Solution: PreRunner Driveshaft Alignment with Rear Lift. No Vibes/CB Damage!
Discussion in 'Suspension' started by Relik, Aug 27, 2013.
  1. Aug 27, 2013 at 11:19 PM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey guys,
    Thought I'd share my experience with lifts and driveshaft/carrier bearing alignment on my '11 PreRunner. It all started with TSB+AAL rear springs. I heard some vibrations while at speed, and louder when above 60mph. So I looked under the truck where I thought vibtration/humming came from. And I spotted my carrier bearing. Started to see some bashing of my Carrier Bearing (CB), and when I got All-Pro 3" Standard Lift springs, my CB eventually blew out. Its just a bearing in a rubber pillow holding the 2wd/PreRunner driveshaft up between the axle and transmission.
    The lift causes the driveshaft to be "shorter" due to the greated angle after lift. And the CB has a neutral position on the driveshaft, which LOWERS and MOVES REARWARD with lift.
    MORE EVIDENT WHEN YOU LOOK AT THE TRANSMISSION SIDE OF SHAFT. ITS STICKING OUT INSTED OF FLUSH.
    So I tried the Beefed Taco CB bracket, which lowers the mounting of the CB for better angle. It did align the angle of the driveshaft well, but then this is when it was evident that the driveshaft has moved rearward. My CB bearing gave out and my vibrations at 60mph got terrible (driveshaft flopping around...)
    So I bought a replacement CB (NOT CHEAP!) and noticed the start of some wear on the rubber. So after some research I decided to try these All-Pro axle relocation plates which shift the axle forward 3/4"
    This caused my U-bolts to have to be at an angle but it worked out. More than 1/2 of the vibes in the road went away but still at 60/70 loudest. And when I went off-road, I'd start wearing the rubber on CB from it not being aligned all the way. The transmission/driveshaft did still stick out but only 1/4" to 3/8" only now.
    But thanks to the forums a guy hinted to use a Driveshaft Spacer instead of the axle plates, which is a spacer between the axle pinion and the driveshaft. Since I used 3/4" axle plates and needed more distance, I ordered a 1" driveshaft spacer from 4crawler.com. They sell different size spacers from 3/4" to 1.5".
    http://www.4crawler.com/4x4/ForSale/DriveshaftSpacer.shtml#65mmx65mm
    AND THEN....
    AND MY CB AND DRIVESHAFT ARE ALIGNED! All my vibrations at speed are gone and the truck drives great with the axle back where it needs to be without the axle plates and with the Beefed Taco lowering bracket AND driveshaft spacer. This may not be an issue on your truck, but I'm sure a 2wd/PreRunner with 3"+ lift should have this problem as I did. Thought I'd share the information.
    4Crawler Driveshaft Spacer (I got 1" spacer for 3" springs):
    BeefedTaco CB Bracket: 1.5" drop
    http://stores.streetacos.com/-strse-1/carrier-bearing-driveshaft-vibration/Detail.bok
    Tacoma_SR5Pro and Biscuits like this.
  2. Aug 28, 2013 at 12:20 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I was under the impression that rather than force the full driveshaft misalignment through the front U joint, it may be best to raise the carrier bearing and share the angle of movement through the three U joints.
    PK
  3. Aug 28, 2013 at 9:43 AM
    Relik
    Eddy
    Thousand Oaks, CA
    Hm, you may have a point. Though the driveshaft spacer is still crucial to fix the displacement of the driveshaft, the CB drop is not "required". I just didn't try the spacer without the CB drop bracket since I had it installed and all looked well afterwards.
  4. Aug 28, 2013 at 9:53 AM
    Large
    Large Red
    Might have to fork over the money and get one of these, but I am 4WD.
  5. Aug 28, 2013 at 9:58 AM
    Relik
    Eddy
    Thousand Oaks, CA
    I'm not sure about the 4WD, I thought they had a slip yoke in the middle of the driveshaft so not a CB to damage or other side effects....just that the slip yoke is more extended. I can't see why it would not work though to get the shaft back in its original location with a lift in rear.
  6. Aug 28, 2013 at 1:50 PM
    Large
    Large Red
    There is a slip yoke and a CB on 4wds.
  7. Aug 28, 2013 at 4:35 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  8. Aug 28, 2013 at 5:15 PM
    Relik
    Eddy
    Thousand Oaks, CA
    Very nice, those are half the price, and black! haha. Good find, bad timing for me ;)
  9. Aug 28, 2013 at 5:29 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    The only possible thing to look at would be full compression of the rear suspension, with the spacer the DS will be pushing further into the trans. at full rear suspension compression.
    Hopefully there is enough room for the extra length at full compression to not cause any harm to the tranny housing.
    Just thinking it may be worth checking.
  10. Sep 23, 2013 at 9:07 PM
    mandzach
    mandzach Well-Known Member
    Great point, anyone had the chance to check this?
  11. Sep 25, 2013 at 11:25 PM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    Yup, 4wds don't need this! Still, good to know!!!
  12. Oct 7, 2015 at 12:49 PM
    TacoDaddy
    TacoDaddy Just call me Daddy
    Brian
    Costa Mesa, CA
    '11 Sport
    What bolt pattern did you order?
  13. Dec 5, 2015 at 7:56 PM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    Sub'd ... I just ordered the .75" thick 65mm X 65mm from 4crawler
    I have a 2" AAL but I'm about to add the 1" block to the axle as the 4" spindles are installed
    See what happens then ... something has to work
    The OME CB drop didn't help ... just moved the vibes to a different mph
  14. Feb 21, 2016 at 11:02 AM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    I will tell you as of ten minutes ago that the low range piece does not work on a prerunner. Fml.
    So im guessing the prerunner pattern is 65x65 as the gentleman above has ordered, that is not one of the fitments the manufacturer says is on there and confirms 65x65 is probably right
    What is the proper way to measure? Seems like a rectangle not a square
  15. Feb 22, 2016 at 2:28 PM
    2nd screen name
    Bob
    LV/SD
    Ordered 66x66x11for 06 prerunner from 4crawler Will update on fitment when recieved
  16. Mar 1, 2016 at 7:04 AM
    2nd screen name
    Bob
    LV/SD
    66x66x11 for me. Since the bolts are 11mm there is only one possible choice. I would guess all prerunner sport v6 are like mine. Can't confirm for other models
  17. Feb 15, 2017 at 11:28 PM
    TRD-Merchant_Marine
    TRD-Merchant_Marine Well-Known Member
    Austin
    2014 White Tacoma TRD Sport DCLB
  18. Jul 5, 2017 at 2:17 PM
    brandonlamb25
    brandonlamb25 Well-Known Member
    Georgia
    08 Crewcab Prerunner V6
    K&N Intake, Wet Okole Seat Covers, Ipod to Factory radio hookup kit, Black Low Pro Toolbox, Toytec Coilovers and 285/75r16 BFG MT's
    I'm wondering what I need to measure to know what size to order. 2008 prerunner doublecab with a 4" block on the rear. Now the black cylinder that joins the transmission is sticking out of the silver can at the tranny about 3/4". Any information welcome.
  19. Feb 5, 2019 at 12:31 PM
    phoenixpiole
    phoenixpiole Well-Known Member
    2018 Tacoma DCSB SR5
    OP,
    How long were you able to drive the truck with the driveshaft sticking out of the transmission before the CB gave out? My 3rd gen prerunner is suffering the same issue with the slip yoke however it isn’t sticking out of the transmission I can just tell it’s not fully engaged. I’m thinking worst case scenario the driveshaft would fail but the transmission itself would be unharmed?
  20. Oct 3, 2021 at 10:59 AM
    Geogonzalez
    Geogonzalez Member
    George
    06 DCSB PreRunner TRD OffRoad
    Front 4" Maxtrac /Rear 3" block 5125 Bilstein 16" Method Rims
    Did the 66x66x11 spacer work on your 06 Tacoma Prerunner. I Have an 06 prerunner Trd and I'm looking to install a spacer for a 3 inch all pro lift.
