SOLVED Chilkat e-locker conversion - preserves factory sensors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deanosaurus, Feb 13, 2025.
  1. Feb 13, 2025 at 8:52 AM
    deanosaurus
    deanosaurus [OP] Caveman
    Northeast Region
    09 TRD OR AC
    Hello.
    My e-locker actuator shit the bed recently, and for a couple bucks more than an Aisin, I'm considering the Chilkat unit to complement the FJ tcase swap this spring.
    Are the factory indicators (dash light) and traction control features (ATRAC etc) preserved with the Chilkat or other manual locker conversions? Where is the sensor for the lock status in the factory configuration, is it inside the 3rd or is it inside the factory electronic actuator?
    Thanks.
    SOLVED: For anyone else looking, somebody confirmed that the sensors are IN the 3rd on 2nd gens and have a separate plug.
  2. Feb 13, 2025 at 9:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There are 2 limit switches (RLY1 & RLY2) in the actuator and a detection switch (RLP) on the rear locker.
    The light is easy, you just ground the detection switch signal wire (RLP) (Blue/Yellow) to turn the light on and signal to the Skid Control ECU (ABS Module) that the diff is locked so it disables ABS as normal.
    Making the 4wd ECU happy is another story, the easy way would be to put in a 4wd ECU out of a non TRD 4wd truck (89533-04021) so it wouldn't be looking for any of the locker switches.
    You may check with the guy in this thread, he may be interested in selling his non-locker ECU. Someone put a non-locker ECU in his truck before he bought it, didn't realize it until he tried the locker.
    https://www.tacomaworld.com/threads/rear-diff-wont-lock.851644/
    I don't have much info on the locker posted here but the switch values are in the 4wd ECU pinout table if you want to try to engineer something.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
    tcBob, deanosaurus[OP] and TnShooter like this.
  3. Feb 14, 2025 at 7:32 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    I think with the FJ diff and tube, and a manual rear locker, the 4WD ECU is then completely unnecessary - I believe non-TRD trucks with the FJ swap delete the 4WD ECU completely. I'll have to test for RLP out of the diff.
    Thanks a million!
  4. Feb 14, 2025 at 7:56 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ah I didn't know you were FJ swapped, yea then you don't need the 4wd ECU in play at all you just have to do a few wiring hacks which we figured out here for the other systems to be happy.
    Let's see your FJ case swap | Page 161 | Tacoma World
  5. Feb 15, 2025 at 10:04 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    For anyone else looking, somebody confirmed that the sensors are IN the 3rd and have a separate plug.
  6. Feb 15, 2025 at 6:23 PM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Is that for 2nd gen? 3rd has a completely different type of locker
  7. Feb 16, 2025 at 7:05 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    3rd as in third member, not third gen.
  8. Feb 16, 2025 at 7:15 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Yep I was just sayin 2nd vs 3rd gens the lockers are completely different. 3rd gen uses an Eaton type electromechanical vs 2nd has the little rack and pinion.
  9. Feb 16, 2025 at 10:31 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    Oh right, yes, this is for 2nd gen trucks - no clue about 3rd gen trucks.
