** Solved - Engine knock passenger side V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by P4iNz, Jul 4, 2020.
  1. Jul 4, 2020 at 12:02 PM
    P4iNz
    P4iNz [OP] Member
    Gods Waiting Room
    19 Taco XSP
    Westin Ultimate Bull Bar Magnaflow Cat-Back
    So with the outright refusal in some cases for folks to update with success and/or horror stories I did the bit where you search and ooo common problem (random complaining followed by some advise) I thought it would be prudent to post my success. So on my 2019 Tacoma SR5 4x4 I had quite the knock, sound resemblance to an old chevrolet low on oil. After a few trial and error and WAY to much digging into TSB’s I found the fix. We have a vacuum pump on the 2GR-FKS when it starts to go this thing makes the engine sound like it has a bad lifter. I have attached the pdf of the TSB. Fix your truck and enjoy!
  2. Jul 4, 2020 at 1:29 PM
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    I have this noise also but the bulletin says it is not cover if you have crawl control, (2016 TRD Off-Road 4x4)
  3. Jul 4, 2020 at 2:09 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Good job op :thumbsup:
    Let us know the outcome.
    4x4spiegel likes this.
  4. Jul 4, 2020 at 2:51 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    Skydvrr[QUOTED] likes this.
  5. Jul 6, 2020 at 9:41 AM
    P4iNz
    P4iNz [OP] Member
    Gods Waiting Room
    19 Taco XSP
    Fixed it over the weekend (or should I say my warranty did)
  6. Jul 6, 2020 at 11:35 AM
    Danno 1948
    Dan
    Ocala,Fl.
    what they do,
  7. Jul 6, 2020 at 11:52 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
  8. Jul 6, 2020 at 12:02 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    This TSB doesn't apply to you because trucks with CC don't have the vacuum pump. The brake booster is electric/hydraulic instead of vacuum assisted.
  9. Jul 6, 2020 at 2:02 PM
    Danno 1948
    Dan
    Ocala,Fl.
    ok cool thanks
  10. Jul 6, 2020 at 2:33 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Good job !
    Do you have a recording of the knock from the vacuum pump prior to it being fixed?
  11. Feb 20, 2021 at 2:28 AM
    Aqua20062
    Aqua20062 New Member
    Hector
    I see the comment tapping at idle? How about when engine is going through rpm range and the tapping noise is is following right there with revs as high as you can Rev. And to add the tapping gets so loud that it sounds like the lifter or valve is ready to pop! Where does the vacuum pump come into play with this scenario??? Very curious because there literally 1000's of tacomas with this issues. I already know what the problem is and have post a thread on this. Some should read it. It will enlighten you!
  12. Apr 6, 2023 at 8:32 AM
    Yoda910
    Yoda910 Active Member
    2018 SR5
    None
    I can never get the sound to load nomatter what phone I have. I most likely need this fix.
    klitzonthefritz likes this.
  13. Jul 31, 2023 at 6:13 PM
    klitzonthefritz
    klitzonthefritz New Member
    Hamilton, NJ
    '16 DCSB TRD Sport
    Anybody post the audio file from the TSB? My ‘16 raps like a diesel all the time since new and it’s getting annoying. Zero mechanical issues after 90k but still
