solid bed extender?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Aug 17, 2020.
  1. Aug 17, 2020 at 11:42 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Has anyone modified or built a bed extender to be solid and not pass-through/see-through?
    Maybe one that can flip to act as a cargo divider when not in use
    Not sure why no aftermarket companies sell them, such as fabricating it from metal
    Seems like it would be useful for camping/sleeping in a 5 foot bed.
    Because with a camper shell or soft top, it could make the bed longer to have room for your feet but still be protected by the elements, not have them bitten off by wild animals outside, etc.
    and if it had a top/roof section (maybe removable) that would provide full coverage on the lower half, all the way back to whatever topper the truck has
  2. Aug 18, 2020 at 4:35 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    With a solid extender you're potentially going to block at least one of your turn and brake lights from the view of drivers behind you. Some of the older extenders were more square. Newer versions are angled and longer in the center to prevent this from happening.
  3. Aug 18, 2020 at 6:10 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    IMO, It will be much easier to cover an extender with netting or some type of fabric cover than to build one. If you plan on having it swing like the factory one, it's likely has to be curved to prevent hitting the camper shell or clear the wheel well.
    Bodyguard89 likes this.
  4. Aug 18, 2020 at 6:45 AM
    Bodyguard89
    Bodyguard89 Well-Known Member
    Montana
    2010 TRD OR DCSB
    Still in planning phase ...
    Yep, get a tailgate net the length to got from one end of the OEM bed extender to the other and attach. They don't usually (none that I could find) with attachment straps on the top and bottom, easy fix with short cinch straps.
  5. Aug 18, 2020 at 8:08 PM
    TacoTuesday1
    FL
    Honestly that sounds like a great idea
    I wonder what extenders are compatible with Total Chaos bed stiffeners
    just found this DIY showing how to make it work with an Amp Research one
    https://www.tacomaworld.com/threads...feners-with-amp-research-bed-extender.484522/
