
    tvagreene
    James
    Ooltewah, TN
    With Supercharger
  11. Jan 31, 2020 at 9:28 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Which one? 400 easily but depends on other mods. Headers intake tune pulley size etc.
    with trd blower over 400 is possible but depends entirely on mods
  12. Feb 1, 2020 at 1:34 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Bump
  13. Feb 1, 2020 at 9:00 PM
    ETALATE
    ETALATE Non Sum Qualis Eram
    Burlingame, CA
    2011 DCSB TRD OR
    The want is real :anonymous:
    GT7[OP] likes this.
  14. Feb 1, 2020 at 9:06 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Just do it. You can always make more money :anonymous:
    NOLAYota, SR-71A and ETALATE[QUOTED] like this.
  15. Feb 2, 2020 at 6:50 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    wait! WHAT?!
    Why?
  16. Feb 3, 2020 at 7:53 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Bump
  17. Feb 6, 2020 at 2:24 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    What's happened here? I was living vicariously through you.
    TodayWasTHeDaY likes this.
  18. Feb 6, 2020 at 5:06 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Life has unexpected twists
  19. Feb 9, 2020 at 12:06 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Bump
  20. Feb 13, 2020 at 12:55 PM
    BillDaCat8
    Jake
    PHX
    If it helps anyone out in making a decision on this. These guys can do the sleeves. They've done several before and as such, already have their CNC machine programming down. Which saves a considerable amount of money. They're in So Cal. Oceanside to be more specific.
    http://www.raceenginedevelopment.com/
    Bump
    JustDSM and Hawk373 like this.
