solid axel death wobble ?
Discussion in 'Solid Axle Suspension' started by mt sas, Feb 19, 2013.
  1. Feb 22, 2013 at 8:13 PM
    mt sas
    mt sas [OP] Well-Known Member
    western montana
    fun
    S.A.S 21spline tcase highsteer
    think so define shim properly ?
  2. Feb 22, 2013 at 8:26 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I had crazy death wobble on the crawler..end up being a lower shock bolt that was M.I.A.
    Another thing that makes wobble is loose shackles..I can not keep those suckers tight and have to crank them down at least once during a good run.
  3. Feb 22, 2013 at 8:32 PM
    MonkeyProof
    SoCal- SGV
    I'm guessing he's talking about the shims that helps to properly preload the trunnion bearings..I think 15ft lbs is what is recommended when using a pull scale.
  4. Feb 22, 2013 at 8:39 PM
    mt sas
    western montana
    fun
    the trunnions were golden when we built the axel im rollin it out on Tuesday and checkin everything will post pics of the process and what I find when I can ! its gotta stop I dd my truck and am tired of burnin diesel every day i love my cummins but ive been drivin yotas for 15 years and they are what I like ! ha ha
  5. Feb 22, 2013 at 9:12 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    The hard part is that the wobble could be anything.. Typically I start from the tires and work my way into the suspension. Wheel balanced, ball joint play, bushings, pitman arm, etc, etc.
  6. Feb 22, 2013 at 9:40 PM
    mt sas
    western montana
    fun
    yep that's where im headed the tires/wheels are balanced alignment is good goin deeper on Tuesday
  7. Feb 23, 2013 at 4:16 PM
    noSKills858
    Alex
    Poway, CA
    Although it does help to know if it's something consistent or when you get to a certain speed which narrows it down a lot more.
  8. Feb 24, 2013 at 9:53 PM
    mt sas
    western montana
    fun
    ive been getn it around 35mph with any tire /wheel combo ive had on it .its always when driving straight mostly on pavement
  9. Feb 27, 2013 at 6:18 PM
    mt sas
    western montana
    fun
    replaced all the old rubber bushings with new poly bushings and one tierod end i think it was the rear shackle frame bushings were the culprits ! the death wobble is gone
  10. Feb 27, 2013 at 6:21 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
  11. Feb 28, 2013 at 5:08 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Nice..... now to break it on the trail.:thumbsup:
  12. May 30, 2013 at 10:20 AM
    ironman44bear
    ironman44bear "Toyota Mafia" MORE BALLS THAN BRAINS
    Billy
    Clovis,CA
    05 DC Taco 4x4
    What type of shackles are you runnin? Do they have a welded connector bar between the the two or are they two separate plates. On my old yota that I sas'd I had serious death wobble and I was runnin shackles that weren't connected...welded a piece of tube between them and bam...death wobble gone.
  13. Jun 19, 2013 at 6:15 PM
    Werkro01
    Werkro01 Senior Clown
    Rob
    CT
    Butters
    Long Bed Leer cap, Wheather tech floor liners, Black badges, Demello Offroad front plate bumper, rear wrap around tube bumper and sliders. Scorpion lined bed, rocker panels and fender flares.
    Nice. If it were still there I would have suggested steering shocks... but only crappy Jeeps need those.:D
